Orin nx 使用mipi传输1920*1080 60fps ,从/dev/video0里取不到数据
imx482->hisi isp->mipi->orin nx,mipi传输的是rgb888,从/dev/video0里去不到数据。
dmesg:
60fps.log (69.0 KB)
dts:
kernel_tegra234-p3767-0000-p3509-a02.txt (409.1 KB)
Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
好的,谢谢。顺便问一下,我在哪里查看先关的回复。
hello user87933,
had you try updating device tree to register IMX482?
according to the logs… [ 12.502354] imx219 10-0010: board setup failed, system still trying to register default camera device (i.e. IMX219)
我更换了设备树重新抓的log,帮忙看一下,谢谢。
kernel_60fps.log (69.0 KB)
hello user87933,
it looks device has register to linux kernel.
do you have stream coming out? I don’t see any further related failures.
有用cheese查看视频流
kernel_60fps.log (80.3 KB)
there’re errors of regulator get, please also check the driver side to confirm it’s correct or not.
[ 3881.944926] hisi 9-001a: camera_common_regulator_get (null) ERR: ffffffffffffffea
[ 3881.952714] get() with no identifier
[ 3881.956457] hisi 9-001a: camera_common_regulator_get (null) ERR: ffffffffffffffea
[ 3881.964189] get() with no identifier
[ 3881.967897] hisi 9-001a: camera_common_regulator_get (null) ERR: ffffffffffffffea
