There is no problem with the first two steps; This is the third step, namely:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 1
The command does not report an error, and prompts that the machine was successfully flushed, but the machine cannot be started, and the serial port does not output any log
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
Sorry for the late response, is this still an issue to support? Thanks
