• RTX 3060
• DeepStream Version 6.0.1
• NVIDIA GPU Driver Version 512.15
When I run the sample deepstream config app, everything loads up well but the nvv4l2decoder plugin is not able to load /dev/nvidia0. Could you please help with this. Attaching the logs file here.
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
1 OUTPUT kFLOAT predictions/Softmax 12x1x1
1 OUTPUT kFLOAT predictions/Softmax 6x1x1
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is ON
[NvMultiObjectTracker] Initialized
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:194>: Pipeline ready
econdary_gie_1>e[00m NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 5]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/../../models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:02.647107767 e[336m 1679e[00m 0x7fd930002380 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<secondary_gie_1>e[00m NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 5]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/../../models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:02.651521124 e[336m 1679e[00m 0x7fd930002380 e[36mINFO e[00m e[00m nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_1>e[00m [UID 5]: Load new model:/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/config_infer_secondary_carcolor.txt sucessfully
0:00:02.662726155 e[336m 1679e[00m 0x7fd930002380 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<secondary_gie_0>e[00m NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 4]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/../../models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:02.662970809 e[336m 1679e[00m 0x7fd930002380 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<secondary_gie_0>e[00m NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 4]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/../../models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:02.665673580 e[336m 1679e[00m 0x7fd930002380 e[36mINFO e[00m e[00m nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_0>e[00m [UID 4]: Load new model:/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt sucessfully
0:00:02.786567498 e[336m 1679e[00m 0x7fd930002380 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie>e[00m NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
0:00:02.786954573 e[336m 1679e[00m 0x7fd930002380 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie>e[00m NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
0:00:02.788686080 e[336m 1679e[00m 0x7fd930002380 e[36mINFO e[00m e[00m nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie>e[00m [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
0:00:02.790729870 e[336m 1679e[00m 0x7fd930002380 e[33;01mWARN e[00m e[00m basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source>e[00m pad not activated yet
0:00:02.791084543 e[336m 1679e[00m 0x7fd930002380 e[33;01mWARN e[00m e[00m basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source>e[00m pad not activated yet
0:00:02.791659605 e[336m 1679e[00m 0x7fd930002380 e[33;01mWARN e[00m e[00m basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source>e[00m pad not activated yet
0:00:02.791874072 e[336m 1679e[00m 0x7fd930002380 e[33;01mWARN e[00m e[00m basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source>e[00m pad not activated yet
0:00:02.792422633 e[336m 1679e[00m 0x7fd930002380 e[33;01mWARN e[00m e[00m basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source>e[00m pad not activated yet
0:00:02.792724967 e[336m 1679e[00m 0x7fd930002380 e[33;01mWARN e[00m e[00m basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source>e[00m pad not activated yet
0:00:02.795257805 e[336m 1679e[00m 0x7fd930002380 e[33;01mWARN e[00m e[00m basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source>e[00m pad not activated yet
0:00:02.795490727 e[336m 1679e[00m 0x7fd930002380 e[33;01mWARN e[00m e[00m basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source>e[00m pad not activated yet
0:00:02.798414948 e[336m 1679e[00m 0x7fd8940410f0 e[33;01mWARN e[00m e[00m qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux0>e[00m failed to find fragment defaults for stream 1
0:00:02.798455124 e[336m 1679e[00m 0x7fd88001e990 e[33;01mWARN e[00m e[00m qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux1>e[00m failed to find fragment defaults for stream 1
0:00:02.799881552 e[336m 1679e[00m 0x7fd8940410f0 e[33;01mWARN e[00m e[00m qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux0>e[00m failed to find fragment defaults for stream 2
0:00:02.799903383 e[336m 1679e[00m 0x7fd88001e990 e[33;01mWARN e[00m e[00m qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux1>e[00m failed to find fragment defaults for stream 2
0:00:02.800019023 e[336m 1679e[00m 0x7fd87c004590 e[33;01mWARN e[00m e[00m qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux3>e[00m failed to find fragment defaults for stream 1
0:00:02.800494155 e[336m 1679e[00m 0x7fd898034a30 e[33;01mWARN e[00m e[00m qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux2>e[00m failed to find fragment defaults for stream 1
0:00:02.800716988 e[336m 1679e[00m 0x7fd87c004590 e[33;01mWARN e[00m e[00m qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux3>e[00m failed to find fragment defaults for stream 2
0:00:02.800835633 e[336m 1679e[00m 0x7fd898034a30 e[33;01mWARN e[00m e[00m qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux2>e[00m failed to find fragment defaults for stream 2
0:00:02.846730133 e[336m 1679e[00m 0x7fd868013ed0 e[33;01mWARN e[00m e[00m v4l2 v4l2_calls.c:653:gst_v4l2_open:<nvv4l2decoder1>e[00m error: Could not open device '/dev/nvidia0' for reading and writing.
0:00:02.847022242 e[336m 1679e[00m 0x7fd868013ed0 e[33;01mWARN e[00m e[00m v4l2 v4l2_calls.c:653:gst_v4l2_open:<nvv4l2decoder1>e[00m error: system error: No such file or directory
0:00:02.847227718 e[336m 1679e[00m 0x7fd86c012370 e[33;01mWARN e[00m e[00m v4l2 v4l2_calls.c:653:gst_v4l2_open:<nvv4l2decoder3>e[00m error: Could not open device '/dev/nvidia0' for reading and writing.
0:00:02.847375253 e[336m 1679e[00m 0x7fd86c012370 e[33;01mWARN e[00m e[00m v4l2 v4l2_calls.c:653:gst_v4l2_open:<nvv4l2decoder3>e[00m error: system error: No such file or directory
0:00:02.846824617 e[336m 1679e[00m 0x7fd894041770 e[33;01mWARN e[00m e[00m v4l2 v4l2_calls.c:653:gst_v4l2_open:<nvv4l2decoder2>e[00m error: Could not open device '/dev/nvidia0' for reading and writing.
0:00:02.847661892 e[336m 1679e[00m 0x7fd894041770 e[33;01mWARN e[00m e[00m v4l2 v4l2_calls.c:653:gst_v4l2_open:<nvv4l2decoder2>e[00m error: system error: No such file or directory
0:00:02.846735814 e[336m 1679e[00m 0x7fd86c011cf0 e[33;01mWARN e[00m e[00m v4l2 v4l2_calls.c:653:gst_v4l2_open:<nvv4l2decoder0>e[00m error: Could not open device '/dev/nvidia0' for reading and writing.
0:00:02.847520258 e[336m 1679e[00m 0x7fd86c012370 e[33;01mWARN e[00m e[00m videodecoder gstvideodecoder.c:2535:gst_video_decoder_change_state:<nvv4l2decoder3>e[00m error: Failed to open decoder
0:00:02.847250681 e[336m 1679e[00m 0x7fd868013ed0 e[33;01mWARN e[00m e[00m videodecoder gstvideodecoder.c:2535:gst_video_decoder_change_state:<nvv4l2decoder1>e[00m error: Failed to open decoder
0:00:02.847813750 e[336m 1679e[00m 0x7fd894041770 e[33;01mWARN e[00m e[00m videodecoder gstvideodecoder.c:2535:gst_video_decoder_change_state:<nvv4l2decoder2>e[00m error: Failed to open decoder
0:00:02.848060406 e[336m 1679e[00m 0x7fd86c011cf0 e[33;01mWARN e[00m e[00m v4l2 v4l2_calls.c:653:gst_v4l2_open:<nvv4l2decoder0>e[00m error: system error: No such file or directory
0:00:02.848220202 e[336m 1679e[00m 0x7fd86c012370 e[33;01mWARN e[00m e[00m decodebin gstdecodebin2.c:2325:connect_pad:<decodebin0>e[00m Couldn't set nvv4l2decoder3 to READY
0:00:02.848373583 e[336m 1679e[00m 0x7fd868013ed0 e[33;01mWARN e[00m e[00m decodebin gstdecodebin2.c:2325:connect_pad:<decodebin2>e[00m Couldn't set nvv4l2decoder1 to READY
0:00:02.848528672 e[336m 1679e[00m 0x7fd894041770 e[33;01mWARN e[00m e[00m decodebin gstdecodebin2.c:2325:connect_pad:<decodebin1>e[00m Couldn't set nvv4l2decoder2 to READY
0:00:02.848686878 e[336m 1679e[00m 0x7fd86c011cf0 e[33;01mWARN e[00m e[00m videodecoder gstvideodecoder.c:2535:gst_video_decoder_change_state:<nvv4l2decoder0>e[00m error: Failed to open decoder
0:00:02.849752989 e[336m 1679e[00m 0x7fd86c011cf0 e[33;01mWARN e[00m e[00m decodebin gstdecodebin2.c:2325:connect_pad:<decodebin3>e[00m Couldn't set nvv4l2decoder0 to READY
