Hi wayneWWW,
check spreedsheet of Jetson_Xavier_NX_Pinmux_Configuration_Template_v1.06,DP0 and DP1 is same,
Pinmux version 1.0
Input pinmux file name: tegra19x-jetson_xavier_nx_module-pinmux.dtsi
Input gpio file name: tegra19x-jetson_xavier_nx_module-gpio-default.dtsi
Generation date: 2020-08-31 10:02
PLEASE DO NOT EDIT THIS FILE
This is autogenerated file using the script pinmux-dts2cfg.py
pinmux.major = 1;
pinmux.minor = 0;
Pinmux for gpio-input pins
pinmux.0x022136e0 = 0x00000001; # CONFIG S7
pinmux.0x02431008 = 0x00000000; # GPIO soc_gpio32_ps7
pinmux.0x02214000 = 0x00000001; # CONFIG G0
pinmux.0x02434058 = 0x00000000; # GPIO soc_gpio00_pg0
pinmux.0x02214080 = 0x00000001; # CONFIG G4
pinmux.0x02434070 = 0x00000000; # GPIO soc_gpio08_pg4
pinmux.0x022140e0 = 0x00000001; # CONFIG G7
pinmux.0x02434088 = 0x00000000; # GPIO soc_gpio11_pg7
pinmux.0x02214260 = 0x00000001; # CONFIG H3
pinmux.0x02434038 = 0x00000000; # GPIO uart4_tx_ph3
pinmux.0x022142a0 = 0x00000001; # CONFIG H5
pinmux.0x02434028 = 0x00000000; # GPIO uart4_rts_ph5
pinmux.0x02212200 = 0x00000001; # CONFIG Y0
pinmux.0x0243d048 = 0x00000000; # GPIO spi3_sck_py0
pinmux.0x02212220 = 0x00000001; # CONFIG Y1
pinmux.0x0243d008 = 0x00000000; # GPIO spi3_miso_py1
pinmux.0x02212240 = 0x00000001; # CONFIG Y2
pinmux.0x0243d060 = 0x00000000; # GPIO spi3_mosi_py2
pinmux.0x02212260 = 0x00000001; # CONFIG Y3
pinmux.0x0243d018 = 0x00000000; # GPIO spi3_cs0_py3
pinmux.0x02212280 = 0x00000001; # CONFIG Y4
pinmux.0x0243d028 = 0x00000000; # GPIO spi3_cs1_py4
pinmux.0x022122a0 = 0x00000001; # CONFIG Y5
pinmux.0x0243d098 = 0x00000000; # GPIO uart5_tx_py5
pinmux.0x022122e0 = 0x00000001; # CONFIG Y7
pinmux.0x0243d0a0 = 0x00000000; # GPIO uart5_rts_py7
pinmux.0x02212420 = 0x00000001; # CONFIG Z1
pinmux.0x0243d0b0 = 0x00000000; # GPIO usb_vbus_en0_pz1
pinmux.0x02212460 = 0x00000001; # CONFIG Z3
pinmux.0x0243d040 = 0x00000000; # GPIO spi1_sck_pz3
pinmux.0x02212480 = 0x00000001; # CONFIG Z4
pinmux.0x0243d020 = 0x00000000; # GPIO spi1_miso_pz4
pinmux.0x022124a0 = 0x00000001; # CONFIG Z5
pinmux.0x0243d058 = 0x00000000; # GPIO spi1_mosi_pz5
pinmux.0x022124c0 = 0x00000001; # CONFIG Z6
pinmux.0x0243d010 = 0x00000000; # GPIO spi1_cs0_pz6
pinmux.0x022124e0 = 0x00000001; # CONFIG Z7
pinmux.0x0243d050 = 0x00000000; # GPIO spi1_cs1_pz7
pinmux.0x0c2f1000 = 0x00000001; # CONFIG EE0
pinmux.0x0c301010 = 0x00000000; # GPIO safe_state_pee0
pinmux.0x0c2f1080 = 0x00000001; # CONFIG EE4
pinmux.0x0c301038 = 0x00000000; # GPIO power_on_pee4
pinmux.0x0c2f1280 = 0x00000001; # CONFIG CC4
pinmux.0x0c302000 = 0x00000000; # GPIO touch_clk_pcc4
pinmux.0x02212c20 = 0x00000001; # CONFIG Q1
pinmux.0x02430058 = 0x00000000; # GPIO soc_gpio21_pq1
pinmux.0x02212c60 = 0x00000001; # CONFIG Q3
pinmux.0x02430068 = 0x00000000; # GPIO soc_gpio23_pq3
pinmux.0x02212ca0 = 0x00000001; # CONFIG Q5
pinmux.0x02430028 = 0x00000000; # GPIO soc_gpio41_pq5
pinmux.0x02212cc0 = 0x00000001; # CONFIG Q6
pinmux.0x02430030 = 0x00000000; # GPIO soc_gpio42_pq6
pinmux.0x02212e00 = 0x00000001; # CONFIG R0
pinmux.0x02430040 = 0x00000000; # GPIO soc_gpio44_pr0
pinmux.0x02212e80 = 0x00000001; # CONFIG R4
pinmux.0x02430098 = 0x00000000; # GPIO uart1_rts_pr4
pinmux.0x02212ea0 = 0x00000001; # CONFIG R5
pinmux.0x02430090 = 0x00000000; # GPIO uart1_cts_pr5
pinmux.0x02213240 = 0x00000001; # CONFIG L2
pinmux.0x02437008 = 0x00000000; # GPIO pex_wake_n_pl2
pinmux.0x02212820 = 0x00000001; # CONFIG N1
pinmux.0x02440020 = 0x00000000; # GPIO soc_gpio54_pn1
Pinmux for gpio-output-low pins
pinmux.0x02214040 = 0x00000003; # CONFIG G2
pinmux.0x0221404c = 0x00000000; # CONTROL G2
pinmux.0x02214050 = 0x00000000; # OUTPUT G2
pinmux.0x02434048 = 0x00000000; # GPIO soc_gpio02_pg2
pinmux.0x02212000 = 0x00000003; # CONFIG X0
pinmux.0x0221200c = 0x00000000; # CONTROL X0
pinmux.0x02212010 = 0x00000000; # OUTPUT X0
pinmux.0x0243d000 = 0x00000000; # GPIO gpu_pwr_req_px0
pinmux.0x0c2f16a0 = 0x00000003; # CONFIG AA5
pinmux.0x0c2f16ac = 0x00000000; # CONTROL AA5
pinmux.0x0c2f16b0 = 0x00000000; # OUTPUT AA5
pinmux.0x0c303028 = 0x00000000; # GPIO can0_en_paa5
pinmux.0x0c2f1200 = 0x00000003; # CONFIG CC0
pinmux.0x0c2f120c = 0x00000000; # CONTROL CC0
pinmux.0x0c2f1210 = 0x00000000; # OUTPUT CC0
pinmux.0x0c302048 = 0x00000000; # GPIO spi2_sck_pcc0
pinmux.0x0c2f1240 = 0x00000003; # CONFIG CC2
pinmux.0x0c2f124c = 0x00000000; # CONTROL CC2
pinmux.0x0c2f1250 = 0x00000000; # OUTPUT CC2
pinmux.0x0c302028 = 0x00000000; # GPIO spi2_mosi_pcc2
pinmux.0x0c2f1260 = 0x00000003; # CONFIG CC3
pinmux.0x0c2f126c = 0x00000000; # CONTROL CC3
pinmux.0x0c2f1270 = 0x00000000; # OUTPUT CC3
pinmux.0x0c302038 = 0x00000000; # GPIO spi2_cs0_pcc3
pinmux.0x02212a80 = 0x00000003; # CONFIG P4
pinmux.0x02212a8c = 0x00000000; # CONTROL P4
pinmux.0x02212a90 = 0x00000000; # OUTPUT P4
pinmux.0x02430070 = 0x00000000; # GPIO soc_gpio04_pp4
pinmux.0x02212aa0 = 0x00000003; # CONFIG P5
pinmux.0x02212aac = 0x00000000; # CONTROL P5
pinmux.0x02212ab0 = 0x00000000; # OUTPUT P5
pinmux.0x02430078 = 0x00000000; # GPIO soc_gpio05_pp5
pinmux.0x02214e00 = 0x00000003; # CONFIG B0
pinmux.0x02214e0c = 0x00000000; # CONTROL B0
pinmux.0x02214e10 = 0x00000000; # OUTPUT B0
pinmux.0x02446008 = 0x00000000; # GPIO cpu_pwr_req_0_pb0
Pinmux for gpio-output-high pins
pinmux.0x0c2f1220 = 0x00000003; # CONFIG CC1
pinmux.0x0c2f122c = 0x00000000; # CONTROL CC1
pinmux.0x0c2f1230 = 0x00000001; # OUTPUT CC1
pinmux.0x0c302050 = 0x00000000; # GPIO spi2_miso_pcc1
Pinmux for used pins
pinmux.0x02431020 = 0x00000400; # aud_mclk_ps4: aud, tristate-disable, input-disable, lpdr-disable
pinmux.0x02431060 = 0x00000440; # dap3_sclk_pt1: i2s3, tristate-disable, input-enable, lpdr-disable
pinmux.0x02431058 = 0x00000400; # dap3_dout_pt2: i2s3, tristate-disable, input-disable, lpdr-disable
pinmux.0x02431050 = 0x00000450; # dap3_din_pt3: i2s3, tristate-enable, input-enable, lpdr-disable
pinmux.0x02431048 = 0x00000440; # dap3_fs_pt4: i2s3, tristate-disable, input-enable, lpdr-disable
pinmux.0x02431080 = 0x00000440; # dap5_sclk_pt5: i2s5, tristate-disable, input-enable, lpdr-disable
pinmux.0x02431078 = 0x00000400; # dap5_dout_pt6: i2s5, tristate-disable, input-disable, lpdr-disable
pinmux.0x02431070 = 0x00000450; # dap5_din_pt7: i2s5, tristate-enable, input-enable, lpdr-disable
pinmux.0x02431068 = 0x00000440; # dap5_fs_pu0: i2s5, tristate-disable, input-enable, lpdr-disable
pinmux.0x02438000 = 0x0000a460; # sdmmc1_clk_pj0: sdmmc1, tristate-disable, input-enable, loopback-enable
pinmux.0x02438008 = 0x0000a448; # sdmmc1_cmd_pj1: sdmmc1, pull-up, tristate-disable, input-enable
pinmux.0x02438030 = 0x0000a448; # sdmmc1_dat0_pj2: sdmmc1, pull-up, tristate-disable, input-enable
pinmux.0x02438028 = 0x0000a448; # sdmmc1_dat1_pj3: sdmmc1, pull-up, tristate-disable, input-enable
pinmux.0x02438020 = 0x0000a448; # sdmmc1_dat2_pj4: sdmmc1, pull-up, tristate-disable, input-enable
pinmux.0x02438018 = 0x0000a448; # sdmmc1_dat3_pj5: sdmmc1, pull-up, tristate-disable, input-enable
pinmux.0x0243a030 = 0x0000a460; # sdmmc3_clk_po0: sdmmc3, tristate-disable, input-enable, loopback-enable
pinmux.0x0243a028 = 0x0000a448; # sdmmc3_cmd_po1: sdmmc3, pull-up, tristate-disable, input-enable
pinmux.0x0243a018 = 0x0000a448; # sdmmc3_dat0_po2: sdmmc3, pull-up, tristate-disable, input-enable
pinmux.0x0243a010 = 0x0000a448; # sdmmc3_dat1_po3: sdmmc3, pull-up, tristate-disable, input-enable
pinmux.0x0243a008 = 0x0000a448; # sdmmc3_dat2_po4: sdmmc3, pull-up, tristate-disable, input-enable
pinmux.0x0243a000 = 0x0000a448; # sdmmc3_dat3_po5: sdmmc3, pull-up, tristate-disable, input-enable
pinmux.0x02445058 = 0x00022400; # eqos_txc_pe0: eqos, tristate-disable, input-disable
pinmux.0x02445018 = 0x00022400; # eqos_td0_pe1: eqos, tristate-disable, input-disable
pinmux.0x02445010 = 0x00022400; # eqos_td1_pe2: eqos, tristate-disable, input-disable
pinmux.0x02445008 = 0x00022400; # eqos_td2_pe3: eqos, tristate-disable, input-disable
pinmux.0x02445000 = 0x00022400; # eqos_td3_pe4: eqos, tristate-disable, input-disable
pinmux.0x02445068 = 0x00022400; # eqos_tx_ctl_pe5: eqos, tristate-disable, input-disable
pinmux.0x02445040 = 0x00022450; # eqos_rd0_pe6: eqos, tristate-enable, input-enable
pinmux.0x02445030 = 0x00022450; # eqos_rd1_pe7: eqos, tristate-enable, input-enable
pinmux.0x02445028 = 0x00022450; # eqos_rd2_pf0: eqos, tristate-enable, input-enable
pinmux.0x02445020 = 0x00022470; # eqos_rd3_pf1: eqos, tristate-enable, input-enable
pinmux.0x02445070 = 0x00022450; # eqos_rx_ctl_pf2: eqos, tristate-enable, input-enable
pinmux.0x02445060 = 0x00022450; # eqos_rxc_pf3: eqos, tristate-enable, input-enable
pinmux.0x02445038 = 0x00022440; # eqos_sma_mdio_pf4: eqos, tristate-disable, input-enable
pinmux.0x02445048 = 0x00022400; # eqos_sma_mdc_pf5: eqos, tristate-disable, input-disable
pinmux.0x0243b020 = 0x00023460; # qspi0_sck_pc0: qspi0, tristate-disable, input-enable, loopback-enable
pinmux.0x0243b028 = 0x00023400; # qspi0_cs_n_pc1: qspi0, tristate-disable, input-disable
pinmux.0x0243b018 = 0x00023440; # qspi0_io0_pc2: qspi0, tristate-disable, input-enable
pinmux.0x0243b010 = 0x00023440; # qspi0_io1_pc3: qspi0, tristate-disable, input-enable
pinmux.0x0243b008 = 0x00023440; # qspi0_io2_pc4: qspi0, tristate-disable, input-enable
pinmux.0x0243b000 = 0x00023440; # qspi0_io3_pc5: qspi0, tristate-disable, input-enable
pinmux.0x02436008 = 0x00002460; # sdmmc4_clk: sdmmc4, tristate-disable, input-enable, loopback-enable
pinmux.0x02436010 = 0x00002440; # sdmmc4_cmd: sdmmc4, tristate-disable, input-enable
pinmux.0x02436058 = 0x00002448; # sdmmc4_dat0: sdmmc4, pull-up, tristate-disable, input-enable
pinmux.0x02436050 = 0x00002448; # sdmmc4_dat1: sdmmc4, pull-up, tristate-disable, input-enable
pinmux.0x02436048 = 0x00002448; # sdmmc4_dat2: sdmmc4, pull-up, tristate-disable, input-enable
pinmux.0x02436040 = 0x00002448; # sdmmc4_dat3: sdmmc4, pull-up, tristate-disable, input-enable
pinmux.0x02436038 = 0x00002448; # sdmmc4_dat4: sdmmc4, pull-up, tristate-disable, input-enable
pinmux.0x02436030 = 0x00002448; # sdmmc4_dat5: sdmmc4, pull-up, tristate-disable, input-enable
pinmux.0x02436028 = 0x00002448; # sdmmc4_dat6: sdmmc4, pull-up, tristate-disable, input-enable
pinmux.0x02436020 = 0x00002448; # sdmmc4_dat7: sdmmc4, pull-up, tristate-disable, input-enable
pinmux.0x02436018 = 0x00000450; # sdmmc4_dqs: sdmmc4, tristate-enable, input-enable
pinmux.0x02434080 = 0x00000410; # soc_gpio10_pg6: gp, tristate-enable, input-disable, lpdr-disable
pinmux.0x02434098 = 0x00000401; # soc_gpio13_ph1: gp, tristate-disable, input-disable, lpdr-disable
pinmux.0x02434060 = 0x00000540; # gen1_i2c_scl_pi3: i2c1, tristate-disable, input-enable, io_high_voltage-disable, lpdr-enable
pinmux.0x02434068 = 0x00000540; # gen1_i2c_sda_pi4: i2c1, tristate-disable, input-enable, io_high_voltage-disable, lpdr-enable
pinmux.0x0243d038 = 0x00000410; # gp_pwm2_px2: gp, tristate-enable, input-disable, lpdr-disable
pinmux.0x0243d070 = 0x00000400; # uart2_tx_px4: uartb, tristate-disable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x0243d078 = 0x00000450; # uart2_rx_px5: uartb, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x0243d080 = 0x00000408; # uart2_rts_px6: uartb, pull-up, tristate-disable, input-disable, lpdr-disable
pinmux.0x0243d088 = 0x00000458; # uart2_cts_px7: uartb, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x0c301000 = 0x00000400; # shutdown_n: shutdown, tristate-disable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c301018 = 0x00000458; # vcomp_alert_pee1: soc, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x0c301040 = 0x00000440; # pwr_i2c_scl_pee5: i2c5, tristate-disable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c301048 = 0x00000440; # pwr_i2c_sda_pee6: i2c5, tristate-disable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c301028 = 0x00000458; # batt_oc_pee3: soc, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x0c303010 = 0x0000c400; # can0_dout_paa2: can0, tristate-disable, input-disable
pinmux.0x0c303018 = 0x0000c450; # can0_din_paa3: can0, tristate-enable, input-enable
pinmux.0x0c302010 = 0x00000400; # uart3_tx_pcc5: uartc, tristate-disable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c302008 = 0x00000450; # uart3_rx_pcc6: uartc, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c302030 = 0x00000560; # gen2_i2c_scl_pcc7: i2c2, tristate-disable, input-enable, io_high_voltage-enable, lpdr-enable
pinmux.0x0c302040 = 0x00000560; # gen2_i2c_sda_pdd0: i2c2, tristate-disable, input-enable, io_high_voltage-enable, lpdr-enable
pinmux.0x0c302020 = 0x00000560; # gen8_i2c_scl_pdd1: i2c8, tristate-disable, input-enable, io_high_voltage-enable, lpdr-enable
pinmux.0x0c302018 = 0x00000560; # gen8_i2c_sda_pdd2: i2c8, tristate-disable, input-enable, io_high_voltage-enable, lpdr-enable
pinmux.0x02430008 = 0x00000400; # extperiph1_clk_pp0: extperiph1, tristate-disable, input-disable, lpdr-disable
pinmux.0x02430000 = 0x00000400; # extperiph2_clk_pp1: extperiph2, tristate-disable, input-disable, lpdr-disable
pinmux.0x02430018 = 0x00000460; # cam_i2c_scl_pp2: i2c3, tristate-disable, input-enable, io_high_voltage-enable, lpdr-disable
pinmux.0x02430010 = 0x00000460; # cam_i2c_sda_pp3: i2c3, tristate-disable, input-enable, io_high_voltage-enable, lpdr-disable
pinmux.0x02430088 = 0x0000045a; # soc_gpio07_pp7: soc, pull-up, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x02430060 = 0x00000459; # soc_gpio22_pq2: nv, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x024300a8 = 0x00000400; # uart1_tx_pr2: uarta, tristate-disable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x024300a0 = 0x00000454; # uart1_rx_pr3: uarta, pull-down, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x02437048 = 0x00000560; # pex_l4_clkreq_n_pl0: pe4, tristate-disable, input-enable, io_high_voltage-enable, lpdr-enable
pinmux.0x02437050 = 0x00000520; # pex_l4_rst_n_pl1: pe4, tristate-disable, input-disable, io_high_voltage-enable, lpdr-enable
pinmux.0x02440030 = 0x00000450; # dp_aux_ch0_hpd_pm0: dp, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x02440038 = 0x00000450; # dp_aux_ch1_hpd_pm1: dp, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x02440050 = 0x00000460; # hdmi_cec_pm4: hdmi, tristate-disable, input-enable, io_high_voltage-enable, lpdr-disable
pinmux.0x02431008 = 0x00000058; # soc_gpio32_ps7: rsvd0, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x02434058 = 0x00000058; # soc_gpio00_pg0: rsvd0, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x02434048 = 0x00000000; # soc_gpio02_pg2: rsvd0, tristate-disable, input-disable, lpdr-disable
pinmux.0x02434070 = 0x00000050; # soc_gpio08_pg4: rsvd0, tristate-enable, input-enable, lpdr-disable
pinmux.0x02434088 = 0x00000058; # soc_gpio11_pg7: rsvd0, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x02434038 = 0x00000051; # uart4_tx_ph3: rsvd1, tristate-enable, input-enable, lpdr-disable
pinmux.0x02434028 = 0x00000051; # uart4_rts_ph5: rsvd1, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d000 = 0x00000000; # gpu_pwr_req_px0: rsvd0, tristate-disable, input-disable, lpdr-disable
pinmux.0x0243d048 = 0x00000055; # spi3_sck_py0: rsvd1, pull-down, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x0243d008 = 0x00000055; # spi3_miso_py1: rsvd1, pull-down, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x0243d060 = 0x00000055; # spi3_mosi_py2: rsvd1, pull-down, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x0243d018 = 0x00000055; # spi3_cs0_py3: rsvd1, pull-down, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x0243d028 = 0x00000055; # spi3_cs1_py4: rsvd1, pull-down, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x0243d098 = 0x00000051; # uart5_tx_py5: rsvd1, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d0a0 = 0x00000051; # uart5_rts_py7: rsvd1, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d0b0 = 0x00000049; # usb_vbus_en0_pz1: rsvd1, pull-up, tristate-disable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x0243d040 = 0x00000055; # spi1_sck_pz3: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d020 = 0x00000055; # spi1_miso_pz4: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d058 = 0x00000055; # spi1_mosi_pz5: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d010 = 0x00000059; # spi1_cs0_pz6: rsvd1, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d050 = 0x00000059; # spi1_cs1_pz7: rsvd1, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x0c301010 = 0x00000051; # safe_state_pee0: rsvd1, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c301038 = 0x00000058; # power_on_pee4: rsvd0, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x0c303028 = 0x0000c000; # can0_en_paa5: rsvd0, tristate-disable, input-disable
pinmux.0x0c302048 = 0x00000002; # spi2_sck_pcc0: rsvd2, tristate-disable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c302050 = 0x00000002; # spi2_miso_pcc1: rsvd2, tristate-disable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c302028 = 0x00000002; # spi2_mosi_pcc2: rsvd2, tristate-disable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c302038 = 0x00000002; # spi2_cs0_pcc3: rsvd2, tristate-disable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c302000 = 0x00000056; # touch_clk_pcc4: rsvd2, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x02430070 = 0x00000000; # soc_gpio04_pp4: rsvd0, tristate-disable, input-disable, lpdr-disable
pinmux.0x02430078 = 0x00000000; # soc_gpio05_pp5: rsvd0, tristate-disable, input-disable, lpdr-disable
pinmux.0x02430058 = 0x00000054; # soc_gpio21_pq1: rsvd0, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x02430068 = 0x00000058; # soc_gpio23_pq3: rsvd0, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x02430020 = 0x00000426; # soc_gpio40_pq4: rsvd2, pull-down, tristate-disable, input-disable, io_high_voltage-enable, lpdr-disable
pinmux.0x02430028 = 0x0000005a; # soc_gpio41_pq5: rsvd2, pull-up, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x02430030 = 0x0000005a; # soc_gpio42_pq6: rsvd2, pull-up, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x02430038 = 0x00000426; # soc_gpio43_pq7: rsvd2, pull-down, tristate-disable, input-disable, io_high_voltage-enable, lpdr-disable
pinmux.0x02430040 = 0x00000056; # soc_gpio44_pr0: rsvd2, pull-down, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x02430048 = 0x00000431; # soc_gpio45_pr1: rsvd1, tristate-enable, input-disable, io_high_voltage-enable, lpdr-disable
pinmux.0x02430098 = 0x00000055; # uart1_rts_pr4: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x02430090 = 0x00000055; # uart1_cts_pr5: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x02446008 = 0x00000000; # cpu_pwr_req_0_pb0: rsvd0, tristate-disable, input-disable, lpdr-disable
pinmux.0x02437008 = 0x00000178; # pex_wake_n_pl2: rsvd0, pull-up, tristate-enable, input-enable, io_high_voltage-enable, lpdr-enable
pinmux.0x02440020 = 0x00000058; # soc_gpio54_pn1: rsvd0, pull-up, tristate-enable, input-enable, lpdr-disable
Pinmux for unused pins for low-power configuration
pinmux.0x02431040 = 0x00000415; # dap1_sclk_ps0: rsvd1, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02431038 = 0x00000415; # dap1_dout_ps1: rsvd1, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02431030 = 0x00000415; # dap1_din_ps2: rsvd1, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02431028 = 0x00000415; # dap1_fs_ps3: rsvd1, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02431018 = 0x00000414; # soc_gpio30_ps5: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02431010 = 0x00000414; # soc_gpio31_ps6: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02431000 = 0x00000414; # soc_gpio33_pt0: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x0243b050 = 0x00023435; # qspi1_sck_pc6: rsvd1, pull-down, tristate-enable, input-disable, loopback-enable
pinmux.0x0243b058 = 0x00023415; # qspi1_cs_n_pc7: rsvd1, pull-down, tristate-enable, input-disable
pinmux.0x0243b048 = 0x00023415; # qspi1_io0_pd0: rsvd1, pull-down, tristate-enable, input-disable
pinmux.0x0243b040 = 0x00023415; # qspi1_io1_pd1: rsvd1, pull-down, tristate-enable, input-disable
pinmux.0x0243b038 = 0x00023415; # qspi1_io2_pd2: rsvd1, pull-down, tristate-enable, input-disable
pinmux.0x0243b030 = 0x00023415; # qspi1_io3_pd3: rsvd1, pull-down, tristate-enable, input-disable
pinmux.0x02434050 = 0x00000414; # soc_gpio01_pg1: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02434040 = 0x00000414; # soc_gpio03_pg3: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02434078 = 0x00000414; # soc_gpio09_pg5: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02434090 = 0x00000414; # soc_gpio12_ph0: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x024340a0 = 0x00000414; # soc_gpio14_ph2: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02434030 = 0x00000415; # uart4_rx_ph4: rsvd1, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02434020 = 0x00000415; # uart4_cts_ph6: rsvd1, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02434018 = 0x00000415; # dap2_sclk_ph7: rsvd1, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02434008 = 0x00000415; # dap2_dout_pi0: rsvd1, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02434000 = 0x00000415; # dap2_din_pi1: rsvd1, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02434010 = 0x00000415; # dap2_fs_pi2: rsvd1, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x0243d068 = 0x00000414; # cv_pwr_req_px1: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x0243d030 = 0x00000415; # gp_pwm3_px3: rsvd1, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x0243d090 = 0x00000415; # uart5_rx_py6: rsvd1, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x0243d0a8 = 0x00000415; # uart5_cts_pz0: rsvd1, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x0243d0b8 = 0x00000415; # usb_vbus_en1_pz2: rsvd1, pull-down, tristate-enable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c301060 = 0x00000415; # ao_retention_n_pee2: rsvd1, pull-down, tristate-enable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c303000 = 0x0000c415; # can1_dout_paa0: rsvd1, pull-down, tristate-enable, input-disable
pinmux.0x0c303008 = 0x0000c415; # can1_din_paa1: rsvd1, pull-down, tristate-enable, input-disable
pinmux.0x0c303020 = 0x0000c414; # can0_stb_paa4: rsvd0, pull-down, tristate-enable, input-disable
pinmux.0x0c303030 = 0x0000c414; # can0_wake_paa6: rsvd0, pull-down, tristate-enable, input-disable
pinmux.0x0c303038 = 0x0000c414; # can0_err_paa7: rsvd0, pull-down, tristate-enable, input-disable
pinmux.0x0c303040 = 0x0000c414; # can1_stb_pbb0: rsvd0, pull-down, tristate-enable, input-disable
pinmux.0x0c303048 = 0x0000c414; # can1_en_pbb1: rsvd0, pull-down, tristate-enable, input-disable
pinmux.0x0c303050 = 0x0000c414; # can1_wake_pbb2: rsvd0, pull-down, tristate-enable, input-disable
pinmux.0x0c303058 = 0x0000c414; # can1_err_pbb3: rsvd0, pull-down, tristate-enable, input-disable
pinmux.0x02430080 = 0x00000414; # soc_gpio06_pp6: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02430050 = 0x00000414; # soc_gpio20_pq0: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02432018 = 0x0000c416; # dap6_sclk_pa0: rsvd2, pull-down, tristate-enable, input-disable
pinmux.0x02432010 = 0x0000c416; # dap6_dout_pa1: rsvd2, pull-down, tristate-enable, input-disable
pinmux.0x02432008 = 0x0000c416; # dap6_din_pa2: rsvd2, pull-down, tristate-enable, input-disable
pinmux.0x02432000 = 0x0000c416; # dap6_fs_pa3: rsvd2, pull-down, tristate-enable, input-disable
pinmux.0x02432038 = 0x0000c416; # dap4_sclk_pa4: rsvd2, pull-down, tristate-enable, input-disable
pinmux.0x02432030 = 0x0000c416; # dap4_dout_pa5: rsvd2, pull-down, tristate-enable, input-disable
pinmux.0x02432028 = 0x0000c416; # dap4_din_pa6: rsvd2, pull-down, tristate-enable, input-disable
pinmux.0x02432020 = 0x0000c416; # dap4_fs_pa7: rsvd2, pull-down, tristate-enable, input-disable
pinmux.0x02446000 = 0x00000414; # cpu_pwr_req_1_pb1: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02441008 = 0x00022435; # ufs0_ref_clk_pff0: rsvd1, pull-down, tristate-enable, input-disable
pinmux.0x02441000 = 0x00022435; # ufs0_rst_pff1: rsvd1, pull-down, tristate-enable, input-disable
pinmux.0x02437020 = 0x00000415; # pex_l0_clkreq_n_pk0: rsvd1, pull-down, tristate-enable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x02437028 = 0x00000415; # pex_l0_rst_n_pk1: rsvd1, pull-down, tristate-enable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x02437010 = 0x00000415; # pex_l1_clkreq_n_pk2: rsvd1, pull-down, tristate-enable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x02437018 = 0x00000415; # pex_l1_rst_n_pk3: rsvd1, pull-down, tristate-enable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x02437000 = 0x00000415; # pex_l2_clkreq_n_pk4: rsvd1, pull-down, tristate-enable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x02437030 = 0x00000415; # pex_l2_rst_n_pk5: rsvd1, pull-down, tristate-enable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x02437038 = 0x00000415; # pex_l3_clkreq_n_pk6: rsvd1, pull-down, tristate-enable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x02437040 = 0x00000415; # pex_l3_rst_n_pk7: rsvd1, pull-down, tristate-enable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x02437058 = 0x00000415; # sata_dev_slp_pl3: rsvd1, pull-down, tristate-enable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x02440040 = 0x00000416; # dp_aux_ch2_hpd_pm2: rsvd2, pull-down, tristate-enable, input-disable, io_high_voltage-disable
pinmux.0x02440048 = 0x00000416; # dp_aux_ch3_hpd_pm3: rsvd2, pull-down, tristate-enable, input-disable, io_high_voltage-disable
pinmux.0x02440000 = 0x00000414; # soc_gpio50_pm5: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02440008 = 0x00000414; # soc_gpio51_pm6: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02440010 = 0x00000414; # soc_gpio52_pm7: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02440018 = 0x00000414; # soc_gpio53_pn0: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
pinmux.0x02440028 = 0x00000414; # soc_gpio55_pn2: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
