AnimationGraph does not work with Standalone Python
I faced following problem. Is there any solutions?
problem
AnimationGraph does not work only in Standalone Python.
Workflow Result
Script Editor work
Extension work
Standalone Python NOT work
  • Character does not change from “T-pose” to expected animation
  • ag.get_character(skel_root_prim) return None (got a warning like below)
[Warning] [omni.anim.graph.core.plugin] getCharacter - biped_demo is not a SkelRoot prim or does not apply AnimationGraphAPI
environment
I tested in 3 environments.
  • Isaac Sim version 2023.1.1
  • Ubuntu 22.04(RTX 3090), Windows10(RTX 4090), Windows11(RTX 4060 laptop)
reproducible steps
  1. run python script
    (script enables omni.anim.graph.bundle extension)
$ isaac_sim-2023.1.1/python.sh minimum.py
minimum.py
from carb import log_info
from omni.isaac.kit import SimulationApp
sim_app = SimulationApp(launch_config={"headless": False})
log_info('loading omni.anim.graph.bundle extension')
from omni.isaac.core.utils.extensions import enable_extension
enable_extension('omni.anim.graph.bundle')
from omni.isaac.core import SimulationContext
from omni.isaac.core.utils.stage import is_stage_loading
sim_context = SimulationContext()
log_info('wait for loading')
sim_app.update()
while is_stage_loading():
    sim_app.update()
log_info('begin to play physics')
sim_context.initialize_physics()
sim_context.play()
log_info('enter event loop')
while sim_app.is_running():
    sim_context.step(render=True)
log_info('closing app')
sim_context.stop()
sim_app.close()
  1. Stop simulation
    push stop button to stop physics simulation
step 3 has two cases
Case1 add AnimationGraph manually
3-a. add character to Stage
I used omniverse://localhost/NVIDIA/Assets/AnimGraph/Characters/NVIDIA/biped_demo.usd.
3-b. add AnimationGraph to Stage
I created a graph that just outputs single animation.
I used omniverse://localhost/NVIDIA/Assets/AnimGraph/Animations/NVIDIA/biped_demo/stand_idle_loop.skelanim.usd as an Animation.
3-c. setup relation to SkelRoot
I made relation from AnimationGraph to SkelRoot.
Case2 add USD which has already applied AnimationGraph
3-1. add Biped_Setup.usd to Stage
I used omniverse://localhost/NVIDIA/Assets/Isaac/4.0/Isaac/People/Characters/Biped_Setup.usd.
  1. Play simulation again
Hi, have you found the solution for this problem
For anyone else running into this issue, try to add
“omni.anim.graph.core” = {}
“omni.anim.graph.schema” = {}
in your [isaacsim_folder]/apps/isaacsim.exp.base.python.kit file, similar to People animations in Standalone App - #10 by 555kd
If you are using IsaacLab, then add the same two lines to isaaclab.python.kit in [isaacLab_path]/apps folder.
