Nvmsgbroker errors when using kafka deepsteam python
• Hardware Platform (GPU)
NVIDIA GeForce GTX 1070
• *** Deep Stream Version
6.3
**• NVIDIA GPU Driver Version **
530.30.02
I’m writing code in python
The task is to save frames and send some information to kafka. I have created a pipeline that you can see in the image, but I get an error:
0:00:08.781040064 2684807      0x4461f20 WARN             nvmsgbroker gstnvmsgbroker.cpp:375:legacy_gst_nvmsgbroker_start:<nvmsg-broker> error: No protocol adaptor library provided
0:00:08.781081595 2684807      0x4461f20 WARN                basesink gstbasesink.c:5367:gst_base_sink_change_state:<nvmsg-broker> error: Failed to start
Error: gst-resource-error-quark: Resource not found. (3): gstnvmsgbroker.cpp(375): legacy_gst_nvmsgbroker_start (): /GstPipeline:pipeline0/GstNvMsgBroker:nvmsg-broker:
Exiting app
I will also leave the full log below. Please note, if I run the same code without the kafka module, it runs and works (though with some warnings)
logs.txt (140.1 KB)
nvmsgbroker plugin is opensource. from the error, proto-lib is not set. take deepstream-test4 for example, the following parameters are used to pass kafka information. please refer to readme.
-p /opt/nvidia/deepstream/deepstream/lib/libnvds_kafka_proto.so --conn-str="localhost;9092"
yes, you’re right, I initialized the proto_lib and conn_str variables incorrectly
Sorry for the late reply, Is this still an DeepStream issue to support? Thanks!
