Hi I have been trying to add moving human using omni.anim.people in my code using the Pythonapi and I can perfectly animate people in non-headless mode. But as soon as I turned to headless mode, when I tried to read the position of the humans, it appears that the human never moves.
from omni.anim.people.scripts.utils import Utils
Utils.get_character_transform(character)
I have already this in my headless kit file:
"omni.anim.graph.core" = { version = "106.1.2" }
"omni.anim.people" = { version = "0.5.0" }
Hi thank you for responding! I have seen this, but the warnings appear both in headless and non-headless mode, I will create a script to reproduce my case and post here again. Just FYI, I am using IsaacSim 4.2.0 and I have installed IsaacSim once last year in December. Animation with that old installation works well even in headless mode and I have reinstalled IsaacSim last week and the animation does not work any more.
2025-06-18 08:45:17 [5,303ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
2025-06-18 08:45:17 [5,676ms] [Warning] [omni.graph.core._impl._registration.register_python_ogn] Python import process in omni.anim.graph.core failed - ‘NoneType’ object is not subscriptable. Aborting Python node registration
2025-06-18 08:45:20 [8,994ms] [Warning] [pxr.AnimGraphSchema] pxr.AnimGraphSchema is deprecated - please use AnimGraphSchema instead
Yes, animation in headless mode is supported. However, the message “Aborting Python node registration” looks suspicious and may indicate that the AnimGraph/extension stack is not being initialized correctly. Could you please share a minimal reproduction script and the exact Isaac Sim version/config you are using? That would help us investigate.
Also note that omni.anim.people is being deprecated. For any new work, please migrate to Isaacsim.Replicator.Agent / IRA.
