DRIVE OS Version: 6.0.10
Issue Description
I’m currently testing the camera Smartlead BS2S107A-100-03 with the application nvsipl_camera using the command below.
sudo ./nvsipl_camera -c R0SIM623S4RU1197NB2_CPHY_x4 -m “0x1111 0x0000 0x0000 0x0000” --enableRawOutput --showfps -d 1
The camera did not start 3 times out of 5 times.
Would you know what would cause this problem?
Error String
nvsipl_camera: ERROR: NvSIPLCamera Init failed
nvsipl_camera: ERROR: Master initialization failed. status: 10
Log
nvsipc_camera_mod.log (18.3 KB)
Dear @Natsuha_Shishido ,
Please check syslog with verbose mode enabled in nvsipl_camera to get more insights.
Do you have any other camera module to test it? Could you check with 1 or 2 cameras to see if same can be reproduced
Could you please provide any update for this topic?
Dear @SivaRamaKrishnaNV @carolyuu
I added the “-v 4” option when starting nvsipl_camera to obtain a log.
Another camera module that can be tested is the Smartlead BF8S103G-100-00.
This does not exhibit the same issues as the Smartlead BS2S107A-100-03.
Log
nvsipc_camera__Success.log (696.2 KB)
nvsipc_camera__Failure.log (970.8 KB)
I have provided the logs; may I kindly ask if there are any updates regarding the progress on this matter?
Could you try check using port B as given at IMX623 Using 4 Lane CPHY | NVIDIA Docs and see if the behavior is observed.
I tryed an operation check using port B and the following command.
sudo ./nvsipl_camera --platform-config “R0SIM623S4RU1197NB2_CPHY_x4” --link-enable-masks “0x0000 0x1111 0x0000 0x0000” --showfps -d 1 -v 4
An issue occurred where no video output was displayed on the monitor.
Attached are the logs for when the video output was successful (nvsipc_camera__portB_Success.log) and when the video output was not displayed (nvsipc_camera__portB_Failure.log).
nvsipc_camera__portB_Failure.log (865.2 KB)
nvsipc_camera__portB_Success.log (651.1 KB)
In both cases, the FPS seems to be very less ( Expecting 30FPS). Could you disable the display flag and check FPS. Also, could you check reflashing to see if it is a SW issue.
Our QA has tested with 4 Smartlead IMX623 B2 cameras and no issue is noticed with sudo ./nvsipl_camera --platform-config "R0SIM623S4RU1197NB2_CPHY_x4" --link-enable-masks "0 0x1111 0 0" --showfps -r 180
Thank you for your confirmation.
I was able to successfully launch 10 out of 10 times using the command you provided.
I would like to confirm three points:
- Why is the “-d 1” option omitted? Does including this option cause a decrease in FPS?
- Could the “-v 4” option also be a factor in reducing FPS?
- Is the Smartlead IMX623 B2 compatible only with Port B?
Enabling display would expect FPS when multiple outputs are enabled(raw, isp0, isp1) We notice it earlier. Verbose option provides more logging information and not expected impact FPS.
The port B and other ports have different deserializer. Did you try smartlead IMX623 B2 on other ports as well?
Yes, I have tested the IMX623 B2 connected to ports A, C, and D.
At that time, I confirmed that it would start up with a probability of about 1 in 5.
Thank you for your support. I’m closing the thread with this response..
