Orin NX 16G can't boot after update to JetPack 6.1
I have try to update my Orin NX 16G to the latest JetPack 6.1.
But when I reach the step 3 in the flash progressing. My Orin stop work(after reboot USB connection is missing).
I see some serial debug log as:
usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
I use https://www.waveshare.net/shop/JETSON-ORIN-IO-BASE.htm this carries board.
What can I do now? BTW, JetPack 5.4.1 is ok on the same hardware.
This carrier board is from vendor, you need to contact with them to know how to update your board.
