[Omni.Anim.People] I can't find the animation graph
I can’t find the animation graph. Isaac Sim 4.2.0, Windows 11 environment. It’s different from the example. Could it be due to an update?
https://docs.omniverse.nvidia.com/isaacsim/latest/features/warehouse_logistics/ext_omni_anim_people.html#manually-setup-characters
Hey @aiden_kim thanks for bringing this issue up! I am able to replicate it.
I found a workaround for it.
  • Follow this tutorial to enable all three extensions (you can make them auto-load)
  • Click on Window → Animation → Animation Graph . Then at the Animation Graph UI, click on New Animation Graph
  • Specify your path (you can select from stage) and then click Create
Now you should have an animation graph that you can edit.
Hi @aiden_kim , thanks for reaching out!
Please make sure you have the anim graph extension suite enabled:
  • omni.anim.graph.core
  • omni.anim.graph.ui
  • omni.anim.graph.schema
