Custom hardware device: Orin NX 8G/16G
software version:JetPack 5.1.5
I need to implement multi network node link aggregation and try using MPTCP to achieve this function. I have set the following parameters in the deconfig:
CONFIG_MPTCP=y
CONFIG_INET_MPTCP_DIAG=m
CONFIG_MPTCP_IPV6=y
and then flash failed:
writing item=17, 9:0:secondary_gpt, 62545444352, 16896, gpt_secondary_9_0.bin, 16896, fixed-<reserved>-0, 03f8fee50575ac8898aaba3521757c06c4d47b34
[ 390]: l4t_flash_from_kernel: Successfully flash the external device
[ 390]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
[ 390]: l4t_flash_from_kernel: Error flashing qspi
Flash failure
Cleaning up...
There was error occurred in the startup log of orin nx 16g:
[ 12.351099] nvmap: disagrees about version of symbol dev_set_name
[ 12.358634] nvmap: Unknown symbol dev_set_name (err -22)
[ 12.364119] nvmap: disagrees about version of symbol sched_set_normal
[ 12.370752] nvmap: Unknown symbol sched_set_normal (err -22)
[ 12.376598] nvmap: disagrees about version of symbol fd_install
[ 12.382685] nvmap: Unknown symbol fd_install (err -22)
[ 12.388013] nvmap: disagrees about version of symbol wake_up_process
[ 12.394553] nvmap: Unknown symbol wake_up_process (err -22)
[ 12.398787] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.400337] nvmap: disagrees about version of symbol _dev_info
[ 12.405771] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[ 12.418706] nvmap: Unknown symbol _dev_info (err -22)
[ 12.418730] nvmap: disagrees about version of symbol perf_trace_run_bpf_submit
[ 12.431334] nvmap: Unknown symbol perf_trace_run_bpf_submit (err -22)
[ 12.440750] nvmap: disagrees about version of symbol _dev_err
[ 12.449239] nvmap: Unknown symbol _dev_err (err -22)
[ 12.454714] nvmap: disagrees about version of symbol __close_fd
[ 12.460815] nvmap: Unknown symbol __close_fd (err -22)
[ 12.470641] systemd[1]: Starting udev Coldplug all Devices...
[ 12.491190] systemd[1]: Started Journal Service.
[ 12.503783] nvmap: disagrees about version of symbol dev_set_name
[ 12.510073] nvmap: Unknown symbol dev_set_name (err -22)
[ 12.515918] nvmap: disagrees about version of symbol sched_set_normal
[ 12.523290] nvmap: Unknown symbol sched_set_normal (err -22)
[ 12.529145] nvmap: disagrees about version of symbol fd_install
[ 12.535226] nvmap: Unknown symbol fd_install (err -22)
[ 12.540558] nvmap: disagrees about version of symbol wake_up_process
[ 12.547089] nvmap: Unknown symbol wake_up_process (err -22)
[ 12.547140] nvmap: disagrees about version of symbol _dev_info
[ 12.558819] nvmap: Unknown symbol _dev_info (err -22)
[ 12.566852] nvmap: disagrees about version of symbol perf_trace_run_bpf_submit
[ 12.576884] nvmap: Unknown symbol perf_trace_run_bpf_submit (err -22)
[ 12.583517] nvmap: disagrees about version of symbol _dev_err
[ 12.589422] nvmap: Unknown symbol _dev_err (err -22)
[ 12.594541] nvmap: disagrees about version of symbol __close_fd
[ 12.600622] nvmap: Unknown symbol __close_fd (err -22)
[ 12.642238] pwm_fan: disagrees about version of symbol _dev_err
[ 12.650920] pwm_fan: Unknown symbol _dev_err (err -22)
[ 12.658830] pwm_fan: disagrees about version of symbol dev_err_probe
[ 12.665377] pwm_fan: Unknown symbol dev_err_probe (err -22)
[ 12.690025] ina3221: disagrees about version of symbol _dev_err
[ 12.696121] ina3221: Unknown symbol _dev_err (err -22)
[ 12.701411] ina3221: disagrees about version of symbol _dev_warn
[ 12.707587] ina3221: Unknown symbol _dev_warn (err -22)
[ 12.919911] systemd-journald[267]: Received client request to flush runtime journal.
[ 13.414567] binfmt_misc: disagrees about version of symbol lookup_one_len
[ 13.421972] binfmt_misc: Unknown symbol lookup_one_len (err -22)
[ 13.520953] nvidia: loading out-of-tree module taints kernel.
[ 13.531079] nvidia: disagrees about version of symbol nvhost_get_default_device
[ 13.545711] nvidia: Unknown symbol nvhost_get_default_device (err -22)
[ 13.553941] nvidia: disagrees about version of symbol fget
[ 13.564404] nvidia: Unknown symbol fget (err -22)
[ 13.564554] spi_tegra114: disagrees about version of symbol _dev_err
[ 13.577773] spi_tegra114: Unknown symbol _dev_err (err -22)
[ 13.577880] nvmap: disagrees about version of symbol dev_set_name
[ 13.589901] nvmap: Unknown symbol dev_set_name (err -22)
[ 13.597015] nvmap: disagrees about version of symbol sched_set_normal
[ 13.604373] nvmap: Unknown symbol sched_set_normal (err -22)
[ 13.604789] ina3221: disagrees about version of symbol _dev_err
[ 13.621939] ina3221: Unknown symbol _dev_err (err -22)
[ 13.622149] nvidia: disagrees about version of symbol fd_install
[ 13.642429] nvidia: Unknown symbol fd_install (err -22)
[ 13.643545] spi_tegra114: disagrees about version of symbol _dev_warn
[ 13.665957] tegra210_adma: disagrees about version of symbol dev_driver_string
[ 13.669099] spi_tegra114: Unknown symbol _dev_warn (err -22)
[ 13.680493] tegra210_adma: Unknown symbol dev_driver_string (err -22)
[ 13.681951] r8168: disagrees about version of symbol alloc_etherdev_mqs
[ 13.700045] r8168: Unknown symbol alloc_etherdev_mqs (err -22)
[ 13.700133] tegra_bpmp_thermal: disagrees about version of symbol _dev_err
[ 13.714982] tegra_bpmp_thermal: Unknown symbol _dev_err (err -22)
[ 13.715104] ina3221: disagrees about version of symbol _dev_warn
[ 13.727579] ina3221: Unknown symbol _dev_warn (err -22)
[ 13.733119] snd_hda_core: disagrees about version of symbol dev_set_name
[ 13.740049] snd_hda_core: Unknown symbol dev_set_name (err -22)
[ 13.740064] fusb301: disagrees about version of symbol dev_fwnode
[ 13.752536] fusb301: Unknown symbol dev_fwnode (err -22)
[ 13.752600] tegra210_adma: disagrees about version of symbol _dev_info
[ 13.764755] tegra210_adma: Unknown symbol _dev_info (err -22)
[ 13.764772] tegra210_adma: disagrees about version of symbol _dev_err
[ 13.777330] tegra210_adma: Unknown symbol _dev_err (err -22)
[ 13.777369] fusb301: disagrees about version of symbol _dev_info
[ 13.794872] fusb301: Unknown symbol _dev_info (err -22)
[ 13.795001] r8168: disagrees about version of symbol __skb_pad
[ 13.806340] r8168: Unknown symbol __skb_pad (err -22)
[ 13.806395] fusb301: disagrees about version of symbol _dev_err
[ 13.817624] fusb301: Unknown symbol _dev_err (err -22)
[ 13.869905] snd_hda_core: disagrees about version of symbol device_initialize
[ 13.877928] snd_hda_core: Unknown symbol device_initialize (err -22)
[ 13.877989] snd_soc_simple_card_utils: disagrees about version of symbol _dev_err
[ 13.897363] tegra210_adma: disagrees about version of symbol _dev_warn
[ 13.897425] snd_soc_simple_card_utils: Unknown symbol _dev_err (err -22)
[ 13.904110] tegra210_adma: Unknown symbol _dev_warn (err -22)
[ 13.904202] userspace_alert: disagrees about version of symbol kobject_uevent_env
[ 13.904207] userspace_alert: Unknown symbol kobject_uevent_env (err -22)
[ 13.904217] userspace_alert: disagrees about version of symbol _dev_err
[ 13.904221] userspace_alert: Unknown symbol _dev_err (err -22)
[ 13.961788] spi_tegra114: disagrees about version of symbol dev_err_probe
[ 13.968843] spi_tegra114: Unknown symbol dev_err_probe (err -22)
[ 13.968900] nvmap: disagrees about version of symbol fd_install
[ 13.981112] nvmap: Unknown symbol fd_install (err -22)
[ 14.005711] pwm_fan: disagrees about version of symbol _dev_err
[ 14.011852] pwm_fan: Unknown symbol _dev_err (err -22)
[ 14.012080] r8168: disagrees about version of symbol skb_copy_bits
[ 14.023546] r8168: Unknown symbol skb_copy_bits (err -22)
[ 14.023552] snd_soc_tegra210_ahub: disagrees about version of symbol _dev_err
[ 14.041921] snd_soc_tegra210_ahub: Unknown symbol _dev_err (err -22)
[ 14.042001] r8168: disagrees about version of symbol skb_put
[ 14.054988] r8168: Unknown symbol skb_put (err -22)
[ 14.055104] binfmt_misc: disagrees about version of symbol lookup_one_len
[ 14.067017] binfmt_misc: Unknown symbol lookup_one_len (err -22)
[ 14.067033] r8168: disagrees about version of symbol skb_tstamp_tx
[ 14.079554] r8168: Unknown symbol skb_tstamp_tx (err -22)
[ 14.079567] fusb301: disagrees about version of symbol fwnode_get_named_child_node
[ 14.092917] fusb301: Unknown symbol fwnode_get_named_child_node (err -22)
[ 14.092933] r8168: disagrees about version of symbol __napi_alloc_skb
[ 14.106525] r8168: Unknown symbol __napi_alloc_skb (err -22)
[ 14.106651] fusb301: disagrees about version of symbol fwnode_handle_put
[ 14.124923] fusb301: Unknown symbol fwnode_handle_put (err -22)
[ 14.125059] pwm_fan: disagrees about version of symbol dev_err_probe
[ 14.137868] pwm_fan: Unknown symbol dev_err_probe (err -22)
[ 14.185710] r8168: disagrees about version of symbol netdev_update_features
[ 14.195118] r8168: Unknown symbol netdev_update_features (err -22)
[ 14.195164] snd_hda_core: disagrees about version of symbol put_device
[ 14.208588] snd_hda_core: Unknown symbol put_device (err -22)
[ 14.208593] r8168: disagrees about version of symbol consume_skb
[ 14.220687] r8168: Unknown symbol consume_skb (err -22)
[ 14.220749] nvidia: disagrees about version of symbol wake_up_process
[ 14.232717] nvidia: Unknown symbol wake_up_process (err -22)
[ 14.232720] snd_hda_core: disagrees about version of symbol perf_trace_run_bpf_submit
[ 14.246660] snd_hda_core: Unknown symbol perf_trace_run_bpf_submit (err -22)
[ 14.341799] r8168: disagrees about version of symbol unregister_netdev
[ 14.348521] r8168: Unknown symbol unregister_netdev (err -22)
[ 14.348746] nvidia: disagrees about version of symbol iterate_fd
[ 14.360733] nvidia: Unknown symbol iterate_fd (err -22)
[ 14.360768] snd_hda_core: disagrees about version of symbol _dev_err
[ 14.372795] snd_hda_core: Unknown symbol _dev_err (err -22)
[ 14.417852] nvmap: disagrees about version of symbol wake_up_process
[ 14.427516] nvmap: Unknown symbol wake_up_process (err -22)
[ 14.469756] r8168: disagrees about version of symbol netdev_warn
[ 14.475966] r8168: Unknown symbol netdev_warn (err -22)
[ 14.505956] snd_hda_core: disagrees about version of symbol device_add
[ 14.512710] snd_hda_core: Unknown symbol device_add (err -22)
[ 14.512823] nvmap: disagrees about version of symbol _dev_info
[ 14.524659] nvmap: Unknown symbol _dev_info (err -22)
[ 14.524769] sha1_ce: disagrees about version of symbol crypto_register_shash
[ 14.537191] sha1_ce: Unknown symbol crypto_register_shash (err -22)
[ 14.537230] tegra210_adma: disagrees about version of symbol dev_driver_string
[ 14.553928] tegra210_adma: Unknown symbol dev_driver_string (err -22)
[ 14.553970] sha1_ce: disagrees about version of symbol crypto_unregister_shash
[ 14.572438] sha1_ce: Unknown symbol crypto_unregister_shash (err -22)
[ 14.572502] tegra210_adma: disagrees about version of symbol _dev_info
[ 14.585789] tegra210_adma: Unknown symbol _dev_info (err -22)
[ 14.585816] nvmap: disagrees about version of symbol perf_trace_run_bpf_submit
[ 14.599160] nvmap: Unknown symbol perf_trace_run_bpf_submit (err -22)
[ 14.599163] snd_hda_core: disagrees about version of symbol device_del
[ 14.599171] snd_hda_core: Unknown symbol device_del (err -22)
[ 14.599176] r8168: disagrees about version of symbol __netif_napi_del
[ 14.599185] r8168: Unknown symbol __netif_napi_del (err -22)
[ 14.599188] tegra210_adma: disagrees about version of symbol _dev_err
[ 14.599192] tegra210_adma: Unknown symbol _dev_err (err -22)
[ 14.599220] r8168: disagrees about version of symbol netdev_err
[ 14.599225] r8168: Unknown symbol netdev_err (err -22)
[ 14.599233] r8168: disagrees about version of symbol pskb_expand_head
[ 14.599237] r8168: Unknown symbol pskb_expand_head (err -22)
[ 14.673720] r8168: disagrees about version of symbol dev_driver_string
[ 14.680911] sha256_arm64: disagrees about version of symbol crypto_unregister_shashes
[ 14.681461] r8168: Unknown symbol dev_driver_string (err -22)
[ 14.689010] sha256_arm64: Unknown symbol crypto_unregister_shashes (err -22)
[ 14.689072] sha256_arm64: disagrees about version of symbol crypto_register_shashes
[ 14.710127] sha256_arm64: Unknown symbol crypto_register_shashes (err -22)
[ 14.710155] r8168: disagrees about version of symbol eth_type_trans
[ 14.723648] r8168: Unknown symbol eth_type_trans (err -22)
[ 14.745703] tegra210_adma: disagrees about version of symbol _dev_warn
[ 14.752618] tegra210_adma: Unknown symbol _dev_warn (err -22)
[ 14.752632] nvmap: disagrees about version of symbol _dev_err
[ 14.769870] nvmap: Unknown symbol _dev_err (err -22)
[ 14.769937] nvmap: disagrees about version of symbol __close_fd
[ 14.782225] nvmap: Unknown symbol __close_fd (err -22)
[ 14.782257] snd_hda_core: disagrees about version of symbol _dev_warn
[ 14.794177] snd_hda_core: Unknown symbol _dev_warn (err -22)
[ 14.794243] r8168: disagrees about version of symbol napi_complete_done
[ 14.806849] r8168: Unknown symbol napi_complete_done (err -22)
[ 14.806936] ghash_ce: disagrees about version of symbol crypto_register_aead
[ 14.820184] ghash_ce: Unknown symbol crypto_register_aead (err -22)
[ 14.820197] ghash_ce: disagrees about version of symbol crypto_unregister_aead
[ 14.834061] ghash_ce: Unknown symbol crypto_unregister_aead (err -22)
[ 14.834090] sha256_arm64: disagrees about version of symbol crypto_unregister_shashes
[ 14.848771] sha256_arm64: Unknown symbol crypto_unregister_shashes (err -22)
[ 14.848801] r8168: disagrees about version of symbol skb_checksum_help
[ 14.862781] r8168: Unknown symbol skb_checksum_help (err -22)
[ 14.865661] binfmt_misc: disagrees about version of symbol lookup_one_len
[ 14.881078] binfmt_misc: Unknown symbol lookup_one_len (err -22)
[ 14.881186] nvidia: disagrees about version of symbol __close_fd
[ 14.895657] nvidia: Unknown symbol __close_fd (err -22)
[ 14.895678] sha256_arm64: disagrees about version of symbol crypto_register_shashes
[ 14.908948] sha256_arm64: Unknown symbol crypto_register_shashes (err -22)
[ 14.908954] ghash_ce: disagrees about version of symbol crypto_register_shash
[ 14.923427] ghash_ce: Unknown symbol crypto_register_shash (err -22)
[ 14.923442] r8168: disagrees about version of symbol __napi_schedule
[ 14.936555] r8168: Unknown symbol __napi_schedule (err -22)
[ 14.965651] snd_hda_core: disagrees about version of symbol kobject_uevent
[ 14.972744] snd_hda_core: Unknown symbol kobject_uevent (err -22)
[ 14.993970] r8168: disagrees about version of symbol netif_device_detach
[ 15.003587] r8168: Unknown symbol netif_device_detach (err -22)
[ 15.033820] ghash_ce: disagrees about version of symbol crypto_unregister_shash
[ 15.043070] ghash_ce: Unknown symbol crypto_unregister_shash (err -22)
[ 15.069822] r8168: disagrees about version of symbol _dev_info
[ 15.075835] r8168: Unknown symbol _dev_info (err -22)
[ 15.075974] ghash_ce: disagrees about version of symbol skcipher_walk_aead_encrypt
[ 15.088853] ghash_ce: Unknown symbol skcipher_walk_aead_encrypt (err -22)
[ 15.088855] r8168: disagrees about version of symbol napi_gro_receive
[ 15.102496] r8168: Unknown symbol napi_gro_receive (err -22)
[ 15.102545] ghash_ce: disagrees about version of symbol skcipher_walk_done
[ 15.115401] ghash_ce: Unknown symbol skcipher_walk_done (err -22)
[ 15.133642] r8168: disagrees about version of symbol netif_device_attach
[ 15.140553] r8168: Unknown symbol netif_device_attach (err -22)
[ 15.140661] ghash_ce: disagrees about version of symbol skcipher_walk_aead_decrypt
[ 15.154445] ghash_ce: Unknown symbol skcipher_walk_aead_decrypt (err -22)
[ 15.154525] nvidia: disagrees about version of symbol nvhost_syncpt_unit_interface_get_aperture
[ 15.170413] nvidia: Unknown symbol nvhost_syncpt_unit_interface_get_aperture (err -22)
[ 15.170425] r8168: disagrees about version of symbol _dev_err
[ 15.184495] r8168: Unknown symbol _dev_err (err -22)
[ 15.241641] r8168: disagrees about version of symbol init_net
[ 15.247572] r8168: Unknown symbol init_net (err -22)
[ 15.247927] aes_ce_cipher: disagrees about version of symbol crypto_unregister_alg
[ 15.263338] aes_ce_cipher: Unknown symbol crypto_unregister_alg (err -22)
[ 15.263401] r8168: disagrees about version of symbol softnet_data
[ 15.277858] r8168: Unknown symbol softnet_data (err -22)
[ 15.277882] aes_ce_cipher: disagrees about version of symbol crypto_register_alg
[ 15.290925] aes_ce_cipher: Unknown symbol crypto_register_alg (err -22)
[ 15.290936] r8168: disagrees about version of symbol netif_napi_add
[ 15.304166] r8168: Unknown symbol netif_napi_add (err -22)
[ 15.304175] r8168: disagrees about version of symbol netif_set_real_num_tx_queues
[ 15.317505] r8168: Unknown symbol netif_set_real_num_tx_queues (err -22)
[ 15.350139] aes_ce_cipher: disagrees about version of symbol crypto_unregister_alg
[ 15.357956] aes_ce_cipher: Unknown symbol crypto_unregister_alg (err -22)
[ 15.357962] r8168: disagrees about version of symbol netif_set_real_num_rx_queues
[ 15.372641] r8168: Unknown symbol netif_set_real_num_rx_queues (err -22)
[ 15.372655] aes_ce_cipher: disagrees about version of symbol crypto_register_alg
[ 15.387188] aes_ce_cipher: Unknown symbol crypto_register_alg (err -22)
[ 15.387222] r8168: disagrees about version of symbol register_netdev
[ 15.400561] r8168: Unknown symbol register_netdev (err -22)
[ 15.400578] r8168: disagrees about version of symbol free_netdev
[ 15.412504] r8168: Unknown symbol free_netdev (err -22)
[ 15.446230] r8168: disagrees about version of symbol netif_tx_wake_queue
[ 15.453143] r8168: Unknown symbol netif_tx_wake_queue (err -22)
[ 15.459244] r8168: disagrees about version of symbol netif_schedule_queue
[ 15.466233] r8168: Unknown symbol netif_schedule_queue (err -22)
[ 15.472429] r8168: disagrees about version of symbol __netdev_alloc_skb
[ 15.479238] r8168: Unknown symbol __netdev_alloc_skb (err -22)
[ 15.485272] r8168: disagrees about version of symbol linkwatch_fire_event
[ 15.492260] r8168: Unknown symbol linkwatch_fire_event (err -22)
[ 15.492270] r8168: disagrees about version of symbol __dev_kfree_skb_any
[ 15.505341] r8168: Unknown symbol __dev_kfree_skb_any (err -22)
[ 15.514226] r8168: disagrees about version of symbol netif_carrier_off
[ 15.523529] r8168: Unknown symbol netif_carrier_off (err -22)
[ 15.526193] using random self ethernet address
[ 15.530382] r8168: disagrees about version of symbol netif_carrier_on
[ 15.534955] using random host ethernet address
[ 15.541578] r8168: Unknown symbol netif_carrier_on (err -22)
[ 15.541589] r8168: disagrees about version of symbol dev_printk
[ 15.558073] r8168: Unknown symbol dev_printk (err -22)
[ 15.558662] loop: disagrees about version of symbol fget
[ 15.568876] loop: Unknown symbol fget (err -22)
[ 15.568885] r8168: disagrees about version of symbol napi_schedule_prep
[ 15.580372] r8168: Unknown symbol napi_schedule_prep (err -22)
[ 15.580376] loop: disagrees about version of symbol set_user_nice
[ 15.580380] loop: Unknown symbol set_user_nice (err -22)
[ 15.580382] r8168: disagrees about version of symbol napi_consume_skb
[ 15.580384] r8168: Unknown symbol napi_consume_skb (err -22)
[ 15.580388] r8168: disagrees about version of symbol napi_disable
[ 15.580389] r8168: Unknown symbol napi_disable (err -22)
[ 15.580399] r8168: disagrees about version of symbol ethtool_op_get_ts_info
[ 15.580400] r8168: Unknown symbol ethtool_op_get_ts_info (err -22)
[ 15.580403] r8168: disagrees about version of symbol netdev_info
[ 15.580405] r8168: Unknown symbol netdev_info (err -22)
[ 15.678024] loop: disagrees about version of symbol path_put
[ 15.683871] loop: Unknown symbol path_put (err -22)
[ 15.688902] loop: disagrees about version of symbol wake_up_process
[ 15.695356] loop: Unknown symbol wake_up_process (err -22)
[ 15.701122] loop: disagrees about version of symbol path_get
[ 15.706952] loop: Unknown symbol path_get (err -22)
[ 15.712013] loop: disagrees about version of symbol kobject_uevent
[ 15.718387] loop: Unknown symbol kobject_uevent (err -22)
[ 15.723953] loop: disagrees about version of symbol rcuwait_wake_up
[ 15.730421] loop: Unknown symbol rcuwait_wake_up (err -22)
[ 16.156351] loop: disagrees about version of symbol fget
[ 16.161862] loop: Unknown symbol fget (err -22)
[ 16.166545] loop: disagrees about version of symbol set_user_nice
[ 16.172813] loop: Unknown symbol set_user_nice (err -22)
[ 16.178341] loop: disagrees about version of symbol path_put
[ 16.184157] loop: Unknown symbol path_put (err -22)
[ 16.189185] loop: disagrees about version of symbol wake_up_process
[ 16.195627] loop: Unknown symbol wake_up_process (err -22)
[ 16.195736] loop: disagrees about version of symbol path_get
[ 16.207093] loop: Unknown symbol path_get (err -22)
[ 16.214935] loop: disagrees about version of symbol kobject_uevent
[ 16.223921] loop: Unknown symbol kobject_uevent (err -22)
[ 16.229550] loop: disagrees about version of symbol rcuwait_wake_up
[ 16.235989] loop: Unknown symbol rcuwait_wake_up (err -22)
[ 21.187357] ramoops: disagrees about version of symbol _dev_err
[ 21.193480] ramoops: Unknown symbol _dev_err (err -22)
[ 21.368871] lzo_rle: disagrees about version of symbol crypto_unregister_alg
[ 21.378530] lzo_rle: Unknown symbol crypto_unregister_alg (err -22)
[ 21.386636] lzo_rle: disagrees about version of symbol crypto_register_alg
[ 21.393726] lzo_rle: Unknown symbol crypto_register_alg (err -22)
[ 21.400014] lzo_rle: disagrees about version of symbol crypto_register_scomp
[ 21.407272] lzo_rle: Unknown symbol crypto_register_scomp (err -22)
[ 21.413732] lzo_rle: disagrees about version of symbol crypto_unregister_scomp
[ 21.421165] lzo_rle: Unknown symbol crypto_unregister_scomp (err -22)
[ 21.453507] zram: Cannot initialise lzo-rle compressing backend
[ 21.469385] lzo_rle: disagrees about version of symbol crypto_unregister_alg
[ 21.477321] lzo_rle: Unknown symbol crypto_unregister_alg (err -22)
[ 21.483840] lzo_rle: disagrees about version of symbol crypto_register_alg
[ 21.490933] lzo_rle: Unknown symbol crypto_register_alg (err -22)
[ 21.497225] lzo_rle: disagrees about version of symbol crypto_register_scomp
[ 21.497227] lzo_rle: Unknown symbol crypto_register_scomp (err -22)
[ 21.497234] lzo_rle: disagrees about version of symbol crypto_unregister_scomp
[ 21.497238] lzo_rle: Unknown symbol crypto_unregister_scomp (err -22)
[ 21.528975] zram: Cannot initialise lzo-rle compressing backend
[ 21.546959] lzo_rle: disagrees about version of symbol crypto_unregister_alg
[ 21.556196] lzo_rle: Unknown symbol crypto_unregister_alg (err -22)
[ 21.556227] binfmt_misc: disagrees about version of symbol lookup_one_len
[ 21.572324] binfmt_misc: Unknown symbol lookup_one_len (err -22)
[ 21.572341] lzo_rle: disagrees about version of symbol crypto_register_alg
[ 21.585610] lzo_rle: Unknown symbol crypto_register_alg (err -22)
[ 21.621673] lzo_rle: disagrees about version of symbol crypto_register_scomp
[ 21.628971] lzo_rle: Unknown symbol crypto_register_scomp (err -22)
[ 21.635434] lzo_rle: disagrees about version of symbol crypto_unregister_scomp
[ 21.642876] lzo_rle: Unknown symbol crypto_unregister_scomp (err -22)
[ 21.679282] zram: Cannot initialise lzo-rle compressing backend
[ 21.697363] lzo_rle: disagrees about version of symbol crypto_unregister_alg
[ 21.704636] lzo_rle: Unknown symbol crypto_unregister_alg (err -22)
[ 21.711111] lzo_rle: disagrees about version of symbol crypto_register_alg
[ 21.718234] lzo_rle: Unknown symbol crypto_register_alg (err -22)
[ 21.718244] lzo_rle: disagrees about version of symbol crypto_register_scomp
[ 21.718245] lzo_rle: Unknown symbol crypto_register_scomp (err -22)
[ 21.718251] lzo_rle: disagrees about version of symbol crypto_unregister_scomp
[ 21.718252] lzo_rle: Unknown symbol crypto_unregister_scomp (err -22)
[ 21.743655] zram: Cannot initialise lzo-rle compressing backend
[ 21.772398] lzo_rle: disagrees about version of symbol crypto_unregister_alg
[ 21.779688] lzo_rle: Unknown symbol crypto_unregister_alg (err -22)
[ 21.786159] lzo_rle: disagrees about version of symbol crypto_register_alg
[ 21.793251] lzo_rle: Unknown symbol crypto_register_alg (err -22)
[ 21.802327] lzo_rle: disagrees about version of symbol crypto_register_scomp
[ 21.812093] lzo_rle: Unknown symbol crypto_register_scomp (err -22)
[ 21.818552] lzo_rle: disagrees about version of symbol crypto_unregister_scomp
[ 21.825991] lzo_rle: Unknown symbol crypto_unregister_scomp (err -22)
[ 21.861260] zram: Cannot initialise lzo-rle compressing backend
[ 21.876961] lzo_rle: disagrees about version of symbol crypto_unregister_alg
[ 21.884236] lzo_rle: Unknown symbol crypto_unregister_alg (err -22)
[ 21.884251] lzo_rle: disagrees about version of symbol crypto_register_alg
[ 21.897807] lzo_rle: Unknown symbol crypto_register_alg (err -22)
[ 21.897818] lzo_rle: disagrees about version of symbol crypto_register_scomp
[ 21.916710] lzo_rle: Unknown symbol crypto_register_scomp (err -22)
[ 21.923159] lzo_rle: disagrees about version of symbol crypto_unregister_scomp
[ 21.930596] lzo_rle: Unknown symbol crypto_unregister_scomp (err -22)
[ 21.962312] zram: Cannot initialise lzo-rle compressing backend
[ 21.979271] lzo_rle: disagrees about version of symbol crypto_unregister_alg
[ 21.986564] lzo_rle: Unknown symbol crypto_unregister_alg (err -22)
[ 21.993043] lzo_rle: disagrees about version of symbol crypto_register_alg
[ 22.000198] lzo_rle: Unknown symbol crypto_register_alg (err -22)
[ 22.006491] lzo_rle: disagrees about version of symbol crypto_register_scomp
[ 22.013750] lzo_rle: Unknown symbol crypto_register_scomp (err -22)
[ 22.020237] lzo_rle: disagrees about version of symbol crypto_unregister_scomp
[ 22.027680] lzo_rle: Unknown symbol crypto_unregister_scomp (err -22)
[ 22.061364] zram: Cannot initialise lzo-rle compressing backend
[ 22.079147] lzo_rle: disagrees about version of symbol crypto_unregister_alg
[ 22.088018] lzo_rle: Unknown symbol crypto_unregister_alg (err -22)
[ 22.095895] lzo_rle: disagrees about version of symbol crypto_register_alg
[ 22.103003] lzo_rle: Unknown symbol crypto_register_alg (err -22)
[ 22.109294] lzo_rle: disagrees about version of symbol crypto_register_scomp
[ 22.116554] lzo_rle: Unknown symbol crypto_register_scomp (err -22)
[ 22.123019] lzo_rle: disagrees about version of symbol crypto_unregister_scomp
[ 22.130444] lzo_rle: Unknown symbol crypto_unregister_scomp (err -22)
[ 22.169756] zram: Cannot initialise lzo-rle compressing backend
[ 22.234936] mtd: disagrees about version of symbol dev_set_name
[ 22.241040] mtd: Unknown symbol dev_set_name (err -22)
[ 22.246417] mtd: disagrees about version of symbol device_unregister
[ 22.252991] mtd: Unknown symbol device_unregister (err -22)
[ 22.258749] mtd: disagrees about version of symbol logfc
[ 22.264246] mtd: Unknown symbol logfc (err -22)
[ 22.268944] mtd: disagrees about version of symbol put_device
[ 22.274927] mtd: Unknown symbol put_device (err -22)
[ 22.280066] mtd: disagrees about version of symbol _dev_err
[ 22.285808] mtd: Unknown symbol _dev_err (err -22)
[ 22.290757] mtd: disagrees about version of symbol device_create
[ 22.296956] mtd: Unknown symbol device_create (err -22)
[ 22.302376] mtd: disagrees about version of symbol device_register
[ 22.308751] mtd: Unknown symbol device_register (err -22)
[ 22.314348] mtd: disagrees about version of symbol device_destroy
[ 22.320634] mtd: Unknown symbol device_destroy (err -22)
Complete log as follows:
orin_nx_startup.txt (117.9 KB)
flash_mptcp.txt (276.4 KB)
deconfig file:
defconfig.txt (32.6 KB)
In JetPack5.1.5,Do it support opening MPTCP? If supported, how to correctly open MPTCP in Orin NX?
I am very grateful for any help.
