hi
We burned the BSP to the previously developed Xavier board and there was a problem,
The same happens when changing to Jetson Orin NX 16GB based developer kit P3450.
Trying to use the following USB flash drives can not be completed, the system will automatically restart after the burning process until the account password is set, and it will be stuck at “using random host ethernet address”
USB device:
Tcell 4k evo USB 3.1 128/512GB
Sandisk Extreme USB 3.0 16GB
Kingston DT KYSON DTKN/128GB
The only USB flash drive we can install is ADATA S102 64GB USB3.1.
Could you share the step to flash the board to XNX devkit?
Hi Wayne
- Install Orin NX to Xaiver developed board.
- Enter debug mode.
- Enter the L4T directory.
- Enter the command to install to the USB flash drive.
- Check the Putty result.
How did you get L4T directory?
What command?
- L4T directory download
https://developer.nvidia.com/embedded/jetson-linux-r3521 - flash command
Quick Start — Jetson Linux Developer Guide documentation
enter : $ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device sda1
-c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml”
–showlogs --network usb0 p3509-a02+p3767-0000 internal
Please let sdkmanager download the BSP folder again. This to prevent you missed some steps in your “L4T directory download”.
Hi Wayne
Choose AGX Oroin and we get the capacity that should be usable.
When can the sdkmanager GUI be used uniformly for installation?
