I was trying out this (Part Three: Create Your Own Nodes — Omniverse Extensions latest documentation) tutorial worked fine. When I restart the Isaac Sim application, the node in has gone missing.
Terminal says, “2023-12-22 04:57:19 [649,330ms] [Warning] [omni.graph.core.plugin] Could not find node type interface for ‘omni.new.extension_test04.NegateDouble’”.
I have checked the extension path and it is listed as a location where Isaac look for extensions.
Pls help. Thank you.
@ruk.shan i am just another user, is the extension already set to autoload (indicated by #5)?
yes. That was the issue. Thank you so much.
