Orin SOM can't flash with Orin Devkit CVB neither custom CVB?
Hi NV_Team,
We get the new Orin SOM, when we flash it with Devkit CVB or our custom CVB can’t flash it with Linux_For_Tegra, flash log(JetPack5.0DP and 5.0.1DP both failed) :
sudo ./flash.sh  -r jetson-agx-orin-devkit  mmcblk0p1
# L4T BSP Information:
# R34 , REVISION: 1.1
# Target Board Information:
# Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0107 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[   0.0115 ] File rcm_state open failed
[   0.0115 ] ERROR: failed to read rcm_state
[   0.0115 ]
[   0.0128 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0131 ] Assuming zero filled SBK key
[   0.0120 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.0174 ] Pre-processing config: tegra234-br-bct-diag-boot.dts
[   0.0224 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.0514 ] Parsing partition layout
[   0.0534 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0548 ]
[   0.0557 ] Parsing partition layout
[   0.0569 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0583 ]
[   0.0584 ] Creating list of images to be signed
[   0.0605 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0616 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0628 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0634 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0694 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0713 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0758 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0761 ] adding BCH for mb2_t234_aligned.bin
[   0.0789 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0916 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0919 ] adding BCH for mb2_t234_aligned.bin
[   0.1063 ]
[   0.1064 ] Generating signatures
[   0.1077 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1079 ] Assuming zero filled SBK key
[   0.1181 ] Warning: pub_key.key is not found
[   0.1170 ] Generating br-bct
[   0.1190 ] Updating dev and MSS params in BR BCT
[   0.1191 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1199 ]
[   0.1200 ] Updating bl info
[   0.1207 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.1214 ] WARNING: boot chain is not completed. set to 0
[   0.1222 ]
[   0.1222 ] Get Signed section of bct
[   0.1230 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.1238 ]
[   0.1239 ] Signing BCT
[   0.1252 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1254 ] Assuming zero filled SBK key
[   0.1277 ] Sha saved in br_bct_BR.sha
[   0.1280 ] Warning: pub_key.key is not found
[   0.1267 ] Updating BCT with signature
[   0.1274 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.1285 ]
[   0.1286 ] Generating SHA2 Hash
[   0.1299 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.1301 ] Assuming zero filled SBK key
[   0.1326 ] Sha saved in br_bct_BR.sha
[   0.1317 ] Updating BCT with SHA2 Hash
[   0.1324 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 --updatesha bct_list_signed.xml
[   0.1332 ] Offset :68 Len :8124
[   0.1335 ]
[   0.1336 ] Generating coldboot mb1-bct
[   0.1344 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1352 ] MB1-BCT version: 0.7
[   0.1354 ] ERROR: /misc/axi_ap_virtual_client is not supported
[   0.1364 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1366 ] Added Platform Config 9 data with size :- 80
[   0.1366 ]
[   0.1367 ] Updating mb1-bct with firmware information
[   0.1374 ] tegrabct_v2 --chip 0x23 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1386 ]
[   0.1396 ] tegrahost_v2 --chip 0x23 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.1404 ]
[   0.1412 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.1420 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.1425 ]
[   0.1440 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --sha sha512
[   0.1442 ] Assuming zero filled SBK key
[   0.1454 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.1466 ]
[   0.1468 ] Generating recovery mb1-bct
[   0.1476 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1483 ] MB1-BCT version: 0.7
[   0.1485 ] ERROR: /misc/axi_ap_virtual_client is not supported
[   0.1494 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1495 ] Added Platform Config 9 data with size :- 80
[   0.1495 ]
[   0.1495 ] Updating mb1-bct with firmware information
[   0.1503 ] tegrabct_v2 --chip 0x23 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1514 ]
[   0.1523 ] tegrahost_v2 --chip 0x23 --align mb1_bct_MB1_aligned.bct
[   0.1530 ]
[   0.1538 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.1545 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.1550 ]
[   0.1565 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --sha sha512
[   0.1567 ] Assuming zero filled SBK key
[   0.1577 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.1588 ]
[   0.1590 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.1590 ] Copying signatures
[   0.1598 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.1645 ]
[   0.1650 ] Boot Rom communication
[   0.1659 ] tegrarcm_v2 --new_session --chip 0x23 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.1666 ] BR_CID: 0x80012344705E35DE640000000B018080
[   0.1676 ] Sending bct_br
[   0.1820 ] Sending mb1
[   0.1825 ] Sending psc_bl1
[   0.1906 ] Sending bct_mb1
[   0.1960 ]
[   0.1960 ] Boot Rom communication completed
[   0.2266 ] tegrahost_v2 --chip 0x23 --align applet_t234_aligned.bin
[   0.2288 ]
[   0.2312 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.2330 ] adding BCH for applet_t234_aligned.bin
[   0.2437 ]
[   0.2453 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --sha sha512
[   0.2455 ] Assuming zero filled SBK key
[   0.2477 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.2492 ]
[   0.2496 ] Sending mb2_applet...
[   0.2505 ] tegrarcm_v2 --chip 0x23 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.2513 ] BL: version 0.11.0.0-t234-54845784-7fb1fa27 last_boot_error: 0
[   0.3918 ] Sending applet
[   0.5097 ]
[   0.5098 ] completed
[   0.5131 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[   0.5150 ] MB2 Applet version 01.00.0000
[   0.7006 ]
[   0.7038 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[   0.7064 ] MB2 Applet version 01.00.0000
[   0.7097 ]
[   0.7111 ] Retrieving board information
[   0.7123 ] tegrarcm_v2 --chip 0x23 --oem platformdetails chip chip_info.bin
[   0.7135 ] MB2 Applet version 01.00.0000
[   0.7284 ] Saved platform info in chip_info.bin
[   0.7340 ] Chip minor revision: 1
[   0.7342 ] Bootrom revision: 0x7
[   0.7343 ] Ram code: 0x0
[   0.7343 ] Chip sku: 0xd2
[   0.7343 ] Chip Sample: prod
[   0.7343 ]
[   0.7348 ] Retrieving EEPROM data
[   0.7349 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23
[   0.7368 ] MB2 Applet version 01.00.0000
[   0.7573 ] Saved platform info in /home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/cvm.bin
[   0.7895 ]
[   0.7929 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[   0.7958 ] MB2 Applet version 01.00.0000
[   0.7988 ]
[   0.8008 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[   0.8017 ] MB2 Applet version 01.00.0000
[   0.8202 ]
[   0.8203 ] Dumping customer Info
[   0.8218 ] tegrarcm_v2 --chip 0x23 --oem dump bct tmp.bct
[   0.8231 ] MB2 Applet version 01.00.0000
[   0.8410 ] Saved bct in tmp.bct
[   0.8479 ]
[   0.8506 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/custinfo_out.bin
[   0.8526 ] Customer data saved in /home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[   0.8530 ] Rebooting to recovery mode
[   0.8545 ] tegrarcm_v2 --chip 0x23 --ismb2
[   0.8583 ]
[   0.8598 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[   0.8611 ] MB2 Applet version 01.00.0000
[   0.8760 ]
[   0.8761 ] Booting to recovery mode
[   0.8779 ] tegrarcm_v2 --chip 0x23 --reboot recovery
[   0.8798 ] MB2 Applet version 01.00.0000
[   0.9004 ]
Board ID(3701) version(RC1) sku(0004) revision(A.0)
Copy /home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb to /home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb.rec
copying bctfile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3701-0000-p3737-0000-TE990M-sdram.dts)... done.
copying pinmux_config(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3701-0000.dtsi)... done.
copying gpioint_config(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-gpioint-p3701-0000.dts)... done.
copying pmic_config(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pmic-p3701-0000.dts)... done.
copying pmc_config(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-padvoltage-p3701-0000.dtsi)... done.
copying deviceprod_config(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-cprod-p3701-0000.dts)... done.
copying prod_config(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-prod-p3701-0000.dts)... done.
copying wb0sdram(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram.dts)... done.
copying bootrom_config(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-reset-p3701-0000.dts)... done.
copying dev_params(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-p3701-0000.dts)... done.
copying mb2bct_cfg(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3701-0000.dts)... done.
Existing pscfwfile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing mb2applet(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
~/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/ramdisk_tmp ~/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader ~/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra
36137 blocks
gzip: /home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.65-tegra
52364 blocks
Making Recovery image...
copying recdtbfile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000215399 s, 92.9 kB/s
Existing sosfile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing dcefile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/dce.bin) reused.
Existing nvdecfile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/nvtboot_cpurf_t234.bin) reused.
Existing mb1file(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/tegra234-bpmp-3701-0000-3737-0000.dtb)... done.
Existing scefile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/tos-mon-only_t234.img) reused.
Existing eksfile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
Reusing existing system.img...
done.
Existing tbcfile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
Skip generating EFI system partition image.
copying tbcdtbfile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb)... done.
copying cfgfile(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t234_qspi_sdmmc.xml) to flash.xml... done.
Existing flashapp(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/tegraflash.py) reused.
Existing overlay_dtb(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/tegra234-p3737-overlay-pcie.dtbo) reused.
Existing overlay_dtb(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/tegra234-p3737-audio-codec-rt5658-40pin.dtbo) reused.
Existing overlay_dtb(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/tegra234-p3737-a04-overlay.dtbo) reused.
Existing overlay_dtb(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/tegra234-p3737-camera-dual-imx274-overlay.dtbo) reused.
Existing overlay_dtb(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/tegra234-p3737-camera-e3331-overlay.dtbo) reused.
Existing overlay_dtb(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/tegra234-p3737-camera-e3333-overlay.dtbo) reused.
Existing overlay_dtb(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/tegra234-p3737-camera-imx185-overlay.dtbo) reused.
Existing overlay_dtb(/home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/tegra234-p3737-camera-imx390-overlay.dtbo) reused.
./tegraflash.py  --bl uefi_jetson_with_dtb.bin  --odmdata gbe-uphy-config-0,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-16  --overlay_dtb tegra234-p3737-overlay-pcie.dtbo,tegra234-p3737-audio-codec-rt5658-40pin.dtbo,tegra234-p3737-a04-overlay.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo,tegra234-p3737-camera-imx390-overlay.dtbo  --bldtb tegra234-p3701-0000-p3737-0000.dtb --applet mb1_t234_prod.bin --cmd "flash; reboot"  --cfg flash.xml --chip 0x23 --concat_cpubl_bldtb --cpubl uefi_jetson.bin --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3701-0000.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3701-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3701-0000.dts --pmc_config tegra234-mb1-bct-padvoltage-p3701-0000.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3701-0000.dts --prod_config tegra234-mb1-bct-prod-p3701-0000.dts --wb0sdram_config tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram.dts --br_cmd_config tegra234-mb1-bct-reset-p3701-0000.dts --dev_params tegra234-br-bct-p3701-0000.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3701-0000.dts  --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; dce_fw dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra234-bpmp-3701-0000-3737-0000.dtb; sce_fw camera-rtcpu-sce.img; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tlk tos-mon-only_t234.img; eks eks.img"   --sdram_config tegra234-p3701-0000-p3737-0000-TE990M-sdram.dts  --cust_info custinfo_out.bin
saving flash command in /home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/twsrv01/sda/home/dennis/nvidia/orin_agx_nx_5.0dp_34.1.1/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[   0.0121 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0122 ] Assuming zero filled SBK key
[   0.0115 ] Parsing partition layout
[   0.0123 ] tegraparser_v2 --pt flash.xml.tmp
[   0.0136 ]
[   0.0167 ] Change tegra234-bpmp-3701-0000-3737-0000.dtb to tegra234-bpmp-3701-0000-3737-0000_with_odm.dtb
[   0.0168 ] Change tegra234-bpmp-3701-0000-3737-0000.dtb to tegra234-bpmp-3701-0000-3737-0000_with_odm.dtb
[   0.0495 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3701-0000-3737-0000_with_odm.dtb tegra234-bpmp-3701-0000-3737-0000_with_odm_tmp.dtb
[   0.2185 ]
[   0.2218 ] Change kernel_tegra234-p3701-0000-p3737-0000.dtb to kernel_tegra234-p3701-0000-p3737-0000_with_odm.dtb
[   0.2240 ] Change kernel_tegra234-p3701-0000-p3737-0000.dtb to kernel_tegra234-p3701-0000-p3737-0000_with_odm.dtb
[   0.7843 ] Concatenating tegra234-p3737-overlay-pcie.dtbo,tegra234-p3737-audio-codec-rt5658-40pin.dtbo,tegra234-p3737-a04-overlay.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo,tegra234-p3737-camera-imx390-overlay.dtbo to tegra234-p3701-0000-p3737-0000_with_odm.dtb
[   0.7847 ] Concatenating bl dtb to cpubl binary
[   0.7875 ] MB2 binary: mb2_t234.bin
[   0.7876 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3701-0000.dts
[   0.8152 ] Generating coldboot mb2-bct
[   0.8153 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3701-0000_cpp.dtb
[   0.8190 ]
[   0.8191 ] Updating mb2-bct with storage information
[   0.8209 ] tegrabct_v2 --chip 0x23 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   0.8234 ]
[   0.8235 ] Concatenating mb2-bct to mb2 binary
[   0.8235 ] mb2_bin_file = mb2_t234.bin
[   0.8235 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[   0.8299 ] DCE binary: dce.bin
[   0.8299 ] Kernel DTB: kernel_tegra234-p3701-0000-p3737-0000.dtb
[   0.8299 ] Concatenate dce with kernel dtb
[   0.8299 ] Concatenating kernel-dtb to dce-fw binary
[   0.8300 ] dce_bin = dce.bin
[   0.8300 ] kernel_dtb = kernel_tegra234-p3701-0000-p3737-0000.dtb
[   0.8300 ] dce_with_dtb = dce_with_kernel_tegra234-p3701-0000-p3737-0000.bin
[   0.8392 ] Parsing partition layout
[   0.8405 ] tegraparser_v2 --pt flash.xml.tmp
[   0.8420 ]
[   0.8421 ] Creating list of images to be signed
[   0.8430 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[   0.8439 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.8447 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.8450 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.8487 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.8493 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.8532 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.8537 ] Header already present for nvdec_t234_prod_aligned.fw
[   0.8565 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   0.8609 ] adding BCH for xusb_t234_prod_aligned.bin
[   0.8742 ] adding BCH for bpmp_aligned.bin
[   0.8797 ] adding BCH for tegra234-bpmp-3701-0000-3737-0000_with_odm_aligned.dtb
[   0.8964 ] Header already present for pscfw_t234_prod_aligned.bin
[   0.9008 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   0.9066 ] Header already present for sc7_t234_prod.bin
[   0.9094 ] Header already present for psc_rf_t234_prod_aligned.bin
[   0.9105 ] adding BCH for nvtboot_cpurf_t234_aligned.bin
[   0.9124 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[   0.9201 ] adding BCH for tos-mon-only_t234_aligned.img
[   1.0136 ] adding BCH for eks_aligned.img
[   1.0168 ] adding BCH for dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned.bin
[   1.0351 ] adding BCH for spe_t234_aligned.bin
[   1.3149 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   1.3236 ] adding BCH for adsp-fw_aligned.bin
[   1.3395 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   1.3515 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   1.3518 ] Header already present for nvdec_t234_prod_aligned.fw
[   1.3538 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   1.3580 ] adding BCH for xusb_t234_prod_aligned.bin
[   1.3712 ] adding BCH for bpmp_aligned.bin
[   1.3769 ] adding BCH for tegra234-bpmp-3701-0000-3737-0000_with_odm_aligned.dtb
[   1.3936 ] Header already present for pscfw_t234_prod_aligned.bin
[   1.3981 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   1.4041 ] Header already present for sc7_t234_prod.bin
[   1.4070 ] Header already present for psc_rf_t234_prod_aligned.bin
[   1.4081 ] adding BCH for nvtboot_cpurf_t234_aligned.bin
[   1.4101 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[   1.4185 ] adding BCH for tos-mon-only_t234_aligned.img
[   1.5127 ] adding BCH for eks_aligned.img
[   1.5159 ] adding BCH for dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned.bin
[   1.5364 ] adding BCH for spe_t234_aligned.bin
[   1.8278 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   1.8415 ] adding BCH for adsp-fw_aligned.bin
[   1.8575 ] adding BCH for recovery_aligned.img
[   1.9577 ] adding BCH for tegra234-p3701-0000-p3737-0000.dtb_aligned.rec
[   3.3367 ]
[   3.3367 ] Filling MB1 storage info
[   3.3368 ] Generating br-bct
[   3.7650 ] Updating dev and MSS params in BR BCT
[   3.7651 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   3.7982 ]
[   3.7982 ] Updating bl info
[   3.7990 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   3.8002 ]
[   3.8003 ] Generating signatures
[   3.8012 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.8014 ] Assuming zero filled SBK key
[   4.0142 ] Warning: pub_key.key is not found
[   4.0135 ] Pre-processing config: tegra234-mb1-bct-reset-p3701-0000.dts
[   4.0185 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   4.0235 ] Pre-processing config: tegra234-mb1-bct-cprod-p3701-0000.dts
[   4.0297 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3701-0000.dts
[   4.0369 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   4.0496 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3701-0000.dtsi
[   4.1409 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3701-0000.dtsi
[   4.1456 ] Pre-processing config: tegra234-mb1-bct-pmic-p3701-0000.dts
[   4.1508 ] Pre-processing config: tegra234-mb1-bct-prod-p3701-0000.dts
[   4.1561 ] Pre-processing config: tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram.dts
[   4.5550 ] Generating br-bct
[   4.5560 ] Updating dev and MSS params in BR BCT
[   4.5561 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   4.5727 ]
[   4.5727 ] Updating customer data section
[   4.5737 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   4.5749 ]
[   4.5749 ] Updating bl info
[   4.5758 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   4.5778 ]
[   4.5778 ] Get Signed section of bct
[   4.5787 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   4.5797 ]
[   4.5797 ] Signing BCT
[   4.5806 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.5808 ] Assuming zero filled SBK key
[   4.5833 ] Sha saved in br_bct_BR.sha
[   4.5837 ] Warning: pub_key.key is not found
[   4.5829 ] Updating BCT with signature
[   4.5837 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   4.5850 ]
[   4.5850 ] Generating SHA2 Hash
[   4.5859 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   4.5861 ] Assuming zero filled SBK key
[   4.5862 ] Assuming zero filled SBK key
[   4.5895 ] Sha saved in br_bct_BR.sha
[   4.5892 ] Updating BCT with SHA2 Hash
[   4.5902 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 --updatesha bct_list_signed.xml
[   4.5911 ] Offset :68 Len :8124
[   4.5914 ]
[   4.5915 ] Generating coldboot mb1-bct
[   4.5924 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[   4.5933 ] MB1-BCT version: 0.7
[   4.5935 ] ERROR: /misc/axi_ap_virtual_client is not supported
[   4.5945 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000_cpp.dtb
[   4.5949 ] WARNING: unknown property 'linux,phandle'
[   4.5956 ] WARNING: unknown property 'linux,phandle'
[   4.5958 ] WARNING: unknown property 'linux,phandle'
[   4.5960 ] WARNING: unknown property 'linux,phandle'
[   4.5962 ] WARNING: unknown property 'linux,phandle'
[   4.5975 ] WARNING: unknown property 'linux,phandle'
[   4.5980 ] Added Platform Config 0 data with size :- 3744
[   4.5983 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000_cpp.dtb
[   4.5986 ] WARNING: unknown node 'g2'
[   4.5987 ] WARNING: unknown node 'g2'
[   4.5987 ] WARNING: unknown node 'g9'
[   4.5987 ] Added Platform Config 2 data with size :- 24
[   4.5987 ]
[   4.5987 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb
[   4.5987 ] Added Platform Config 4 data with size :- 476
[   4.5987 ]
[   4.5987 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[   4.5987 ] Added Platform Config 3 data with size :- 52
[   4.5988 ]
[   4.5988 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[   4.5988 ] WARNING: unknown property 'major'
[   4.5988 ] WARNING: unknown property 'minor'
[   4.5988 ] Added Platform Config 5 data with size :- 500
[   4.5988 ]
[   4.5988 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[   4.5988 ] Added Platform Config 7 data with size :- 380
[   4.5988 ]
[   4.5988 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   4.5988 ] Added Platform Config 9 data with size :- 80
[   4.5988 ]
[   4.5988 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[   4.5988 ] ModuleCount 0 NumProdNames 0
[   4.5988 ] Added Platform Config 6 data with size :- 16
[   4.5988 ]
[   4.5989 ] Updating mb1-bct with firmware information
[   4.5998 ] tegrabct_v2 --chip 0x23 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   4.6014 ]
[   4.6026 ] tegrahost_v2 --chip 0x23 --align mb1_cold_boot_bct_MB1_aligned.bct
[   4.6035 ]
[   4.6045 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   4.6055 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   4.6063 ]
[   4.6075 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --sha sha512
[   4.6076 ] Assuming zero filled SBK key
[   4.6098 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   4.6111 ]
[   4.6113 ] Generating recovery mb1-bct
[   4.6123 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[   4.6132 ] MB1-BCT version: 0.7
[   4.6133 ] ERROR: /misc/axi_ap_virtual_client is not supported
[   4.6144 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000_cpp.dtb
[   4.6148 ] WARNING: unknown property 'linux,phandle'
[   4.6155 ] WARNING: unknown property 'linux,phandle'
[   4.6157 ] WARNING: unknown property 'linux,phandle'
[   4.6159 ] WARNING: unknown property 'linux,phandle'
[   4.6161 ] WARNING: unknown property 'linux,phandle'
[   4.6176 ] WARNING: unknown property 'linux,phandle'
[   4.6181 ] Added Platform Config 0 data with size :- 3744
[   4.6183 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000_cpp.dtb
[   4.6187 ] WARNING: unknown node 'g2'
[   4.6188 ] WARNING: unknown node 'g2'
[   4.6189 ] WARNING: unknown node 'g9'
[   4.6189 ] Added Platform Config 2 data with size :- 24
[   4.6189 ]
[   4.6189 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb
[   4.6189 ] Added Platform Config 4 data with size :- 476
[   4.6189 ]
[   4.6189 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[   4.6189 ] Added Platform Config 3 data with size :- 52
[   4.6189 ]
[   4.6189 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[   4.6189 ] WARNING: unknown property 'major'
[   4.6189 ] WARNING: unknown property 'minor'
[   4.6189 ] Added Platform Config 5 data with size :- 500
[   4.6189 ]
[   4.6189 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[   4.6190 ] WARNING: unknown property 'minor'
[   4.6190 ] Added Platform Config 7 data with size :- 380
[   4.6190 ]
[   4.6190 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   4.6190 ] Added Platform Config 9 data with size :- 80
[   4.6190 ]
[   4.6190 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[   4.6190 ] ModuleCount 0 NumProdNames 0
[   4.6190 ] Added Platform Config 6 data with size :- 16
[   4.6190 ]
[   4.6190 ] Updating mb1-bct with firmware information
[   4.6200 ] tegrabct_v2 --chip 0x23 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   4.6213 ]
[   4.6224 ] tegrahost_v2 --chip 0x23 --align mb1_bct_MB1_aligned.bct
[   4.6234 ]
[   4.6244 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   4.6254 ] adding BCH for mb1_bct_MB1_aligned.bct
[   4.6262 ]
[   4.6274 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --sha sha512
[   4.6276 ] Assuming zero filled SBK key
[   4.6298 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   4.6311 ]
[   4.6314 ] Generating coldboot mem-bct
[   4.6323 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp.dtb --wb0sdram tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram_cpp.dtb --membct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_1.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_2.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_3.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_4.bct
[   4.6333 ]  packing sdram params with Wb0 file tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram_cpp.dtb
[   4.6525 ] Packing sdram param for instance[0]
[   4.6527 ] Packing sdram param for instance[1]
[   4.6529 ] Packing sdram param for instance[2]
[   4.6531 ] Packing sdram param for instance[3]
[   4.6532 ] Packing sdram param for instance[4]
[   4.6534 ] Packing sdram param for instance[5]
[   4.6536 ] Packing sdram param for instance[6]
[   4.6537 ] Packing sdram param for instance[7]
[   4.6539 ] Packing sdram param for instance[8]
[   4.6540 ] Packing sdram param for instance[9]
[   4.6542 ] Packing sdram param for instance[10]
[   4.6544 ] Packing sdram param for instance[11]
[   4.6545 ] Packing sdram param for instance[12]
[   4.6547 ] Packing sdram param for instance[13]
[   4.6549 ] Packing sdram param for instance[14]
[   4.6550 ] Packing sdram param for instance[15]
[   4.6700 ]
[   4.6700 ] Getting sector size from pt
[   4.6713 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   4.6723 ]
[   4.6724 ] BlockSize read from layout is 0x200
[   4.6733 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_1.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_2.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_3.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_4.bct
[   4.6741 ] Binary 0 length is 58752
[   4.6744 ] Binary 0 align length is 58880
[   4.6753 ] Binary 1 length is 58752
[   4.6754 ] Binary 1 align length is 58880
[   4.6762 ] Binary 2 length is 58752
[   4.6764 ] Binary 2 align length is 58880
[   4.6772 ] Binary 3 length is 58752
[   4.6773 ] Binary 3 align length is 58880
[   4.6782 ] Buffer length is 235520
[   4.6783 ] adding BCH for tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_1.bct
[   4.6786 ] new length is 243712
[   4.6786 ]
[   4.6801 ] tegrahost_v2 --chip 0x23 --align mem_coldboot_aligned.bct
[   4.6813 ]
[   4.6825 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --appendsigheader mem_coldboot_aligned.bct zerosbk
[   4.6836 ] Header already present for mem_coldboot_aligned.bct
[   4.6843 ]
[   4.6855 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --sha sha512
[   4.6857 ] Assuming zero filled SBK key
[   4.6883 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   4.6899 ]
[   4.6903 ] Generating recovery mem-bct
[   4.6912 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp.dtb --wb0sdram tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram_cpp.dtb --membct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_1.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_2.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_3.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_4.bct
[   4.6921 ]  packing sdram params with Wb0 file tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram_cpp.dtb
[   4.7095 ] Packing sdram param for instance[0]
[   4.7097 ] Packing sdram param for instance[1]
[   4.7099 ] Packing sdram param for instance[2]
[   4.7100 ] Packing sdram param for instance[3]
[   4.7102 ] Packing sdram param for instance[4]
[   4.7103 ] Packing sdram param for instance[5]
[   4.7105 ] Packing sdram param for instance[6]
[   4.7107 ] Packing sdram param for instance[7]
[   4.7108 ] Packing sdram param for instance[8]
[   4.7110 ] Packing sdram param for instance[9]
[   4.7111 ] Packing sdram param for instance[10]
[   4.7113 ] Packing sdram param for instance[11]
[   4.7115 ] Packing sdram param for instance[12]
[   4.7117 ] Packing sdram param for instance[13]
[   4.7118 ] Packing sdram param for instance[14]
[   4.7120 ] Packing sdram param for instance[15]
[   4.7258 ]
[   4.7260 ] Reading ramcode from backup chip_info.bin file
[   4.7260 ] RAMCODE Read from Device: 0
[   4.7261 ] Using ramcode 0
[   4.7261 ] Disabled BPMP dtb trim, using default dtb
[   4.7261 ]
[   4.7272 ] tegrahost_v2 --chip 0x23 --align mem_rcm_aligned.bct
[   4.7281 ]
[   4.7290 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --appendsigheader mem_rcm_aligned.bct zerosbk
[   4.7298 ] adding BCH for mem_rcm_aligned.bct
[   4.7319 ]
[   4.7330 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --sha sha512
[   4.7332 ] Assuming zero filled SBK key
[   4.7348 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   4.7360 ]
[   4.7362 ] Copying signatures
[   4.7373 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   5.2552 ]
[   5.2567 ] Boot Rom communication
[   5.2577 ] tegrarcm_v2 --new_session --chip 0x23 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   5.2586 ] BR_CID: 0x80012344705E35DE640000000B018080
[   5.2596 ] Sending bct_br
[   5.2768 ] Sending mb1
[   5.3600 ] Sending psc_bl1
[   5.3671 ] Sending bct_mb1
[   5.3728 ]
[   5.3729 ] Boot Rom communication completed
[   5.3730 ] Generating blob for T23x
[   5.3819 ] tegrahost_v2 --chip 0x23 --align blob_uefi_jetson_with_dtb_aligned.bin
[   5.3828 ]
[   5.3837 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --appendsigheader blob_uefi_jetson_with_dtb_aligned.bin zerosbk
[   5.3845 ] adding BCH for blob_uefi_jetson_with_dtb_aligned.bin
[   5.4798 ]
[   5.4810 ] tegrasign_v3.py --key None --list blob_uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --sha sha512
[   5.4812 ] Assuming zero filled SBK key
[   5.4885 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt blob_uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[   5.4943 ]
[   5.4985 ] tegrahost_v2 --chip 0x23 --align blob_pscfw_t234_prod_aligned.bin
[   5.4996 ]
[   5.5007 ] tegrahost_v2 --chip 0x23 0 --magicid DATA --appendsigheader blob_pscfw_t234_prod_aligned.bin zerosbk
[   5.5017 ] Header already present for blob_pscfw_t234_prod_aligned.bin
[   5.5089 ]
[   5.5100 ] tegrasign_v3.py --key None --list blob_pscfw_t234_prod_aligned_sigheader.bin_list.xml --sha sha512
[   5.5102 ] Assuming zero filled SBK key
[   5.5129 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_pscfw_t234_prod_aligned_sigheader.bin.encrypt blob_pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[   5.5146 ]
[   5.5164 ] tegrahost_v2 --chip 0x23 --align blob_mce_flash_o10_cr_prod_aligned.bin
[   5.5174 ]
[   5.5184 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --appendsigheader blob_mce_flash_o10_cr_prod_aligned.bin zerosbk
[   5.5194 ] Header already present for blob_mce_flash_o10_cr_prod_aligned.bin
[   5.5235 ]
[   5.5247 ] tegrasign_v3.py --key None --list blob_mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --sha sha512
[   5.5249 ] Assuming zero filled SBK key
[   5.5280 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[   5.5299 ]
[   5.5316 ] Generating recovery mb2-bct
[   5.5317 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3701-0000_cpp.dtb
[   5.5341 ]
[   5.5342 ] Updating mb2-bct with storage information
[   5.5355 ] tegrabct_v2 --chip 0x23 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   5.5373 ]
[   5.5374 ] Concatenating mb2-bct to mb2 binary
[   5.5374 ] mb2_bin_file = mb2_t234.bin
[   5.5374 ] mb2_bct_file = mb2_bct_MB2.bct
[   5.5398 ] tegrahost_v2 --chip 0x23 --align blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[   5.5410 ]
[   5.5423 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --appendsigheader blob_mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[   5.5434 ] adding BCH for blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[   5.5614 ]
[   5.5625 ] tegrasign_v3.py --key None --list blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --sha sha512
[   5.5627 ] Assuming zero filled SBK key
[   5.5653 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[   5.5669 ]
[   5.5686 ] tegrahost_v2 --chip 0x23 --align blob_xusb_t234_prod_aligned.bin
[   5.5696 ]
[   5.5706 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --appendsigheader blob_xusb_t234_prod_aligned.bin zerosbk
[   5.5715 ] adding BCH for blob_xusb_t234_prod_aligned.bin
[   5.5792 ]
[   5.5803 ] tegrasign_v3.py --key None --list blob_xusb_t234_prod_aligned_sigheader.bin_list.xml --sha sha512
[   5.5805 ] Assuming zero filled SBK key
[   5.5826 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_xusb_t234_prod_aligned_sigheader.bin.encrypt blob_xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[   5.5840 ]
[   5.5844 ] Concatenating kernel-dtb to dce-fw binary
[   5.5844 ] dce_bin = dce.bin
[   5.5844 ] kernel_dtb = kernel_tegra234-p3701-0000-p3737-0000.dtb
[   5.5844 ] dce_with_dtb = dce_with_kernel_tegra234-p3701-0000-p3737-0000.bin
[   5.5994 ] tegrahost_v2 --chip 0x23 --align blob_dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned.bin
[   5.6004 ]
[   5.6014 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --appendsigheader blob_dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned.bin zerosbk
[   5.6024 ] adding BCH for blob_dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned.bin
[   5.8881 ]
[   5.8893 ] tegrasign_v3.py --key None --list blob_dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned_sigheader.bin_list.xml --sha sha512
[   5.8895 ] Assuming zero filled SBK key
[   5.9096 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned_sigheader.bin.encrypt blob_dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned_sigheader.bin.hash zerosbk
[   5.9219 ]
[   5.9307 ] tegrahost_v2 --chip 0x23 --align blob_nvdec_t234_prod_aligned.fw
[   5.9319 ]
[   5.9329 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --appendsigheader blob_nvdec_t234_prod_aligned.fw zerosbk
[   5.9338 ] Header already present for blob_nvdec_t234_prod_aligned.fw
[   5.9376 ]
[   5.9388 ] tegrasign_v3.py --key None --list blob_nvdec_t234_prod_aligned_sigheader.fw_list.xml --sha sha512
[   5.9390 ] Assuming zero filled SBK key
[   5.9411 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_nvdec_t234_prod_aligned_sigheader.fw.encrypt blob_nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[   5.9428 ]
[   5.9448 ] tegrahost_v2 --chip 0x23 --align blob_bpmp_aligned.bin
[   5.9459 ]
[   5.9469 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --appendsigheader blob_bpmp_aligned.bin zerosbk
[   5.9479 ] adding BCH for blob_bpmp_aligned.bin
[   5.9683 ]
[   5.9695 ] tegrasign_v3.py --key None --list blob_bpmp_aligned_sigheader.bin_list.xml --sha sha512
[   5.9696 ] Assuming zero filled SBK key
[   5.9722 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_bpmp_aligned_sigheader.bin.encrypt blob_bpmp_aligned_sigheader.bin.hash zerosbk
[   5.9740 ]
[   5.9756 ] tegrahost_v2 --chip 0x23 --align blob_tegra234-bpmp-3701-0000-3737-0000_aligned.dtb
[   5.9766 ]
[   5.9778 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --appendsigheader blob_tegra234-bpmp-3701-0000-3737-0000_aligned.dtb zerosbk
[   5.9788 ] adding BCH for blob_tegra234-bpmp-3701-0000-3737-0000_aligned.dtb
[   5.9837 ]
[   5.9848 ] tegrasign_v3.py --key None --list blob_tegra234-bpmp-3701-0000-3737-0000_aligned_sigheader.dtb_list.xml --sha sha512
[   5.9849 ] Assuming zero filled SBK key
[   5.9870 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tegra234-bpmp-3701-0000-3737-0000_aligned_sigheader.dtb.encrypt blob_tegra234-bpmp-3701-0000-3737-0000_aligned_sigheader.dtb.hash zerosbk
[   5.9883 ]
[   5.9898 ] tegrahost_v2 --chip 0x23 --align blob_camera-rtcpu-sce_aligned.img
[   5.9907 ]
[   5.9916 ] tegrahost_v2 --chip 0x23 0 --magicid SCEF --appendsigheader blob_camera-rtcpu-sce_aligned.img zerosbk
[   5.9926 ] adding BCH for blob_camera-rtcpu-sce_aligned.img
[   5.9992 ]
[   6.0003 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-sce_aligned_sigheader.img_list.xml --sha sha512
[   6.0005 ] Assuming zero filled SBK key
[   6.0025 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-sce_aligned_sigheader.img.encrypt blob_camera-rtcpu-sce_aligned_sigheader.img.hash zerosbk
[   6.0038 ]
[   6.0055 ] tegrahost_v2 --chip 0x23 --align blob_camera-rtcpu-t234-rce_aligned.img
[   6.0065 ]
[   6.0074 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --appendsigheader blob_camera-rtcpu-t234-rce_aligned.img zerosbk
[   6.0082 ] adding BCH for blob_camera-rtcpu-t234-rce_aligned.img
[   6.0257 ]
[   6.0269 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --sha sha512
[   6.0271 ] Assuming zero filled SBK key
[   6.0297 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt blob_camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[   6.0314 ]
[   6.0333 ] tegrahost_v2 --chip 0x23 --align blob_adsp-fw_aligned.bin
[   6.0342 ]
[   6.0351 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --appendsigheader blob_adsp-fw_aligned.bin zerosbk
[   6.0360 ] adding BCH for blob_adsp-fw_aligned.bin
[   6.0493 ]
[   6.0504 ] tegrasign_v3.py --key None --list blob_adsp-fw_aligned_sigheader.bin_list.xml --sha sha512
[   6.0506 ] Assuming zero filled SBK key
[   6.0533 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_adsp-fw_aligned_sigheader.bin.encrypt blob_adsp-fw_aligned_sigheader.bin.hash zerosbk
[   6.0551 ]
[   6.0568 ] tegrahost_v2 --chip 0x23 --align blob_spe_t234_aligned.bin
[   6.0578 ]
[   6.0587 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --appendsigheader blob_spe_t234_aligned.bin zerosbk
[   6.0596 ] adding BCH for blob_spe_t234_aligned.bin
[   6.0697 ]
[   6.0708 ] tegrasign_v3.py --key None --list blob_spe_t234_aligned_sigheader.bin_list.xml --sha sha512
[   6.0710 ] Assuming zero filled SBK key
[   6.0731 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_spe_t234_aligned_sigheader.bin.encrypt blob_spe_t234_aligned_sigheader.bin.hash zerosbk
[   6.0746 ]
[   6.0760 ] tegrahost_v2 --chip 0x23 --align blob_tos-mon-only_t234_aligned.img
[   6.0770 ]
[   6.0779 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --appendsigheader blob_tos-mon-only_t234_aligned.img zerosbk
[   6.0788 ] adding BCH for blob_tos-mon-only_t234_aligned.img
[   6.0840 ]
[   6.0852 ] tegrasign_v3.py --key None --list blob_tos-mon-only_t234_aligned_sigheader.img_list.xml --sha sha512
[   6.0855 ] Assuming zero filled SBK key
[   6.0882 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tos-mon-only_t234_aligned_sigheader.img.encrypt blob_tos-mon-only_t234_aligned_sigheader.img.hash zerosbk
[   6.0897 ]
[   6.0912 ] tegrahost_v2 --chip 0x23 --align blob_eks_aligned.img
[   6.0923 ]
[   6.0934 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --appendsigheader blob_eks_aligned.img zerosbk
[   6.0944 ] adding BCH for blob_eks_aligned.img
[   6.0949 ]
[   6.0960 ] tegrasign_v3.py --key None --list blob_eks_aligned_sigheader.img_list.xml --sha sha512
[   6.0962 ] Assuming zero filled SBK key
[   6.0982 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_eks_aligned_sigheader.img.encrypt blob_eks_aligned_sigheader.img.hash zerosbk
[   6.0994 ]
[   6.1007 ] tegrahost_v2 --chip 0x23 --generateblob blob.xml blob.bin
[   6.1015 ] The number of images in blob is 16
[   6.1018 ] blobsize is 16226944
[   6.1019 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3115968
[   6.1095 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 366592
[   6.1101 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 179856
[   6.1105 ] Added binary blob_applet_t234.bin of size 269184
[   6.1107 ] Not supported type: mb2_applet
[   6.1108 ] Added binary blob_mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt of size 440640
[   6.1112 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164352
[   6.1115 ] Added binary blob_dce_with_kernel_tegra234-p3701-0000-p3737-0000_sigheader.bin.encrypt of size 9306624
[   6.1159 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 225280
[   6.1173 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 542608
[   6.1175 ] Added binary blob_tegra234-bpmp-3701-0000-3737-0000_sigheader.dtb.encrypt of size 140160
[   6.1179 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166192
[   6.1182 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 521568
[   6.1186 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 399360
[   6.1189 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   6.1191 ] Added binary blob_tos-mon-only_t234_sigheader.img.encrypt of size 107888
[   6.1195 ] Added binary blob_eks_sigheader.img.encrypt of size 9232
[   6.1257 ]
[   6.1258 ] Sending membct and RCM blob
[   6.1269 ] tegrarcm_v2 --chip 0x23 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   6.1277 ] BL: version 0.11.0.0-t234-54845784-7fb1fa27 last_boot_error: 0
[   6.1284 ] Sending bct_mem
[   6.1408 ] Sending blob
[   7.4880 ]
[   7.4880 ] completed
[   7.4881 ] Retrieving storage infomation
[   7.4909 ] tegrarcm_v2 --chip 0x23 --oem platformdetails storage storage_info.bin
[   7.4932 ] Applet/MB2 is not running on device.
[   7.5601 ]
[   7.5602 ] Error: failed to get storage info
[   8.5656 ] tegrarcm_v2 --chip 0x23 --ismb2applet
Did you remember to set the eeprom read size of the CVB to 0 in your mb2 config?
Yes, the set is right, and I use Orin devkit som on our custom cvb flash and bootup is success. But ths SOM we just get is not working.
tegra234-mb2-bct-common.dtsi
        eeprom {
            cvm_eeprom_i2c_instance = <0>;
            cvm_eeprom_i2c_slave_address = <0xa0>;
            cvm_eeprom_read_size = <0x100>;
            cvb_eeprom_i2c_instance = <0x0>;
            cvb_eeprom_i2c_slave_address = <0xac>;
            cvb_eeprom_read_size = <0x0>;
Then I think it is board design issue.
Hi WayneWWW,
It’s not the board design issue.
I use Orin Devkit CVB and the Orin SOM(not Devkit SOM) still can’t flash to this SOM, and get the same error.
Oh ok. Sorry that I didn’t notice you also flash it with devkit.
Could you share me the uart log when you flash the SOM on devkit?
Please refer to the uart log .
sz@twsrv01:~$ sudo minicom -D /dev/ttyACM0
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyACM0, 13:38:56
Press CTRL-A Z for help on special keys
[0003.072] I> MB1 (version: 0.11.0.0-t234-54845784-7fb1fa27)
[0003.077] I> t234-A01-0-Silicon (0x12347) Prod
[0003.081] I> Boot-mode : BPMP Diagnostic
[0003.085] I> Emulation:
[0003.087] I> Entry timestamp: 0x00000000
[0003.091] I> last_boot_error: 0x0
[0003.094] I> BR-BCT: preprod_dev_sign: 0
[0003.098] I> rst_source: 0x0, rst_level: 0x0
[0003.102] I> Task: Clocks enable (0x50011b9d)
[0003.106] I> Task: Crypto init (0x50018df5)
[0003.110] I> Task: Secure debug controls (0x5000c76d)
[0003.115] E> Error: ECID of check failed!!
[0003.119] E> Error: ECID of check failed!!
[0003.123] E> Error: ECID of check failed!!
[0003.127] E> Error: ECID of check failed!!
[0003.131] I> Task: Program NV master stream id (0x5000c725)
[0003.137] I> Task: Verify boot mode (0xd482021)
[0003.145] I> Task: Alias fuses (0x5000ecd5)
[0003.149] E> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0003.156] I> Task: 0x5000e911
[0003.159] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000038
[0003.164] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0003.169] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0003.173] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0003.177] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0003.181] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0003.185] I> FUSE_SKU_INFO_0 = 0xd2
[0003.189] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0003.193] I> FUSE_PACKAGE_INFO_0 = 0x2
[0003.196] I> SKU: INVALID
[0003.199] I> Task: Voltage monitor (0x50011ba5)
[0003.203] E> Invalid sku info[0003.206] I> VMON: Vmon re-calibration and fine tuning done
[0003.211] I> Task: Blockdev init (0x500157e1)
[0003.215] I> Task: UPHY init (0x5001b42d)
[0003.220] E> UPHY: UPHY lane info table is empty in MB1 BCT.
[0003.226] I> Task: Boot device init (0x5000d6a9)
[0003.230] E> Adding eMMC storage modules
[0003.234] I> Boot-device: RCM (instance: 0)
[0003.238] I> USB configuration success
[0003.242] I> Task: TSC init (0x5001c7e1)
[0003.246] I> Task: Enable WDT 5th expiry (0x5001d27d)
[0003.251] I> Task: Disable WDT globally (0x5001d2b9)
[0003.255] I> Task: I2C register (0x50000a09)
[0003.260] I> Task: Reset FSI (0x50011ba1)
[0003.263] I> Task: Enable clock-mon (0x5001c301)
[0003.279] I> FMON: Fmon re-programmed in mb1
[0003.283] I> Task: MB1 fixed firewalls (0x5001b1bd)
[0003.289] I> Task: Load MB2/Applet/FSKP (0x5001c305)
[0003.294] I> Loading MB2 Applet
[0003.297] I> Scratch RSV109: 0x00000000    active chain: 0
[0003.303] I> Slot: 0
[0003.305] I> Binary[21] block-0 (partition size: 0x50000)
[0003.310] I>  get_binary_info: Binary name: MB2-Applet
[0003.315] I> Size of crypto header is 8192
[0003.319] I> BCH load address is : 0x4004e000
[0003.323] I> Size of crypto header is 8192
[0003.327] I> BCH of MB2-Applet read from storage
[0003.332] I> BCH address is : 0x4004e000
[0003.336] I> MB2-Applet header integrity check is success
[0003.341] I> Binary magic in BCH component 0 is MB2A
[0003.346] I> component binary type is 21
[0003.349] I> Size of crypto header is 8192
[0003.361] I> MB2-Applet binary is read from storage
[0003.366] I> MB2-Applet binary integrity check is success
[0003.371] I> Binary MB2-Applet loaded successfully at 0x40000000 (0x41b80)
[0003.378] I> Task: Prepare MB2 params (0x5001c3d5)
[0003.383] I> MB2-params @ 0x40060000
[0003.387] I> BR-BCT Boot Chain Fields
[0003.390] I>    u32_non_gpio_select_boot_chain  : 0
[0003.395] I>    u32_num_boot_chains             : 0
[0003.400] I>    bf_bl_gpio_select_boot_chain_1b : 0
[0003.404] I> Task: Misc NV security settings (0x5000ca35)
[0003.410] I> NVDEC sticky bits programming done
[0003.414] I> Task: Disable/Reload WDT (0x5001d2e9)
[0003.419] I> Programmed SLCG global override := 0x0
[0003.423] I> MB1: MSS reconfig completed
I> Applet (version: 0.0.0.0-t234-54845784-6c7023cc)
I> Emulation:
I> Entry timestamp: 0xffffffff
I> Task: Pinmux init (0x4000062d)
I> Task: Boot device init (0x400012e5)
I> Applet do storage init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : clk_m
I> QSPI-0l initialized successfully
I> qspi flash-0 params source = safe params
I> sdmmc DDR50 mode
I> sdmmc-3 params source = safe params
I> sdmmc bdev is already initialized
E> mb2_config_storage_init_one_device: failed: Unknown device 7
I> Task: Partition Manager Init (0x40002cf5)
W> Cannot find any partition table for 00030000
 > PARTITION_MANAGER: Failed to publish partition.
W> Cannot find any partition table for 00000003
W> Cannot find any partition table for 00010003
I> Task: I2C register (0x400006a5)
I> Task: Register exit handlers (0x400005f5)
I> Task: Enter 3p server (0x400018b5)
I> Populate chip info
I> RAM_CODE 0x4000001
I> Populate eeprom info
I> Populate eeprom info for module cvm
I> dump bct
I> Rebooting : reboot-recovery
E> instance 0 not supported for module 8
[0015.757] I> MB1 (version: 0.11.0.0-t234-54845784-7fb1fa27)
[0015.762] I> t234-A01-0-Silicon (0x12347) Prod
[0015.766] I> Boot-mode : Coldboot
[0015.769] I> Emulation:
[0015.772] I> Entry timestamp: 0x00000000
[0015.776] I> last_boot_error: 0x0
[0015.779] I> BR-BCT: preprod_dev_sign: 0
[0015.782] I> rst_source: 0xb, rst_level: 0x1
[0015.787] I> Task: Clocks enable (0x50011b9d)
[0015.791] I> Task: Crypto init (0x50018df5)
[0015.795] I> Task: Secure debug controls (0x5000c76d)
[0015.800] E> Error: ECID of check failed!!
[0015.804] E> Error: ECID of check failed!!
[0015.808] E> Error: ECID of check failed!!
[0015.812] E> Error: ECID of check failed!!
[0015.816] I> Task: Program NV master stream id (0x5000c725)
[0015.821] I> Task: Verify boot mode (0xd482021)
[0015.829] I> Task: Alias fuses (0x5000ecd5)
[0015.834] E> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0015.841] I> Task: 0x5000e911
[0015.844] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000038
[0015.849] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0015.853] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0015.858] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0015.862] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0015.866] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0015.870] I> FUSE_SKU_INFO_0 = 0xd2
[0015.873] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0015.878] I> FUSE_PACKAGE_INFO_0 = 0x2
[0015.881] I> SKU: INVALID
[0015.884] I> Task: Voltage monitor (0x50011ba5)
[0015.888] E> Invalid sku info[0015.891] I> VMON: Vmon re-calibration and fine tuning done
[0015.896] I> Task: Blockdev init (0x500157e1)
[0015.900] I> Task: UPHY init (0x5001b42d)
[0015.905] E> UPHY: UPHY lane info table is empty in MB1 BCT.
[0015.910] I> Task: Boot device init (0x5000d6a9)
[0015.915] E> Adding eMMC storage modules
[0015.919] I> Boot-device: RCM (instance: 0)
[0015.923] I> USB configuration success
[0016.498] I> Task: TSC init (0x5001c7e1)
[0016.502] I> Task: Enable WDT 5th expiry (0x5001d27d)
[0016.507] I> Task: Disable WDT globally (0x5001d2b9)
[0016.511] I> Task: I2C register (0x50000a09)
[0016.515] I> Task: Reset FSI (0x50011ba1)
[0016.519] I> Task: Pinmux init (0x50010e95)
[0016.524] I> Task: Prod config init (0x50011075)
[0016.528] I> Task: Pad voltage init (0x50010f85)
[0016.533] I> Task: Prod init (0x50011119)
[0016.537] I> Task: Thermal check (0x5001121d)
[0016.541] I> max_chip_limit = 115
[0016.544] I> min_chip_limit = -30
[0016.557] I> max temp read = 28
[0016.560] I> min temp read = 25
[0016.563] I> Task: Common rail init (0x50011695)
[0016.568] W>  Thermal config not found in BCT
[0016.572] W>  Generic i2c config not found in BCT
[0016.578]  > DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0016.586] W>  MEMIO rail config not found in BCT
[0016.590] I> Task: Mem clock src (0x5000f6b9)
[0016.594] I> Task: BR PMIC seq (0x50011711)
[0016.599] I> Task: Misc. board config (0x500116ed)
[0016.603] W>  Platform config not found in BCT
[0016.607] I> Task: Load membct (0x5000f5d5)
[0016.611] I> RAM_CODE 0x4000001
[0016.615] I> Loading MEM-BCT to SysRAM
[0016.618] I> Scratch RSV109: 0x00000000    active chain: 0
[0016.623] I> Slot: 0
[0016.625] I> Binary[0] block-0 (partition size: 0x40000)
[0016.631] I>  get_binary_info: Binary name: MEM-BCT-0
[0016.635] I> Size of crypto header is 8192
[0016.639] I> BCH load address is : 0x40050000
[0016.644] I> Size of crypto header is 8192
[0016.648] I> BCH of MEM-BCT-0 read from storage
[0016.652] I> BCH address is : 0x40050000
[0016.656] I> MEM-BCT-0 header integrity check is success
[0016.661] I> Binary magic in BCH component 0 is MEM0
[0016.666] I> component binary type is 0
[0016.672] I> MEM-BCT-0 binary is read from storage
[0016.676] I> MEM-BCT-0 binary integrity check is success
[0016.682] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0016.692] I> RAM_CODE 0x4000001
[0016.696] I> Task: Save mem-bct info (0x50011d59)
[0016.700] I> Task: SDRAM params override (0x50010c79)
[0016.705] I> Task: Carveout allocate (0x50011da5)
[0016.710] I> ECC region[0]: Start:0x0, End:0x0
[0016.714] I> ECC region[1]: Start:0x0, End:0x0
[0016.718] I> ECC region[2]: Start:0x0, End:0x0
[0016.723] I> ECC region[3]: Start:0x0, End:0x0
[0016.727] I> ECC region[4]: Start:0x0, End:0x0
[0016.731] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0016.737] I> Non-ECC region[1]: Start:0x0, End:0x0
[0016.742] I> Non-ECC region[2]: Start:0x0, End:0x0
[0016.746] I> Non-ECC region[3]: Start:0x0, End:0x0
[0016.751] I> Non-ECC region[4]: Start:0x0, End:0x0
[0016.758] I> allocated(CO:51) base:0x80000000 size:0x8000000 align: 0x200000
[0016.765] I> allocated(CO:44) base:0xd6000000 size:0x2a000000 align: 0x100000
[0016.772] I> allocated(CO:46) base:0xa0000000 size:0x20000000 align: 0x20000000
[0016.779] I> allocated(CO:31) base:0xce000000 size:0x8000000 align: 0x100000
[0016.786] I> allocated(CO:39) base:0xc8000000 size:0x6000000 align: 0x200000
[0016.793] I> allocated(CO:20) base:0xc6000000 size:0x2000000 align: 0x2000000
[0016.800] I> allocated(CO:24) base:0xc4000000 size:0x2000000 align: 0x2000000
[0016.807] I> allocated(CO:28) base:0xc2000000 size:0x2000000 align: 0x2000000
[0016.814] I> allocated(CO:29) base:0xc0000000 size:0x2000000 align: 0x2000000
[0016.821] I> allocated(CO:41) base:0x9f000000 size:0x1000000 align: 0x100000
[0016.828] I> allocated(CO:43) base:0x9e000000 size:0x1000000 align: 0x200000
[0016.835] I> allocated(CO:02) base:0x9d800000 size:0x800000 align: 0x800000
[0016.842] I> allocated(CO:03) base:0x9d000000 size:0x800000 align: 0x800000
[0016.848] I> allocated(CO:06) base:0x9c800000 size:0x800000 align: 0x800000
[0016.855] I> allocated(CO:10) base:0x9c000000 size:0x800000 align: 0x800000
[0016.862] I> allocated(CO:56) base:0x9b800000 size:0x800000 align: 0x200000
[0016.869] I> allocated(CO:07) base:0x9b400000 size:0x400000 align: 0x400000
[0016.876] I> allocated(CO:22) base:0x9b000000 size:0x400000 align: 0x400000
[0016.883] I> allocated(CO:33) base:0x9ac00000 size:0x400000 align: 0x200000
[0016.889] I> allocated(CO:47) base:0x9a800000 size:0x400000 align: 0x200000
[0016.896] I> allocated(CO:01) base:0x9a700000 size:0x100000 align: 0x100000
[0016.903] I> allocated(CO:04) base:0x9a600000 size:0x100000 align: 0x100000
[0016.910] I> allocated(CO:05) base:0x9a500000 size:0x100000 align: 0x100000
[0016.917] I> allocated(CO:08) base:0x9a400000 size:0x100000 align: 0x100000
[0016.924] I> allocated(CO:09) base:0x9a300000 size:0x100000 align: 0x100000
[0016.930] I> allocated(CO:15) base:0x9a200000 size:0x100000 align: 0x100000
[0016.937] I> allocated(CO:17) base:0x9a100000 size:0x100000 align: 0x100000
[0016.944] I> allocated(CO:23) base:0x9a000000 size:0x100000 align: 0x100000
[0016.951] I> allocated(CO:27) base:0x99f00000 size:0x100000 align: 0x100000
[0016.958] I> allocated(CO:42) base:0x99e00000 size:0x100000 align: 0x100000
[0016.965] I> allocated(CO:54) base:0x99d80000 size:0x80000 align: 0x80000
[0016.971] I> allocated(CO:26) base:0x99d40000 size:0x40000 align: 0x2000
[0016.978] I> allocated(CO:48) base:0x99d20000 size:0x20000 align: 0x10000
[0016.984] I> allocated(CO:34) base:0x99d10000 size:0x10000 align: 0x10000
[0016.991] I> allocated(CO:35) base:0x99d00000 size:0x10000 align: 0x10000
[0016.998] I> allocated(CO:49) base:0x99cf0000 size:0x10000 align: 0x10000
[0017.004] I> allocated(CO:50) base:0x99ce0000 size:0x10000 align: 0x10000
[0017.011] I> allocated(CO:52) base:0x99cd0000 size:0x10000 align: 0x10000
[0017.018] I> Task: SDRAM init (0x5000f6bd)
[0017.024] I> SDRAM-params @ 0xd485000
[0017.028] I> MSS code-drop: NvBootSdramInit
[0017.032] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0017.039] I> MSS CAR: Init PLLM
[0017.042] I> MSS CAR: Init PLLHUB
[0017.053] I> mb1_sdram_init Done !
[0017.056] I> SDRAM Size in Total 800000000
[0017.060] I> SDRAM test pass
[0017.063] I> Task: Dram ecc scrub (0x5000f2c9)
[0017.067] I> Task: DRAM alias check (0x50010c71)
[0017.283] I> Task: Register checker (0x50010c75)
[0017.292] I> Task: Enable clock-mon (0x5001c301)
[0017.309] I> FMON: Fmon re-programmed in mb1
[0017.314] I> Task: Mapper init (0x5001a0d5)
[0017.319] I> Task: SC7 Context Init (0x5001cacd)
[0017.325] I> Task: CCPLEX IST init (0x5000ce75)
[0017.331] I> Task: CPU WP0 (0x5000c2c9)
[0017.336] I> Loading MCE
[0017.339] I> Scratch RSV109: 0x00000000    active chain: 0
[0017.345] I> Slot: 0
[0017.348] I> Binary[8] block-0 (partition size: 0x80000)
[0017.354] I>  get_binary_info: Binary name: MCE
[0017.359] I> Size of crypto header is 8192
[0017.363] I> BCH load address is : 0x4003e000
[0017.369] I> Size of crypto header is 8192
[0017.851] I> BCH of MCE read from storage
[0017.855] I> BCH address is : 0x4003e000
[0017.861] I> MCE header integrity check is success
[0017.866] I> Binary magic in BCH component 0 is MTSM
[0017.872] I> component binary type is 8
[0017.876] I> Size of crypto header is 8192
[0017.885] I> MCE binary is read from storage
[0017.890] I> MCE binary integrity check is success
[0017.896] I> Binary MCE loaded successfully at 0x40000000 (0x29e90)
[0017.904] E> Invalid sku info[0017.907] I> Size of crypto header is 8192
[0017.912] I> Sending WP0 mailbox command to PSC
Does it just stuck here and never reset?
Hi WayneWWW,
Yes. Stuck and no reset.
sz@twsrv01:~$ lsusb
Bus 003 Device 055: ID 0955:7223 NVidia Corp.
Bus 003 Device 047: ID 0955:7045 NVidia Corp.
We will check.
Hi dennis.jiang,
Do you get 32GB Orin module? if so , you need to wait for JP5.0 EA which will be released these days, do not try it on JP5.0、JP5.0.1 DP
Hi Jeffli,
We have got JP5.0GA EA and now the SOM can be flashed now
Thanks for you information.
