PCIe Hot-Plug not working
The cable used on the devkit follows the Open Compute Facebook version of the Mini-SAS spec. Standard Mini-SAS cable would not work as it does not carry some of the sideband signals. Here are the cables from Amphenol which are compatible with the Orin devkit.
Description Mfg P/N
CABLE Assy miniSAS-HD x4 GEN4 500MM Black Male 0° PCI Express to Male 0° PCI Express wire 100ohm UL VW-1 NEDDDF-N904
CABLE Assy miniSAS-HD x4 GEN4 1000MM Black Male 0° PCI Express to Male 0° PCI Express wire 100ohm UL VW-1 NEDDDF-N901
CABLE Assy miniSAS-HD x4 GEN4 3000MM Black Male 0° PCI Express to Male 0° PCI Express wire 100ohm UL VW-1 NEDDDF-N903
Dear @VickNV ,
Unfortunately, the mini-SAS cable with the model number you provided(NEDDDF-N904, NEDDDF-N901, NEDDDF-N903) could not be found on Amphenol’s official site.↓
https://www.amphenol-cs.com/
I’m sorry, but could you please check the model number again?
Also, I understand you need to support sideband signals, are the following products compatible with Orin DevKit?
thanks,
@shibata-a
This cable was designed for the devkit so it may not be advertised as a standard cable on their website. You should reach out to their local Amphenol contact directly to inquire and purchase the cable. Thanks.
@shibata-a please share back your experience once your setup works well. Thanks.
Dear @VickNV ,
With the support of the local team, we were able to make it work as expected.
Thank you very much.
