which heatsink model is originally used in the Jetson Nano developer kit?
Cheers, Royden
Hi rwagnern63fr, please refer to this post for more info about the heatsink:
unfortunately I don’t have access to a CAD-programm at the moment, can you provide a link or a specific serialnumber?
Hi rwagnern63fr, the original vendor of the heatsink isn’t able to handle small orders, so it is recommended to find a suitable replacement from the CAD design. How many units were you looking to procure?
Hi all, update to this topic: you can procure the heatsink from Auvidea - [url]https://auvidea.eu/product/heatsink-for-nvidia-jetson-nano/[/url]
Also: Heat sinks are not magic.
As long as you have the right thermal contact interface (typically, a flat spot of some minimum size) and enough thickness to carry the heat gradient and enough fin surface area to radiate into the air, you’ll be fine.
Hi dusty_nv,
can you help me to solve this questions:
can you send me a data sheet and a assembly procedure of 110-0111-000
Does the heatsink already come with the “thermal grease”?
what characteristics does this material have? (there is a technical sheet where the storage characteristics are highlighted?).
thanks Riccardo
Hi @r.bilato, since you are referring to product from Auvidea, please contact them about the technical specifications.
There has also been a Nano heatsink created by ConnectTech: https://connecttech.com/product/nvidia-jetson-nano-passive-heat-sink/
