Orin NX freezes while trying to connect WIFI
I am trying to connect wifi using USB wifi adapter
however the jetson freezes but connection to wifi is always failing
and the board freezes
Is there any way to fix this issue?
Which JetPack SW?
With your custom carrier board?
Which USB wifi dongle?
Is there any output of dmesg when try to connect the Wifi:
JetPack SW is 5.1.1
yes Board is TL-JDK100-R03 from company tellian
and usb 2.0 dongle
would there be a problem if I connect usb2.0 dongle in usb 3.0 connector?
No, that does not matter.
You better dumping the uart log when system hang.
