Omniverse Streaming Client does not work on my school network but works when I use my phone hotspot
Hi, Brandon here. Currently, I am using an AWS EC2 Nvidia Optimized AMI Instance to run Isaac Sim and Isaac Lab. I am able to run the scripts on the instance via ssh for Isaac Sim and Lab but when I want to view the window using the omniverse streaming client, it only work when I use my phone hotspot and not on my university’s wifi network. The output of the kit-remote.log file for when I try to launch the Omniverse Streaming Client is as such:
[2024-07-19 09:04:13,787]=17:04:13= DEBUG [Geronimo: GeronimoRemoteConfig] {2AE3B140} - Cannot open config file RemoteConfig.json.
[2024-07-19 09:04:13,787]=17:04:13= INFO [Tracing] {2AE3B140} - Starting tracing for gfn-gamestream.
[2024-07-19 09:04:13,787]=17:04:13= INFO [OV-Streaming-Client: main] {2AE3B140} - Command line: “./kit-remote --width 1920 --height 1080 --server 13.229.200.180”
[2024-07-19 09:04:13,787]=17:04:13= INFO [OV-Streaming-Client: main] {2AE3B140} - Setting log level to ‘E’
[2024-07-19 09:04:14,150]=17:04:14= ERROR [Geronimo::Analytics] {2AE3B140} - Failed to load dll with error: /home/brandon/.local/share/ov/pkg/kit_remote-103.1.1//NvTelemetryAPI.so: cannot open shared object file: No such file or directory
[2024-07-19 09:04:14,403]=17:04:14= ERROR [BifrostClient: Streamer] {2AE3B140} - updateVideoSettingsForNVbProfile: profile 8 is not handled
[2024-07-19 09:04:14,522]=17:04:14= ERROR [NVST:RtspClient] {F2FFD640} - Failed to create the RTSP session: WebSocket Exception: Cannot upgrade to WebSocket connection: Service Unavailable
[2024-07-19 09:04:14,523]=17:04:14= ERROR [NVST:ClientSession] {F2FFD640} - Unexpectedly disconnected from server: connection creation
[2024-07-19 09:04:14,523]=17:04:14= ERROR [NVST:ClientSession] {F2FFD640} - Failed to connect to server using RTSP handshake (error codes: 0X800B1004 0X800B1004)
[2024-07-19 09:04:14,523]=17:04:14= ERROR [NVST:ClientSession] {F2FFD640} - Failed to create RTSP connection with error 0X800B1004
[2024-07-19 09:04:14,523]=17:04:14= ERROR [NVST:ClientLibraryWrapper] {F2FFD640} - Could not create initial streaming connection : 0x800b1004
[2024-07-19 09:04:14,523]=17:04:14= ERROR [BifrostClient: Streamer] {F2FFD640} - Failed to initiate connection to rtsp://13.229.200.180:48010: Error: NVST_R_ERROR_UNEXPECTED_DISCONNECTION_INITIAL (0x800b1004)
[2024-07-19 09:04:14,523]=17:04:14= ERROR [BifrostClient: Streamer] {F2FFD640} - Streamer connection failure. Error: NVST_R_ERROR_UNEXPECTED_DISCONNECTION_INITIAL (0x800b1004)
[2024-07-19 09:04:14,523]=17:04:14= ERROR [BifrostClient: SessionController] {F2FFD640} - Failed to start the streamer for session ce853913-5f78-42ce-b51f-cb8dfcff3882. Aborting the session.
[2024-07-19 09:04:14,523]=17:04:14= ERROR [RemoteGridApp] {F1FFB640} - STREAMING: FAILED: NVB_SN_STREAMING_START_FAILED (800b1004)
Could someone help me out in debugging the issue? Thank you.
Hi Brandon – sorry for the delayed response.
Looking at your log, the error points directly to the cause:
Your setup is: Isaac Sim running on the AWS EC2 instance (13.229.200.180), and the
Omniverse Streaming Client running on your local laptop connected to university WiFi.
The streaming client connects via WebRTC, which requires UDP for the media stream
(video frames travel over SRTP/UDP). Your university’s WiFi proxy passes TCP/HTTP but
silently drops UDP – which is why it works on your phone hotspot (open network) but
not on campus.
Note: the restriction is on your laptop’s side (university WiFi), not on the AWS
EC2 side. That matters for choosing the right fix.
Why the Docker Compose Web Viewer does not help here
Isaac Sim 6.x includes an official Docker Compose Web Viewer, but it does not eliminate
the UDP requirement for remote browsers. The web viewer container only serves the
HTML/JS page over TCP 8210. Once the page loads, your browser opens its own direct
WebSocket (TCP 49100) and WebRTC media stream (UDP 47998) to the Isaac Sim container –
the web viewer is out of the loop for the actual video. Both containers run with
network_mode: host, so there is no internal Docker hop that UDP could stay inside.
Your laptop still needs UDP 47998 to reach EC2, and university WiFi still blocks it.
What actually works: run the streaming client on the EC2 server itself
The fix is to run the streaming client on the EC2 instance (where UDP is unrestricted),
not on your university laptop. A community write-up for exactly this topology is here:
Running Isaac Sim on a TCP-only server (forum/386592)
The approach:
[University laptop] --TCP only--> noVNC (on EC2)
                               TurboVNC virtual desktop (on EC2)
                           Omniverse Streaming Client (on EC2)
                                 UDP loopback
                                 Isaac Sim (on EC2)
All UDP stays on the EC2 instance (loopback). Your laptop only needs one TCP port open
to reach noVNC – which university WiFi handles without issue.
Since this topic has had no activity for over two years, I am closing it now.
If you are still experiencing this issue, please open a new topic with your current
Isaac Sim version and we will be happy to help.
