Orin Nano 8gb - No usb 3.0
Hi, i have my Orin Nano with the stock linux distro. With lsusb -t i can see :
lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 10000M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 10000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 480M
|__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 8, If 0, Class=Vendor Specific Class, Driver=cp210x, 12M
|__ Port 4: Dev 4, If 2, Class=Vendor Specific Class, Driver=, 12M
|__ Port 4: Dev 4, If 0, Class=Communications, Driver=cdc_acm, 12M
|__ Port 4: Dev 4, If 1, Class=CDC Data, Driver=cdc_acm, 12M
|__ Port 3: Dev 3, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 3: Dev 3, If 1, Class=Wireless, Driver=btusb, 12M
I mean, this show USB 3.0 on Bus 02.Port 1. But none of 4 conectors use that port. I tried to connect my device on any of the 4 ports and always uses Bus 01 (usb 2.0). Any help with it?
I’m totally stuck.
Do you use Orin Nano developer kit? If yes, please check:
Jetson Download Center | NVIDIA Developer
The four type-A ports are connected to the roothub USB1 and USBSS0.
