Orin NX 8GB module flash failed
Hello everyone,
I want to flash the Orin NX 8GB module on my carrier board. jetpack version 5.1.1, I used the command sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device sda1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --showlogs --network usb0 jetson-orin-nano-devkit external. But flash fails, The attachment are flash log and debugUSB log. Can you give me some advice on checking my carrier board? Which part of the schematic should I check?
cmdflash.log (252.5 KB)
debug_usb_log.txt (37.7 KB)
It is hard to read your uart log. (if you ever read it by yourself before sending out).
Please clean up the format and share it again.
Sorry, the attached file was not reviewed. We’re already going over the schematics. Thank you for your reply
不太清楚這邊你想說什麼, 所以這個問題還需要繼續討論嗎?
Not quite sure about what you want to tell. Is this issue still needed to check?
不用了,谢谢,我们自己先检查,请关闭这个帖子吧!
ok. 不過還是要提醒一下. 有些東西不是你們那邊硬體檢查就能修正的… 例如這個
好的。
