We used JetPack 5.1.3 and came across the OS hang issue.
The console log is attached.
Could you please give some hints to know the reason of the OS hang issue ?
000.066] I> MB1 (version: 1.4.0.1-t234-54845784-08e631ca)
[0000.071] I> t234-A01-1-Silicon (0x12347) Prod
[0000.075] I> Boot-mode : Coldboot
[0000.079] I> Entry timestamp: 0x00000000
[0000.082] I> last_boot_error: 0x0
[0000.085] I> BR-BCT: preprod_dev_sign: 0
[0000.089] I> rst_source: 0x0, rst_level: 0x0
[0000.093] I> Task: SE error check
[0000.097] I> Task: Bootchain select WAR set
[0000.101] I> Task: Enable SLCG
[0000.103] I> Task: CRC check
[0000.106] I> Task: Initialize MB2 params
[0000.111] I> MB2-params @ 0x40060000
[0000.114] I> Task: Crypto init
[0000.117] I> Task: Perform MB1 KAT tests
[0000.121] I> Task: NVRNG health check
[0000.124] I> NVRNG: Health check success
[0000.128] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.134] I> Task: Enabling and initialization of Bandwidth limiter
[0000.140] I> No request to configure MBWT settings for any PC!
[0000.146] I> Task: Secure debug controls
[0000.150] I> Task: strap war set
[0000.153] I> Task: Initialize SOC Therm
[0000.157] I> Task: Program NV master stream id
[0000.161] I> Task: Verify boot mode
[0000.167] I> Task: Alias fuses
[0000.170] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.178] I> Task: Print SKU type
[0000.181] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.186] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.190] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.195] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.199] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.203] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.208] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.212] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.216] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.221] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.225] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.229] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.233] I> FUSE_SKU_INFO_0 = 0xd0
[0000.236] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.240] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.244] I> SKU: Prod
[0000.246] I> Task: Boost clocks
[0000.249] I> Initializing PLLC2 for AXI_CBB.
[0000.253] I> AXI_CBB : src = 35, divisor = 0
[0000.258] I> Task: Voltage monitor
[0000.261] I> VMON: Vmon re-calibration and fine tuning done
[0000.266] I> Task: UPHY init
[0000.271] I> HSIO UPHY init done
[0000.274] W> Skipping GBE UPHY config
[0000.278] I> Task: Boot device init
[0000.281] I> Boot_device: QSPI_FLASH instance: 0
[0000.286] I> Qspi clock source : pllc_out0
[0000.290] I> QSPI Flash: Macronix 64MB
[0000.293] I> QSPI-0l initialized successfully
[0000.298] I> Task: TSC init
[0000.301] I> Task: Load membct
[0000.303] I> RAM_CODE 0x4000431
[0000.306] I> Loading MEMBCT
[0000.309] I> Slot: 0
[0000.311] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.317] I> Binary name: MEM-BCT-0
[0000.320] I> Size of crypto header is 8192
[0000.324] I> Size of crypto header is 8192
[0000.328] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.334] I> BCH of MEM-BCT-0 read from storage
[0000.338] I> BCH address is : 0x40050000
[0000.342] I> MEM-BCT-0 header integrity check is success
[0000.347] I> Binary magic in BCH component 0 is MEM0
[0000.352] I> component binary type is 0
[0000.356] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.363] I> MEM-BCT-0 binary is read from storage
[0000.368] I> MEM-BCT-0 binary integrity check is success
[0000.373] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.379] I> RAM_CODE 0x4000431
[0000.385] I> RAM_CODE 0x4000431
[0000.389] I> Task: Load Page retirement list
[0000.393] I> Task: SDRAM params override
[0000.397] I> Task: Save mem-bct info
[0000.400] I> Task: Carveout allocate
[0000.403] I> RCM blob carveout will not be allocated
[0000.408] I> Update CCPLEX IST carveout from MB1-BCT
[0000.413] I> ECC region[0]: Start:0x0, End:0x0
[0000.417] I> ECC region[1]: Start:0x0, End:0x0
[0000.422] I> ECC region[2]: Start:0x0, End:0x0
[0000.426] I> ECC region[3]: Start:0x0, End:0x0
[0000.430] I> ECC region[4]: Start:0x0, End:0x0
[0000.434] I> Non-ECC region[0]: Start:0x80000000, End:0x1080000000
[0000.441] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.445] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.450] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.454] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.465] I> allocated(CO:44) base:0x1049800000 size:0x36800000 align: 0x100000
[0000.472] I> allocated(CO:31) base:0x1040000000 size:0x8000000 align: 0x8000000
[0000.480] I> allocated(CO:43) base:0x103c000000 size:0x4000000 align: 0x200000
[0000.487] I> allocated(CO:39) base:0x1039e00000 size:0x2200000 align: 0x10000
[0000.494] I> allocated(CO:20) base:0x1036000000 size:0x2000000 align: 0x2000000
[0000.501] I> allocated(CO:24) base:0x1034000000 size:0x2000000 align: 0x2000000
[0000.508] I> allocated(CO:28) base:0x1032000000 size:0x2000000 align: 0x2000000
[0000.515] I> allocated(CO:29) base:0x1030000000 size:0x2000000 align: 0x2000000
[0000.523] I> allocated(CO:22) base:0x1048000000 size:0x1000000 align: 0x1000000
[0000.530] I> allocated(CO:41) base:0x1038e00000 size:0x1000000 align: 0x100000
[0000.537] I> allocated(CO:35) base:0x1038000000 size:0xe00000 align: 0x10000
[0000.544] I> allocated(CO:02) base:0x1049000000 size:0x800000 align: 0x800000
[0000.551] I> allocated(CO:03) base:0x102f800000 size:0x800000 align: 0x800000
[0000.558] I> allocated(CO:06) base:0x102f000000 size:0x800000 align: 0x800000
[0000.565] I> allocated(CO:56) base:0x102e800000 size:0x800000 align: 0x200000
[0000.572] I> allocated(CO:07) base:0x102e400000 size:0x400000 align: 0x400000
[0000.579] I> allocated(CO:33) base:0x102e000000 size:0x400000 align: 0x200000
[0000.586] I> allocated(CO:23) base:0x102de00000 size:0x200000 align: 0x200000
[0000.593] I> allocated(CO:01) base:0x102dd00000 size:0x100000 align: 0x100000
[0000.600] I> allocated(CO:05) base:0x102dc00000 size:0x100000 align: 0x100000
[0000.607] I> allocated(CO:08) base:0x102db00000 size:0x100000 align: 0x100000
[0000.614] I> allocated(CO:09) base:0x102da00000 size:0x100000 align: 0x100000
[0000.621] I> allocated(CO:15) base:0x102d900000 size:0x100000 align: 0x100000
[0000.628] I> allocated(CO:17) base:0x102d800000 size:0x100000 align: 0x100000
[0000.635] I> allocated(CO:27) base:0x102d700000 size:0x100000 align: 0x100000
[0000.642] I> allocated(CO:42) base:0x102d600000 size:0x100000 align: 0x100000
[0000.649] I> allocated(CO:54) base:0x102d580000 size:0x80000 align: 0x80000
[0000.656] I> allocated(CO:34) base:0x102d570000 size:0x10000 align: 0x10000
[0000.663] I> allocated(CO:72) base:0x102d370000 size:0x200000 align: 0x10000
[0000.670] I> allocated(CO:47) base:0x102ce00000 size:0x400000 align: 0x200000
[0000.677] I> allocated(CO:48) base:0x102d350000 size:0x20000 align: 0x10000
[0000.684] I> allocated(CO:69) base:0x102d330000 size:0x20000 align: 0x10000
[0000.691] I> allocated(CO:49) base:0x102d320000 size:0x10000 align: 0x10000
[0000.697] I> allocated(CO:50) base:0x102d310000 size:0x10000 align: 0x10000
[0000.704] I> allocated(CO:52) base:0x102d300000 size:0x10000 align: 0x10000
[0000.711] I> NSDRAM base: 0x80000000, end: 0x102d370000, size: 0xfad370000
[0000.718] I> Task: Thermal check
[0000.721] I> max_chip_limit = 105
[0000.724] I> min_chip_limit = -28
[0000.727] I> max temp read = 41
[0000.730] I> min temp read = 40
[0000.733] I> Task: Update FSI SCR with thermal fuse data
[0000.738] I> Task: Enable WDT 5th expiry
[0000.742] I> Task: I2C register
[0000.745] I> Task: Set I2C bus freq
[0000.749] I> Task: Reset FSI
[0000.751] I> Task: Pinmux init
[0000.755] I> Task: Prod config init
[0000.758] I> Task: Pad voltage init
[0000.761] I> Task: Prod init
[0000.764] I> Task: Program rst req config reg
[0000.768] I> Task: Common rail init
[0000.772] I> DONE: Thermal config
[0000.776] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.784] I> DONE: SOC rail config
[0000.788] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.794] I> DONE: MEMIO rail config
[0000.798] I> DONE: GPU rail info
[0000.801] I> DONE: CV rail info
[0000.804] I> Task: Mem clock src
[0000.807] I> Task: Misc. board config
[0000.811] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.817] I> Task: SDRAM init
[0000.819] I> MemoryType: 4 MemBctRevision: 8
[0000.826] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0000.834] I> MSS CAR: Init PLLM
[0000.837] I> MSS CAR: Init PLLHUB
[0000.841] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.853] I> SDRAM initialized!
[0000.856] I> SDRAM Size in Total 0x1000000000
[0000.860] I> Task: Dram Ecc scrub
[0000.863] I> Task: DRAM alias check
[0000.880] I> Task: Program NSDRAM carveout
[0000.884] I> NSDRAM carveout encryption is enabled
[0000.888] I> Program NSDRAM carveout
[0000.892] I> Task: Register checker
[0000.895] I> Task: Enable clock-mon
[0000.910] I> FMON: Fmon re-programming done
[0000.914] I> Task: Mapper init
[0000.917] I> Task: SC7 Context Init
[0000.920] I> Task: CCPLEX IST init
[0000.923] I> Task: CPU WP0
[0000.926] I> Loading MCE
[0000.929] I> Slot: 0
[0000.931] I> Binary[8] block-22784 (partition size: 0x80000)
[0000.936] I> Binary name: MCE
[0000.939] I> Size of crypto header is 8192
[0000.943] I> Size of crypto header is 8192
[0000.947] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0000.953] I> BCH of MCE read from storage
[0000.957] I> BCH address is : 0x4003e000
[0000.961] I> MCE header integrity check is success
[0000.966] I> Binary magic in BCH component 0 is MTSM
[0000.970] I> component binary type is 8
[0000.974] I> Size of crypto header is 8192
[0000.978] I> strt_pg_num(22800) num_of_pgs(357) read_buf(0x40000000)
[0000.986] I> MCE binary is read from storage
[0000.991] I> MCE binary integrity check is success
[0000.996] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.002] I> Size of crypto header is 8192
[0001.013] I> Size of crypto header is 8192
[0001.017] I> Sending WP0 mailbox command to PSC
[0001.026] I> Task: XUSB Powergate
[0001.029] I> Skipping powergate XUSB.
[0001.032] I> Task: MB1 fixed firewalls
[0001.039] W> Firewall readback mismatch
[0001.044] I> Task: Load bpmp-fw
[0001.047] I> Slot: 0
[0001.049] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.054] I> Binary name: BPMP_FW
[0001.058] I> Size of crypto header is 8192
[0001.062] I> Size of crypto header is 8192
[0001.065] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.072] I> BCH of BPMP_FW read from storage
[0001.076] I> BCH address is : 0x807fe000
[0001.080] I> BPMP_FW header integrity check is success
[0001.085] I> Binary magic in BCH component 0 is BPMF
[0001.089] I> component binary type is 15
[0001.093] I> Size of crypto header is 8192
[0001.097] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.115] I> BPMP_FW binary is read from storage
[0001.121] I> BPMP_FW binary integrity check is success
[0001.126] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.133] I> Slot: 0
[0001.135] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.140] I> Binary name: BPMP_FW_DTB
[0001.144] I> Size of crypto header is 8192
[0001.148] I> Size of crypto header is 8192
[0001.152] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.158] I> BCH of BPMP_FW_DTB read from storage
[0001.162] I> BCH address is : 0x807fc000
[0001.166] I> BPMP_FW_DTB header integrity check is success
[0001.172] I> Binary magic in BCH component 0 is BPMD
[0001.176] I> component binary type is 16
[0001.180] I> Size of crypto header is 8192
[0001.184] I> strt_pg_num(13072) num_of_pgs(259) read_buf(0x807db9f0)
[0001.192] I> BPMP_FW_DTB binary is read from storage
[0001.197] I> BPMP_FW_DTB binary integrity check is success
[0001.202] I> Binary BPMP_FW_DTB loaded successfully at 0x807db9f0 (0x20440)
[0001.209] I> Task: BPMP fw ast config
[0001.213] I> Task: Load psc-fw
[0001.216] I> Slot: 0
[0001.218] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.223] I> Binary name: PSC_FW
[0001.226] I> Size of crypto header is 8192
[0001.230] I> Size of crypto header is 8192
[0001.234] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.240] I> BCH of PSC_FW read from storage
[0001.244] I> BCH address is : 0x80ffe000
[0001.248] I> PSC_FW header integrity check is success
[0001.253] I> Binary magic in BCH component 0 is PFWP
[0001.258] I> component binary type is 17
[0001.262] I> Size of crypto header is 8192
[0001.266] I> strt_pg_num(21264) num_of_pgs(717) read_buf(0x80fa4600)
[0001.276] I> PSC_FW binary is read from storage
[0001.281] I> PSC_FW binary integrity check is success
[0001.286] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[0001.292] I> Task: Load nvdec-fw
[0001.295] I> Slot: 0
[0001.297] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.303] I> Binary name: NVDEC
[0001.306] I> Size of crypto header is 8192
[0001.310] I> Size of crypto header is 8192
[0001.314] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.320] I> BCH of NVDEC read from storage
[0001.324] I> BCH address is : 0x800fe000
[0001.328] I> NVDEC header integrity check is success
[0001.333] I> Binary magic in BCH component 0 is NDEC
[0001.337] I> component binary type is 7
[0001.341] I> Size of crypto header is 8192
[0001.345] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.354] I> NVDEC binary is read from storage
[0001.359] I> NVDEC binary integrity check is success
[0001.364] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.370] I> Size of crypto header is 8192
[0001.382] I> Task: Load tsec-fw
[0001.385] I> TSEC-FW load support not enabled
[0001.389] I> Task: GPIO interrupt map
[0001.393] I> Task: SC7 context save
[0001.396] I> Slot: 0
[0001.398] I> Binary[27] block-0 (partition size: 0x100000)
[0001.403] I> Binary name: BR_BCT
[0001.406] I> Size of crypto header is 8192
[0001.410] I> Size of crypto header is 8192
[0001.414] I> Size of crypto header is 8192
[0001.418] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.424] I> BR_BCT binary is read from storage
[0001.429] I> BR_BCT binary integrity check is success
[0001.433] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.440] I> Slot: 0
[0001.442] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.447] I> Binary name: SC7-FW
[0001.450] I> Size of crypto header is 8192
[0001.454] I> Size of crypto header is 8192
[0001.458] I> Size of crypto header is 8192
[0001.462] I> Size of crypto header is 8192
[0001.466] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.472] I> BCH of SC7-FW read from storage
[0001.476] I> BCH address is : 0xa0002000
[0001.480] I> SC7-FW header integrity check is success
[0001.485] I> Binary magic in BCH component 0 is WB0B
[0001.490] I> component binary type is 13
[0001.494] I> Size of crypto header is 8192
[0001.498] I> strt_pg_num(23824) num_of_pgs(347) read_buf(0xa0004000)
[0001.506] I> SC7-FW binary is read from storage
[0001.511] I> SC7-FW binary integrity check is success
[0001.516] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b440)
[0001.522] I> Slot: 0
[0001.524] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.530] I> Binary name: PSC_RF
[0001.533] I> Size of crypto header is 8192
[0001.537] I> Size of crypto header is 8192
[0001.540] I> Size of crypto header is 8192
[0001.544] I> Size of crypto header is 8192
[0001.548] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002f440)
[0001.555] I> BCH of PSC_RF read from storage
[0001.559] I> BCH address is : 0xa002f440
[0001.563] I> PSC_RF header integrity check is success
[0001.567] I> Binary magic in BCH component 0 is PSCR
[0001.572] I> component binary type is 22
[0001.576] I> Size of crypto header is 8192
[0001.580] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031440)
[0001.587] I> PSC_RF binary is read from storage
[0001.592] I> PSC_RF binary integrity check is success
[0001.597] I> Binary PSC_RF loaded successfully at 0xa0031440 (0x1be60)
[0001.606] I> Task: Save WP0 payload to SC7 ctx
[0001.611] I> Task: Load MB2rf binary to SC7 ctx
[0001.615] I> Slot: 0
[0001.617] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.623] I> Binary name: MB2_RF
[0001.626] I> Size of crypto header is 8192
[0001.630] I> Size of crypto header is 8192
[0001.634] I> Size of crypto header is 8192
[0001.637] I> Size of crypto header is 8192
[0001.641] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d6aa0)
[0001.648] I> BCH of MB2_RF read from storage
[0001.652] I> BCH address is : 0xa00d6aa0
[0001.656] I> MB2_RF header integrity check is success
[0001.661] I> Binary magic in BCH component 0 is MB2R
[0001.665] I> component binary type is 14
[0001.669] I> Size of crypto header is 8192
[0001.673] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d8aa0)
[0001.681] I> MB2_RF binary is read from storage
[0001.685] I> MB2_RF binary integrity check is success
[0001.690] I> Binary MB2_RF loaded successfully at 0xa00d8aa0 (0x1bfc0)
[0001.696] I> Task: Save fuse alias data to SC7 ctx
[0001.701] I> Task: Save PMIC data to SC7 ctx
[0001.705] I> Task: Save Pinmux data to SC7 ctx
[0001.709] I> Task: Save Pad Voltage data to SC7 ctx
[0001.714] I> Task: Save controller prod data to SC7 ctx
[0001.719] I> Task: Save prod cfg data to SC7 ctx
[0001.724] I> Task: Save I2C bus freq data to SC7 ctx
[0001.729] I> Task: Save SOCTherm data to SC7 ctx
[0001.733] I> Task: Save FMON data to SC7 ctx
[0001.737] I> Task: Save VMON data to SC7 ctx
[0001.741] I> Task: Save TZDRAM data to SC7 ctx
[0001.745] I> Task: Save GPIO int data to SC7 ctx
[0001.750] I> Task: Save clock data to SC7 ctx
[0001.754] I> Task: Save debug data to SC7 ctx
[0001.758] I> Task: Save MBWT data to SC7 ctx
[0001.766] I> SC7 context save done
[0001.770] I> Task: Load MB2/Applet/FSKP
[0001.773] I> Loading MB2
[0001.776] I> Slot: 0
[0001.778] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.783] I> Binary name: MB2
[0001.786] I> Size of crypto header is 8192
[0001.790] I> Size of crypto header is 8192
[0001.794] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.800] I> BCH of MB2 read from storage
[0001.804] I> BCH address is : 0x8007e000
[0001.808] I> MB2 header integrity check is success
[0001.812] I> Binary magic in BCH component 0 is MB2B
[0001.817] I> component binary type is 6
[0001.821] I> Size of crypto header is 8192
[0001.825] I> strt_pg_num(8464) num_of_pgs(838) read_buf(0x80000000)
[0001.836] I> MB2 binary is read from storage
[0001.841] I> MB2 binary integrity check is success
[0001.845] I> Binary MB2 loaded successfully at 0x80000000 (0x68b10)
[0001.851] I> Task: Map CCPLEX SHARED carveout
[0001.856] I> Task: Prepare MB2 params
[0001.859] I> Task: Dram ecc test
[0001.862] I> Task: Misc NV security settings
[0001.867] I> NVDEC sticky bits programming done
[0001.871] I> Successfully powergated NVDEC
[0001.875] I> Task: Disable/Reload WDT
[0001.878] I> Task: Program misc carveouts
[0001.882] I> Program IPC carveouts
[0001.886] I> Task: Disable SCPM/POD reset
[0001.890] I> SLCG Global override status := 0x0
[0001.894] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-934581f8)
I> Emulation:
I> Entry timestamp: 0x001d5571
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x102e800000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002050)
I> Task: Check MC errors (0x5000204c)
I> Task: Enable hot-plug capability (0x500290f8)
I> Task: TZDRAM heap init (0x5001a0fc)
I> Task: PSC mailbox init (0x50018864)
I> Task: Crypto init (0x50006874)
I> Task: Enable GP-SE clock (0x500021b4)
I> Task: Measured Boot init (0x5001c04c)
I> Task: fTPM silicon identity init (0x5001c1f8)
I> fTPM is not enabled.
I> Task: OEM SC7 context save init (0x5001b598)
I> Task: I2C register (0x50002010)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001ff8)
I> Task: Program CBB PCIE AMAP regions (0x5001bcf8)
I> Task: Boot device init (0x50001f40)
I> Task: Partition Manager Init (0x50001f20)
I> Active chain: 0
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Active chain: 0
W> Cannot find any partition table for 00000003
PARTITION_MANAGER: Failed to publish partition.
I> Active chain: 0
I> Found 15 partitions in SDMMC_USER (instance 3)
I> Task: Load and authenticate registered FWs (0x5001f064)
I> Task: Load AUXP FWs (0x50028c7c)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Active chain: 0
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Active chain: 0
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x102db00000
I> Active chain: 0
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x102d800000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x1036000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9528448 bytes
I> dce: plain binary integrity check is success
I> Active chain: 0
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x1036000000
I> Active chain: 0
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x102e400000
I> Successfully register APE FW context save task with MB2 loader
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x102dc00000
I> Successfully register XUSB FW context save task with MB2 loader
I> Task: Carveout setup (0x500217e4)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50018738)
I> Task: Enable FSI VMON (0x50018234)
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings (0x50018318)
I> FSITHERM max temp = 41
I> FSITHERM min temp = 41
I> Task: Restore XUSB sec (0x50001ef4)
I> Task: Enable FSI SE clock (0x50018cc0)
I> Enable FSI-SE clock and 10ms delay…
I> Task: Initialize SBSA UART CAR (0x50002118)
I> Task: Initialize CPUBL Params (0x50019cac)
I> CPUBL-params @ 0x1032000000
I> Task: Ratchet update (0x5002a194)
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data (0x50019a78)
I> Task: Revoke PKC fuse (0x50001d40)
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save (0x5001b874)
I> Task: Unpowergate APE (0x50019428)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x50025cf0)
I> OEM firewalls configured
I> Task: Powergate APE (0x5001959c)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x50026144)
I> Task: Unhalt AUXPs (0x50028f00)
I> Unhalting SPE..
I> Enabling combined UART
e: early_init
c initialized
c initialized
n lic initialized
e: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
e: SafeRTOS v8.4
e: init
heduler initialized
n hsp initialized
g initialized
u initialized
mp ipc initialized
e: late init
u_nic clock initialized
b clock initialized
initialized
mp hsp initialized
p1 hsp initialized
plex ipc initialized
e: start scheduler
Task: Trigger mailbox for PSC-BL1 exit (0x500188e4)
I> Sending opcode 0x4d420802 to psc
: Entering psc_monitor_init!
INFO: GSC22 BOM:0x1048002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
eceived ACK from psc
I> Tas: MONITOR: user task addr:0x1048022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
dt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is fcc6f4f897ab64a32c3de470c48f0036
bpmp: combined : mret to Superviry md5 is a414c625926dbe27334a57bddff625ec
bpmp: firmware tag is a414c625926dbe27334a-fcc6f4f897a
Control register check for CBB_CENTRAL_CBB_FIREWALL_MC
INFO: psc supervisor init.
INFO: psc_irq_init…
INFO: enter idle taskF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
Write control check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 0f18000b != actual value: 00000000 address: 13a159c8
Control register ch?k for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
tart secure NOR provision (0x5001bb10)
I> Task: Load FSI keyblob (0x50018d08)
I> Skipping FSI key blob copy
ialized avfs_clk_platform
initialized powergate
ask: Unhalt AUXPs (0x50028f08)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt sialized dvs
initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
ssful
I> DCE unhalt successful
2.710938] Camera-FW on t234-rce-safe started
PE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50019dd0)
I> Task: Load TOS (0x5001a5early console enabled.
I> Active chain: 0
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), nme: A_cpu-bootloader
I> cpubl : oem authentication of header done
I> cpubl : meta-blob integrity check is success.
ialized emc
initialized emc_mrq
publ : will be decompressed at 0x102ce00000
I> version 1 Bin 1 BChecialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
0ialized uphy
tent_size 0 Content ChkSumialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
eserved_00 0
ialized clk_cal_late
initialized noc_late
initialized cvc
initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable pllc4_muxed
enable sdmmc4_axicif
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
enable sdmmc_legacy_tm
initialized clk_mach_post
initialized pg_post
initializ 2.886535] Camera-FW on t234-rce-safe ready SHA1=55ecd57d (crt 12.966 ms,egulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
al boot 189.621 ms)
publ : decompressed to 3346560 bytes
I> cpubl: plain binary integrity check is success
I> Active chain: 0
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> NSDRAM carveout base: 0x80000000, size: 0xfad370000
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x102ce00000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x103fdc7000
I> Relocating OP-TEE dtb from: 0x103fefec50 to 0x103c000860, size: 0x2886
I> [0] START: 0x80000000, SIZE: 0xfad370000
I> [1] START: 0x1032000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Active chain: 0
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x102e800400
I> EKB detected (length: 0x410) @ VA:0x102e800400
I> Task: Prepare TOS params (0x5001a4d8)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x103c000860
I> Task: OEM SC7 context save (0x5001b970)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50028f94)
I> Task: Program display sticky bits (0x50028f10)
I> Task: Storage device deinit (0x500020bc)
I> Task: SMMU external bypass disable (0x50018848)
I> Task: SMMU init (0x50018764)
I> Task: Program GICv3 registers (0x50029034)
I> Task: Audit firewall settings (0x50025f44)
I> Task: Bootchain failure check (0x500025c8)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
FW Boot Done
CE: BL31: v2.6(release):cec9a2bc3
NOTICE: BL31: Built : 20:19:41, Feb 19 2024
I/TC: Physical secure memory base 0x103c040000 size 0x3fc0000
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.22 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Feb 20 04:28:56 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check Porting guidelines — OP-TEE documentation documentation
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
son UEFI firmware (version 5.0-35550185 built on 2024-02-20T04:21:22+00:00)
: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
:?? 00 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_origin=0
E/LD: init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
E/TC:?? 00 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c
Jetson UEFI firmware (version 5.0-35550185 built on 2024-02-20T04:21:22+00:00)
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map…
: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary CPU 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.192-tegra (root@ehw-C9X299-RPGF-L) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #6 SMP PREEMPT Tue Aug 5 20:26:12 CST 2025
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x1024621f18 SMBIOS=0xffff0000 SMBIOS 3.0=0x1028640000 MEMATTR=0x1022df1018 ESRT=0x1022efec98 RNG=0x1016a90018 MEMRESERVE=0x1017405f18
[ 0.000000] random: crng init done
[ 0.000000] esrt: Reserving ESRT space from 0x0000001022efec98 to 0x0000001022efecd0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000ff6800000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001033ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000010195a5fff]
[ 0.000000] node 0: [mem 0x00000010195a6000-0x00000010197abfff]
[ 0.000000] node 0: [mem 0x00000010197ac000-0x0000001026c8ffff]
[ 0.000000] node 0: [mem 0x0000001026c90000-0x0000001028bcffff]
[ 0.000000] node 0: [mem 0x0000001028bd0000-0x000000102d2fffff]
[ 0.000000] node 0: [mem 0x000000102d310000-0x000000102d31ffff]
[ 0.000000] node 0: [mem 0x0000001032000000-0x0000001033ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] On node 0, zone Normal: 16 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 224 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90392 r8192 d32488 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16188944
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 63751404K/65784896K available (18496K kernel code, 3168K rwdata, 7168K rodata, 3968K init, 1417K bss, 1509204K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000774] Console: colour dummy device 80x25
[ 0.000916] printk: console [tty0] enabled
[ 0.000962] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000973] pid_max: default: 32768 minimum: 301
[ 0.001032] LSM: Security Framework initializing
[ 0.001055] Yama: becoming mindful.
[ 0.001074] SELinux: Initializing.
[ 0.001201] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.001285] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.003814] rcu: Hierarchical SRCU implementation.
[ 0.003913] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.004755] DTS File Name: /home/ehw/bzg_agx64/35.0.0/Linux_for_Tegra/source/public/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0005-p3737-0000.dts
[ 0.004765] DTB Build time: Aug 5 2025 20:26:36
[ 0.006434] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.006764] Remapping and enabling EFI services.
[ 0.007720] smp: Bringing up secondary CPUs …
[ 0.036454] Detected PIPT I-cache on CPU1
[ 0.036498] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.036537] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.065200] Detected PIPT I-cache on CPU2
[ 0.065209] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.065224] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.093843] Detected PIPT I-cache on CPU3
[ 0.093852] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.093865] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.124546] Detected PIPT I-cache on CPU4
[ 0.124568] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.124594] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.153257] Detected PIPT I-cache on CPU5
[ 0.153267] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.153281] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.181923] Detected PIPT I-cache on CPU6
[ 0.181933] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.181949] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.210594] Detected PIPT I-cache on CPU7
[ 0.210604] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.210620] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.241305] Detected PIPT I-cache on CPU8
[ 0.241328] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.241356] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.270022] Detected PIPT I-cache on CPU9
[ 0.270033] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.270047] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.299303] Detected PIPT I-cache on CPU10
[ 0.299313] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.299329] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.328576] Detected PIPT I-cache on CPU11
[ 0.328586] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.328601] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.328657] smp: Brought up 1 node, 12 CPUs
[ 0.328721] SMP: Total of 12 processors activated.
[ 0.328726] CPU features: detected: Privileged Access Never
[ 0.328729] CPU features: detected: LSE atomic instructions
[ 0.328731] CPU features: detected: User Access Override
[ 0.328734] CPU features: detected: 32-bit EL0 Support
[ 0.328738] CPU features: detected: Common not Private translations
[ 0.328741] CPU features: detected: RAS Extension Support
[ 0.328743] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.328747] CPU features: detected: CRC32 instructions
[ 0.328749] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.348063] spectre-bhb mitigation disabled by command line option
[ 0.348065] spectre-bhb mitigation disabled by command line option
[ 0.366977] CPU: All CPU(s) started at EL2
[ 0.370328] devtmpfs: initialized
[ 0.389528] Registered cp15_barrier emulation handler
[ 0.389540] Registered setend emulation handler
[ 0.389546] KASLR enabled
[ 0.389680] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.389694] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.392365] pinctrl core: initialized pinctrl subsystem
[ 0.393061] NET: Registered protocol family 16
[ 0.393934] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.394139] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.394340] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.394367] audit: initializing netlink subsys (disabled)
[ 0.394460] audit: type=2000 audit(0.392:1): state=initialized audit_enabled=0 res=1
[ 0.394646] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.394648] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.394653] thermal_sys: Registered thermal governor ‘pid_thermal_gov’
[ 0.397314] cpuidle: using governor menu
[ 0.397442] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.397566] ASID allocator initialised with 32768 entries
[ 0.397655] Serial: AMBA PL011 UART driver
[ 0.399545] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.399569] Tegra reboot handler registered.
[ 0.419198] mc: mapped MMIO address: 0xffff800011200000 → 0x2c10000
[ 0.419210] mc: mapped MMIO address: 0xffff800011220000 → 0x2c20000
[ 0.419218] mc: mapped MMIO address: 0xffff800011240000 → 0x2c30000
[ 0.419225] mc: mapped MMIO address: 0xffff800011260000 → 0x2c40000
[ 0.419234] mc: mapped MMIO address: 0xffff800011280000 → 0x2c50000
[ 0.419241] mc: mapped MMIO address: 0xffff8000112a0000 → 0x2b80000
[ 0.419249] mc: mapped MMIO address: 0xffff8000112c0000 → 0x2b90000
[ 0.419257] mc: mapped MMIO address: 0xffff8000112e0000 → 0x2ba0000
[ 0.419263] mc: mapped MMIO address: 0xffff800011300000 → 0x2bb0000
[ 0.419270] mc: mapped MMIO address: 0xffff800011320000 → 0x1700000
[ 0.419276] mc: mapped MMIO address: 0xffff800011340000 → 0x1710000
[ 0.419282] mc: mapped MMIO address: 0xffff800011360000 → 0x1720000
[ 0.419290] mc: mapped MMIO address: 0xffff800011380000 → 0x1730000
[ 0.419297] mc: mapped MMIO address: 0xffff8000113a0000 → 0x1740000
[ 0.419303] mc: mapped MMIO address: 0xffff8000113c0000 → 0x1750000
[ 0.419310] mc: mapped MMIO address: 0xffff8000113e0000 → 0x1760000
[ 0.419319] mc: mapped MMIO address: 0xffff800011400000 → 0x1770000
[ 0.419328] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.419371] mc-err: mcerr ops are set to t23x
[ 0.420075] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 81, base_baud = 0) is a SBSA
[ 1.509617] printk: console [ttyAMA0] enabled
[ 1.518177] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.524884] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.531584] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.538283] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.546858] ACPI: Interpreter disabled.
[ 1.551932] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 1.556810] vbusA-cvb: supplied by vdd-5v-sys
[ 1.561274] vbusB-cvb: supplied by vdd-5v-sys
[ 1.565756] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 1.570661] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 1.575909] iommu: Default domain type: Translated
[ 1.580831] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.587104] SCSI subsystem initialized
[ 1.590930] usbcore: registered new interface driver usbfs
[ 1.596431] usbcore: registered new interface driver hub
[ 1.601758] usbcore: registered new device driver usb
[ 1.606998] mc: Linux media interface: v0.10
[ 1.611276] videodev: Linux video capture interface: v2.00
[ 1.616915] pps_core: LinuxPPS API ver. 1 registered
[ 1.621878] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.631019] PTP clock support registered
[ 1.635177] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.642335] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.649997] Registered efivars operations
[ 1.654134] FPGA manager framework
[ 1.657560] Advanced Linux Sound Architecture Driver Initialized.
[ 1.663911] Bluetooth: Core ver 2.22
[ 1.667493] NET: Registered protocol family 31
[ 1.671937] Bluetooth: HCI device and connection manager initialized
[ 1.678296] Bluetooth: HCI socket layer initialized
[ 1.683174] Bluetooth: L2CAP socket layer initialized
[ 1.688235] Bluetooth: SCO socket layer initialized
[ 1.693631] camchar: rtcpu character device driver loaded
[ 1.699275] clocksource: Switched to clocksource arch_sys_counter
[ 1.870123] VFS: Disk quotas dquot_6.6.0
[ 1.874088] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.881296] pnp: PnP ACPI: disabled
[ 1.886734] la/ptsa driver initialized.
[ 1.890626] NET: Registered protocol family 2
[ 1.895188] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 1.904963] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 1.913742] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 1.922312] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 1.930210] TCP: Hash tables configured (established 524288 bind 65536)
[ 1.936926] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 1.943987] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 1.951585] NET: Registered protocol family 1
[ 1.956223] RPC: Registered named UNIX socket transport module.
[ 1.962155] RPC: Registered udp transport module.
[ 1.966858] RPC: Registered tcp transport module.
[ 1.971566] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.978020] PCI: CLS 0 bytes, default 64
[ 1.982076] Trying to unpack rootfs image as initramfs…
[ 2.115450] Freeing initrd memory: 9548K
[ 2.121853] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.129826] kvm [1]: IPA Size Limit: 48 bits
[ 2.134118] kvm [1]: GICv3: no GICV resource entry
[ 2.138911] kvm [1]: disabling GICv2 emulation
[ 2.143364] kvm [1]: GIC system register CPU interface enabled
[ 2.149309] kvm [1]: vgic interrupt IRQ9
[ 2.153390] kvm [1]: VHE mode initialized successfully
[ 2.159215] Initialise system trusted keyrings
[ 2.163750] workingset: timestamp_bits=46 max_order=24 bucket_order=0
[ 2.172382] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.178510] NFS: Registering the id_resolver key type
[ 2.183588] Key type id_resolver registered
[ 2.187771] Key type id_legacy registered
[ 2.191814] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.198522] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 2.205931] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.221969] NET: Registered protocol family 38
[ 2.226416] Key type asymmetric registered
[ 2.230513] Asymmetric key parser ‘x509’ registered
[ 2.235409] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 2.242871] io scheduler mq-deadline registered
[ 2.247401] io scheduler kyber registered
[ 2.255841] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.261449] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.267038] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.272624] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.280842] tegra_dc_assign_hw_data: no matching compatible node
[ 2.286862] tegradccommon module_init failed
[ 2.291134] tegradc module_init failed
[ 2.295143] EINJ: ACPI disabled.
[ 2.300031] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.306910] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 2.312221] tegra-pmc: ### PMC reset level: L0
[ 2.316663] tegra-pmc: ### PMC reset status reg: 0x0
[ 2.323047] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 3.818268] printk: console [ttyTCU0] enabled
[ 3.827465] arm-smmu 12000000.iommu: probing hardware configuration…
[ 3.835457] arm-smmu 12000000.iommu: SMMUv2 with:
[ 3.840323] arm-smmu 12000000.iommu: stage 1 translation
[ 3.845894] arm-smmu 12000000.iommu: stage 2 translation
[ 3.851433] arm-smmu 12000000.iommu: nested translation
[ 3.856891] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 3.864313] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 3.873308] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 3.880015] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 3.886709] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 3.894308] arm-smmu 10000000.iommu: probing hardware configuration…
[ 3.901010] arm-smmu 10000000.iommu: SMMUv2 with:
[ 3.905840] arm-smmu 10000000.iommu: stage 1 translation
[ 3.911371] arm-smmu 10000000.iommu: stage 2 translation
[ 3.916909] arm-smmu 10000000.iommu: nested translation
[ 3.922371] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 3.929788] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 3.938667] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 3.945378] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 3.952075] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 3.959223] arm-smmu 8000000.iommu: probing hardware configuration…
[ 3.965833] arm-smmu 8000000.iommu: SMMUv2 with:
[ 3.970571] arm-smmu 8000000.iommu: stage 1 translation
[ 3.976023] arm-smmu 8000000.iommu: stage 2 translation
[ 3.981463] arm-smmu 8000000.iommu: nested translation
[ 3.986815] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 3.994139] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.002920] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.009536] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.016146] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.023544] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.033941] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.039922] tegra_profiler: auth: init
[ 4.044073] nvsciipc: loaded module
[ 4.049281] tun: Universal TUN/TAP device driver, 1.6
[ 4.054950] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.062376] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.067860] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.072955] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.079044] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.084586] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.090481] PPP generic driver version 2.4.2
[ 4.094903] PPP BSD Compression module registered
[ 4.099735] PPP Deflate Compression module registered
[ 4.104939] PPP MPPE Compression module registered
[ 4.109879] usbcore: registered new interface driver r8152
[ 4.115523] usbcore: registered new interface driver asix
[ 4.121074] usbcore: registered new interface driver ax88179_178a
[ 4.127349] usbcore: registered new interface driver cdc_ether
[ 4.133353] usbcore: registered new interface driver net1080
[ 4.139162] usbcore: registered new interface driver cdc_subset
[ 4.145245] usbcore: registered new interface driver zaurus
[ 4.150969] usbcore: registered new interface driver cdc_ncm
[ 4.156791] usbcore: registered new interface driver aqc111
[ 4.162628] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.168983] ohci-pci: OHCI PCI platform driver
[ 4.173560] ohci-platform: OHCI generic platform driver
[ 4.179235] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.185525] usbcore: registered new interface driver uas
[ 4.191003] usbcore: registered new interface driver usb-storage
[ 4.197332] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.203457] mousedev: PS/2 mouse device common for all mice
[ 4.209209] usbcore: registered new interface driver xpad
[ 4.216643] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.222118] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:25 UTC (25)
[ 4.230350] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.236774] i2c /dev entries driver
[ 4.240416] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.246223] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.251964] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.257700] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.263470] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.269174] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.274857] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.280611] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.288745] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.297336] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.306006] pps pps0: new PPS source ktimer
[ 4.310305] pps pps0: ktimer PPS source registered
[ 4.315222] pps_ldisc: PPS line discipline registered
[ 4.321290] device-mapper: uevent: version 1.0.3
[ 4.326125] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.336019] sdhci: Secure Digital Host Controller Interface driver
[ 4.342358] sdhci: Copyright(c) Pierre Ossman
[ 4.346831] Synopsys Designware Multimedia Card Interface Driver
[ 4.353064] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.359055] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 4.359294] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.359444] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[ 4.378592] tegra-bpmp bpmp: firmware: a414c625926dbe27334a-fcc6f4f897a
[ 4.387101] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.392717] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 4.407041] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.412965] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
gfs initialized
6.130153] hid: raw HID events driver (C) Jiri Kosina
[ 6.135713] usbcore: registered new interface driver usbhid
[ 6.141454] usbhid: USB HID core driver
[ 6.145947] tegra-dce d800000.dce: Adding to iommu group 5
[ 6.153177] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 6.162146] tegra234-aon c000000.aon: Adding to iommu group 6
[ 6.168624] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 6.175998] c000000.aon:hsp: probed
[ 6.177801] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 6.188177] tegra234-aon c000000.aon: init done
[ 6.188608] tegra23x-psc e860000.psc: Adding to iommu group 7
[ 6.193022] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] …
[ 6.199671] tegra23x-psc e860000.psc: ext_cfg base:0000000026760f4c
[ 6.207172] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 6.207360] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] …
[ 6.213636] tegra23x-psc e860000.psc: init done
[ 6.221411] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 6.229837] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 8
[ 6.246934] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 6.259345] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 6.268542] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 6.280183] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 6.291619] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 6.303305] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 6.315913] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 6.328769] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 6.340901] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (120)
[ 6.347717] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 6.356090] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=55ecd57df677fd722e795b49ccb283f065b222a1
[ 6.369489] t19x_cache tegra-cache: probed
[ 6.373910] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 6.388231] optee: probing for conduit method.
6.392827] optee: revision 3.22 (e3b12903)
[ 6.451198] optee: dynamic shared memory is enabled
[ 6.460638] optee: initialized driver
[ 6.479739] nvpmodel: initialized successfully
[ 6.484430] tegra_hv: get_hvd: not initialized yet
[ 6.489374] user_ivc_mempool: hypervisor not present
[ 6.495180] usbcore: registered new interface driver snd-usb-audio
[ 6.502196] u32 classifier
[ 6.505009] input device check on
[ 6.508783] Actions configured
[ 6.512434] Initializing XFRM netlink socket
[ 6.517228] NET: Registered protocol family 10
[ 6.523528] Segment Routing with IPv6
[ 6.527346] NET: Registered protocol family 17
[ 6.531937] NET: Registered protocol family 15
[ 6.536600] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.550780] Bluetooth: RFCOMM socket layer initialized
[ 6.556191] Bluetooth: RFCOMM ver 1.11
[ 6.560067] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.566163] Bluetooth: HIDP socket layer initialized
[ 6.572781] 9pnet: Installing 9P2000 support
[ 6.577276] Key type dns_resolver registered
[ 6.583043] registered taskstats version 1
[ 6.587288] Loading compiled-in X.509 certificates
[ 6.604505] Loaded X.509 cert ‘Build time autogenerated kernel key: 939191b3a1cf4cdeeb0095a2019b9d2b9c8f0dfd’
[ 6.615342] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[ 6.628363] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.636939] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[ 6.649694] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.656755] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[ 6.668945] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.675598] tegra194-pcie 141e0000.pcie: Adding to iommu group 12
[ 6.687551] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 6.720839] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 13
[ 6.733390] host1x 13e40000.host1x: Adding to iommu group 14
[ 6.766153] host1x 13e40000.host1x: initialized
[ 6.771243] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 15
[ 6.779383] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 6.791427] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 16
[ 6.799487] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 6.811484] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 17
[ 6.819550] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 6.831550] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 18
[ 6.839617] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.851660] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 19
[ 6.859735] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.871732] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 20
[ 6.879833] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.891856] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 21
[ 6.899943] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.911984] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 22
[ 6.920065] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.932094] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 23
[ 6.940169] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 6.952152] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 24
[ 6.960226] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 6.972227] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 25
[ 6.980285] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 6.992311] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 26
[ 7.000365] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 7.012385] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 27
[ 7.020471] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 7.032474] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 28
[ 7.040537] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 7.052546] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 29
[ 7.060608] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 7.072594] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 30
[ 7.080654] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 7.092655] falcon 15340000.vic: Adding to iommu group 31
[ 7.103754] falcon 15340000.vic: initialized
[ 7.108508] falcon 15380000.nvjpg: Adding to iommu group 32
[ 7.118329] falcon 15380000.nvjpg: initialized
[ 7.123033] falcon 15540000.nvjpg1: Adding to iommu group 33
[ 7.131917] falcon 15540000.nvjpg1: initialized
[ 7.136725] falcon 154c0000.nvenc: Adding to iommu group 34
[ 7.148055] falcon 154c0000.nvenc: initialized
[ 7.152817] falcon 15a50000.ofa: Adding to iommu group 35
[ 7.162272] falcon 15a50000.ofa: initialized
[ 7.166822] nvdec 15480000.nvdec: Adding to iommu group 36
[ 7.179884] nvdec 15480000.nvdec: initialized
[ 7.184530] tsec 15500000.tsec: Adding to iommu group 37
[ 7.195136] tsec 15500000.tsec: initialized
[ 7.202163] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.219317] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 7.236011] gpio-394 (camera-control-output-low): hogged as output/low
[ 7.242772] gpio-397 (camera-control-output-low): hogged as output/low
[ 7.249532] gpio-487 (camera-control-output-low): hogged as output/low
[ 7.256293] gpio-486 (camera-control-output-low): hogged as output/low
[ 7.264177] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 7.271688] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 7.278683] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 7.285291] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 7.291804] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 7.298034] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 7.306451] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 7.315037] tegra194-isp5 14800000.isp: Adding to iommu group 38
[ 7.324629] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 7.334311] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 7.340897] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 39
[ 7.349120] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 40
[ 7.357177] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 7.367184] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 7.374011] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 7.383998] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 7.390787] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 7.400765] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 7.407594] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 41
[ 7.416309] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 7.427707] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 42
[ 7.436396] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 7.447776] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 43
[ 7.456458] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 7.467844] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 44
[ 7.476567] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 7.487932] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 45
[ 7.496613] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 7.507987] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 46
[ 7.516691] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 7.528069] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 47
[ 7.536773] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 7.548154] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 48
[ 7.556831] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 7.568213] pva 16000000.pva0: Adding to iommu group 49
[ 7.593766] pva 16000000.pva0: initialized
[ 7.609960] nvdla 15880000.nvdla0: Adding to iommu group 50
[ 7.625654] nvdla 15880000.nvdla0: initialized
[ 7.632005] nvdla 158c0000.nvdla1: Adding to iommu group 51
[ 7.646972] nvdla 158c0000.nvdla1: initialized
[ 7.653237] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 7.661406] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 7.668919] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 7.675543] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 7.682293] serial-tegra 3100000.serial: Adding to iommu group 2
[ 7.688957] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 26, base_baud = 0) is a TEGRA_UART
[ 7.698758] serial-tegra 3110000.serial: Adding to iommu group 2
[ 7.705272] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 79, base_baud = 0) is a TEGRA_UART
[ 7.714614] serial-tegra 3130000.serial: Adding to iommu group 2
[ 7.721186] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 80, base_baud = 0) is a TEGRA_UART
[ 7.747313] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 7.757077] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.762665] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 7.771327] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 7.780958] tegra-xusb 3610000.xhci: irq 237, io mem 0x03610000
[ 7.787285] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.792845] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.800646] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.808238] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 7.816747] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.824184] usb usb1: Product: xHCI Host Controller
[ 7.829202] usb usb1: Manufacturer: Linux 5.10.192-tegra xhci-hcd
[ 7.835473] usb usb1: SerialNumber: 3610000.xhci
[ 7.841054] hub 1-0:1.0: USB hub found
[ 7.844945] hub 1-0:1.0: 4 ports detected
[ 7.849395] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 7.857902] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.865338] usb usb2: Product: xHCI Host Controller
[ 7.870356] usb usb2: Manufacturer: Linux 5.10.192-tegra xhci-hcd
[ 7.876634] usb usb2: SerialNumber: 3610000.xhci
[ 7.881911] hub 2-0:1.0: USB hub found
[ 7.885795] hub 2-0:1.0: 4 ports detected
[ 7.911229] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 7.936684] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2022000 KHz, changing to: 2035200 KHz
[ 7.949961] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1916000 KHz, changing to: 1958400 KHz
[ 7.962753] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2008000 KHz, changing to: 2035200 KHz
[ 7.974684] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[ 7.983459] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.990761] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.991869] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 8.002881] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff → 0x0030100000
[ 8.011577] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff → 0x0040000000
[ 8.020266] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff → 0x2080000000
[ 8.024668] mmc0: CQHCI version 5.10
[ 8.037564] irq: IRQ304: trimming hierarchy from :interrupt-controller@f400000-1
[ 8.045311] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 304
[ 8.060736] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 8.149433] mmc0: Command Queue Engine enabled
[ 8.154007] mmc0: periodic cache flush enabled
[ 8.158579] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 8.165633] mmcblk0: mmc0:0001 DG4064 59.2 GiB
[ 8.170503] mmcblk0rpmb: mmc0:0001 DG4064 partition 3 4.00 MiB, chardev (510:0)
[ 8.191571] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 9.136550] tegra194-pcie 14100000.pcie: Phy link never came up
[ 9.142715] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 9.149514] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 9.155156] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 9.164993] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 9.175819] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 9.183757] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 9.190099] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 9.204473] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 9.209874] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.218855] pcieport 0001:00:00.0: Adding to iommu group 9
[ 9.224787] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
[ 9.231398] pcieport 0001:00:00.0: AER: enabled with IRQ 64
[ 9.237360] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 9.243460] pci 0001:00:00.0: Removing from iommu group 9
[ 9.249016] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 9.257048] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 9.264989] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 9.272156] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff → 0x0036100000
[ 9.280838] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff → 0x0040000000
[ 9.289518] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff → 0x2140000000
[ 10.395297] tegra194-pcie 14160000.pcie: Phy link never came up
[ 10.401454] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 10.408261] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 10.413914] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 10.424041] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.434858] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 10.442786] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 10.449124] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 10.455630] tegra-xusb 3610000.xhci: entering ELPG done
[ 10.463184] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 10.468590] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.477549] pcieport 0004:00:00.0: Adding to iommu group 10
[ 10.483534] pcieport 0004:00:00.0: PME: Signaling with IRQ 66
[ 10.490139] pcieport 0004:00:00.0: AER: enabled with IRQ 66
[ 10.496090] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 10.502176] pci 0004:00:00.0: Removing from iommu group 10
[ 10.507822] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 10.515582] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 10.522471] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 10.530394] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[ 10.537558] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff → 0x003e100000
[ 10.546248] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff → 0x0040000000
[ 10.554927] tegra194-pcie 141e0000.pcie: MEM 0x2e40000000..0x3227ffffff → 0x2e40000000
[ 10.671433] tegra194-pcie 141e0000.pcie: Link up
[ 10.678245] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 10.685066] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 10.690710] pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[ 10.700834] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.711641] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[ 10.719558] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 10.725871] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 10.736072] pci 0007:01:00.0: [10ee:7038] type 00 class 0x070001
[ 10.742362] pci 0007:01:00.0: reg 0x10: [mem 0x00000000-0x0000ffff]
[ 10.754011] pci 0007:00:00.0: BAR 14: assigned [mem 0x3228000000-0x32280fffff]
[ 10.761448] pci 0007:01:00.0: BAR 0: assigned [mem 0x3228000000-0x322800ffff]
[ 10.768813] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 10.774183] pci 0007:00:00.0: bridge window [mem 0x3228000000-0x32280fffff]
[ 10.781550] pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.790280] pci 0007:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 10.799227] pcieport 0007:00:00.0: Adding to iommu group 12
[ 10.805203] pcieport 0007:00:00.0: PME: Signaling with IRQ 70
[ 10.811805] pcieport 0007:00:00.0: AER: enabled with IRQ 70
[ 10.817837] serial 0007:01:00.0: Adding to iommu group 12
[ 10.823604] serial 0007:01:00.0: enabling device (0000 → 0002)
[ 10.830475] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 10.835525] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 10.840460] vdd-dp: supplied by vdd-3v3-sys
[ 10.844912] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 10.849945] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 10.857209] tegra194-isp5 14800000.isp: initialized
[ 10.868499] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 10.874939] (NULL device *): fops function table already registered
[ 10.882215] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 10.889096] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 10.889224] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 10.911671] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 304
[ 11.008470] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 11.015655] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff → 0x003a100000
[ 11.024355] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff → 0x0040000000
[ 11.033038] tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff → 0x2740000000
[ 11.975009] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 12.148868] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 12.155038] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 12.161850] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 12.167487] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 12.177608] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 12.188446] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 12.196378] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 12.202701] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 12.216843] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 12.222244] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 12.231204] pcieport 0005:00:00.0: Adding to iommu group 11
[ 12.237210] pcieport 0005:00:00.0: PME: Signaling with IRQ 68
[ 12.243806] pcieport 0005:00:00.0: AER: enabled with IRQ 68
[ 12.250442] nvethernet 2310000.ethernet: Adding to iommu group 52
[ 12.256860] nvethernet 2310000.ethernet: failed to read skip mac reset flag, default 0
[ 12.265046] nvethernet 2310000.ethernet: Failed to read nvida,pause_frames, so setting to default support as disable
[ 12.275907] nvethernet 2310000.ethernet: setting to default DMA bit mask
[ 12.284390] nvethernet 2310000.ethernet: missing nvidia,pad_auto_cal_pu_offset, setting default 0
[ 12.293529] nvethernet 2310000.ethernet: missing nvidia,pad_auto_cal_pd_offset, setting default 0
[ 12.310295] nvethernet 2310000.ethernet: Ethernet MAC address: 48:b0:2d:ff:c6:d7
[ 12.318258] nvethernet 2310000.ethernet: macsec param in DT is missing or disabled
[ 12.326061] nvethernet 2310000.ethernet: Macsec not supported/Not enabled in DT
[ 12.334843] nvethernet 2310000.ethernet: eth0 (HW ver: 53) created with 8 DMA channels
[ 12.343521] irq: IRQ306: trimming hierarchy from :pmc@c360000
[ 12.349624] irq: IRQ307: trimming hierarchy from :interrupt-controller@f400000-1
[ 12.357298] irq: IRQ308: trimming hierarchy from :pmc@c360000
[ 12.363272] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 12.370902] tegra-se-nvhost 15810000.se: Adding to iommu group 53
[ 12.377506] tegra-se-nvhost 15810000.se: initialized
[ 12.393576] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 12.399975] tegra-se-nvhost 15820000.se: Adding to iommu group 54
[ 12.406676] tegra-se-nvhost 15820000.se: initialized
[ 12.414367] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 12.420722] tegra-se-nvhost 15840000.se: Adding to iommu group 55
[ 12.427404] tegra-se-nvhost 15840000.se: initialized
[ 12.433564] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 12.440433] tegra_actmon d230000.actmon: in actmon_register()…
[ 12.446884] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 12.453136] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 12.461534] hvc_sysfs: hypervisor is not present
ING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
12.594849] ALSA device list:
[ 12.597913] No soundcards found.
[ 12.601981] Freeing unused kernel memory: 3968K
[ 12.606683] Run /init as init process
[ 12.622277] Root device found: mmcblk0p1
[ 12.630546] Found dev node: /dev/mmcblk0p1
[ 13.582172] EXT4-fs (mmcblk0p1): 1 orphan inode deleted
[ 13.587562] EXT4-fs (mmcblk0p1): recovery complete
[ 13.597365] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 13.607943] Rootfs mounted over mmcblk0p1
[ 13.622808] Switching from initrd to actual rootfs
[ 13.721124] systemd[1]: System time before build time, advancing clock.
[ 13.743752] x_tables: module verification failed: signature and/or required key missing - tainting kernel
[ 13.777115] systemd[1]: systemd 245.4-4ubuntu3.22 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 13.800723] systemd[1]: Detected architecture arm64.
[ 13.840553] systemd[1]: Set hostname to .
[ 14.020029] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 14.033088] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 14.042693] systemd[1]: Created slice system-modprobe.slice.
[ 14.048906] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 14.055627] systemd[1]: Created slice User and Session Slice.
[ 14.061658] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 14.069759] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 14.079541] systemd[1]: Reached target User and Group Name Lookups.
[ 14.086061] systemd[1]: Reached target Slices.
[ 14.090687] systemd[1]: Reached target Mounting snaps.
[ 14.096030] systemd[1]: Reached target Mounted snaps.
[ 14.101302] systemd[1]: Reached target Swap.
[ 14.113869] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 14.120780] systemd[1]: Listening on Syslog Socket.
[ 14.125960] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 14.132997] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 14.139994] systemd[1]: Listening on Journal Audit Socket.
[ 14.145777] systemd[1]: Listening on Journal Socket (/dev/log).
[ 14.152040] systemd[1]: Listening on Journal Socket.
[ 14.157316] systemd[1]: Listening on udev Control Socket.
[ 14.163007] systemd[1]: Listening on udev Kernel Socket.
[ 14.169522] systemd[1]: Mounting Huge Pages File System…
[ 14.176255] systemd[1]: Mounting POSIX Message Queue File System…
[ 14.183583] systemd[1]: Mounting RPC Pipe File System…
[ 14.190001] systemd[1]: Mounting Kernel Debug File System…
[ 14.196746] systemd[1]: Mounting Kernel Trace File System…
[ 14.203746] systemd[1]: Starting Journal Service…
[ 14.209928] systemd[1]: Starting Set the console keyboard layout…
[ 14.217343] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 14.227142] systemd[1]: Starting Load Kernel Module chromeos_pstore…
[ 14.234000] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 14.234970] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 14.250048] systemd[1]: Starting Load Kernel Module pstore_blk…
[ 14.257256] systemd[1]: Starting Load Kernel Module pstore_zone…
[ 14.264821] systemd[1]: Starting Load Kernel Module ramoops…
[ 14.271940] systemd[1]: Starting NVIDIA specific first-boot udev script…
[ 14.280104] systemd[1]: Started Nameserver information manager.
[ 14.286423] systemd[1]: Reached target Network (Pre).
[ 14.292412] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 14.301800] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 14.319592] systemd[1]: Starting Load Kernel Modules…
[ 14.325872] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 14.333504] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 14.333735] systemd[1]: Starting udev Coldplug all Devices…
[ 14.333883] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 14.334075] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x0000001038e00000,16777216
[ 14.334078] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 14.334084] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000001049800000,914358272
[ 14.334085] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 14.334088] nvmap_page_pool_init: Total RAM pages: 16072302
[ 14.334089] nvmap_page_pool_init: nvmap page pool size: 2009037 pages (3751 MB)
[ 14.334140] nvmap_background_zero_thread: PP zeroing thread starting.
[ 14.334357] misc nvmap: created heap vpr base 0x0000001049800000 size (892928KiB)
[ 14.337369] misc nvmap: created heap fsi base 0x0000001038e00000 size (16384KiB)
[ 14.424623] systemd[1]: Started Journal Service.
[ 14.455925] systemd-journald[319]: Received client request to flush runtime journal.
[ 15.094163] nvidia: loading out-of-tree module taints kernel.
[ 15.107177] nv_platform 13800000.display: Adding to iommu group 56
[ 15.118184] platform 13800000.display:nvdisplay-niso: Adding to iommu group 57
[ 15.130819] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64 35.5.0 Release Build (buildbrain@mobile-u64-6519-d7000) Mon Feb 19 20:34:12 PST 2024
[ 15.131403] spi-tegra114 3210000.spi: Adding to iommu group 2
[ 15.155258] nvvrs11 4-0020: NVVRS11 Vendor ID: 0x11
[ 15.162799] nvadsp 2993000.adsp: Adding to iommu group 58
[ 15.165821] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 15.168671] nvadsp 2993000.adsp: in probe()…
[ 15.169050] nvvrs11 4-0020: NVVRS11 Model Rev: 0xE1
[ 15.169053] nvvrs11 4-0020: NVVRS11 probe successful
[ 15.169595] nvvrs11 4-0022: NVVRS11 Vendor ID: 0x11
[ 15.170990] nvvrs11 4-0022: NVVRS11 Model Rev: 0xE1
[ 15.170992] nvvrs11 4-0022: NVVRS11 probe successful
[ 15.182270] irq: IRQ310: trimming hierarchy from :pmc@c360000
[ 15.186544] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 15.187567] cpu-throttle-alert cooling device registered.
[ 15.187929] gpu-throttle-alert cooling device registered.
[ 15.188353] cv0-throttle-alert cooling device registered.
[ 15.188688] cv1-throttle-alert cooling device registered.
[ 15.188977] cv2-throttle-alert cooling device registered.
[ 15.189229] soc0-throttle-alert cooling device registered.
[ 15.189502] soc1-throttle-alert cooling device registered.
[ 15.189798] soc2-throttle-alert cooling device registered.
[ 15.191546] tegra-hda 3510000.hda: Adding to iommu group 59
[ 15.192300] hot-surface-alert cooling device registered.
[ 15.192402] rt5640 8-001c: Device with ID register 0xffff686b is not rt5640/39
[ 15.193609] spi-tegra114 3230000.spi: Adding to iommu group 2
[ 15.201429] irq: IRQ311: trimming hierarchy from :pmc@c360000
[ 15.206917] cdi_tsc c6a0000.tsc_sig_gen: CDI TSC probing…
[ 15.214578] nct1008_nct72 4-004c: starting parse dt
[ 15.218220] cdi_tsc_probe: Initializing the driver
[ 15.224238] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 15.230270] cdi_tsc_probe: Successfully initialized the tsc char driver
[ 15.235462] nct1008_nct72 4-004c: success parsing dt
[ 15.327751] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 15.327751]
[ 15.328058] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 15.386047] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 15.392354] nct1008_nct72 4-004c: EXT shutdown limit 107
[ 15.434413] nct1008_nct72 4-004c: initial LOC temp: 41000
[ 15.440591] nct1008_nct72 4-004c: initial EXT temp: 47750
[ 15.447191] nct1008_nct72 4-004c: hi_b:-4, lo_b:0
[ 15.453260] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 15.463517] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
[ 15.474287] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
[ 15.474708] tegra-asoc: sound: Adding to iommu group 58
[ 15.485230] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
[ 15.490596] irq: IRQ312: trimming hierarchy from :pmc@c360000
[ 15.492014] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 58
[ 15.492069] tegra210_adsp_audio_probe: platform probe started
[ 15.494030] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 15.494265] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 15.494495] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 15.494733] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 15.494963] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 15.495193] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 15.495197] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 15.495198] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 15.495262] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 15.500722] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
[ 15.511440] ucsi_ccg 1-0008: i2c_transfer failed -121
[ 15.544900] cryptd: max_cpu_qlen set to 1000
[ 15.549882] ucsi_ccg 1-0008: ucsi_ccg_init failed - -121
[ 15.610578] ucsi_ccg: probe of 1-0008 failed with error -121
[ 15.731564] using random self ethernet address
[ 15.736248] using random host ethernet address
[ 16.114750] using random self ethernet address
[ 16.119454] using random host ethernet address
Please try to remove all peripheral including camera to check whether the os hang.
If issue still exist, please try latest version (JP5.1.5/ JP 6.2) .
