Pactl list not see bluetooth PipeWire
somedays ago, I use bluetoothctl connect my audio device, and use pactl lisl sinks short list bluetooth device successfully. This is my note somedays ago.
nvidia@nvidia:~$ pactl list sinks short
45      alsa_output.platform-88090b0000.hda.hdmi-stereo PipeWire        s32le 2ch 48000Hz       SUSPENDED
46      alsa_output.platform-sound.analog-stereo        PipeWire        s24-32le 2ch 48000Hz    IDLE
183     bluez_output.AA_9B_B8_7E_58_3E.1        PipeWire        s16le 1ch 16000Hz       RUNNING
but now, I cant see the bluez_output.AA_9B_B8_7E_58_3E.1 device? maybe reboot cause this problem, I dont know why?
(richtech-v3) jetson@jetson ~ $ bluetoothctl devices
Device AA:9B:B8:7E:58:3E HP WS1pro 5.4
(richtech-v3) jetson@jetson ~ $ bluetoothctl info AA:9B:B8:7E:58:3E
Device AA:9B:B8:7E:58:3E (public)
        Name: HP WS1pro 5.4
        Alias: HP WS1pro 5.4
        Class: 0x00240404 (2360324)
        Icon: audio-headset
        Paired: yes
        Bonded: yes
        Trusted: yes
        Blocked: no
        Connected: yes
        LegacyPairing: no
        UUID: Audio Sink                (0000110b-0000-1000-8000-00805f9b34fb)
        UUID: A/V Remote Control        (0000110e-0000-1000-8000-00805f9b34fb)
        UUID: Handsfree                 (0000111e-0000-1000-8000-00805f9b34fb)
        ManufacturerData.Key: 0x7262 (29282)
        ManufacturerData.Value:
  32 32 78 78 11 22 33 44 55 66 aa bb 00 00        22xx."3DUf....
        Battery Percentage: 0x64 (100)
(richtech-v3) jetson@jetson ~ $ pactl list sinks short
48      alsa_output.platform-sound.analog-stereo        PipeWire        s24-32le 2ch 48000Hz    SUSPENDED
62      alsa_output.usb-Jieli_Technology_USB_Composite_Device-01.analog-stereo  PipeWire        s16le 2ch 48000Hz       SUSPENDED
“I’m quite certain that my Bluetooth speaker is connected, because when I run the disconnect and connect commands, the bluetooth speaker plays the ‘device disconnected’ and ‘device connected’ voice prompts.”
Check the status of the Bluetooth radio
rfkill list
If it says Soft blocked: yes, run
sudo rfkill unblock bluetooth
Then restart bluetooth service
sudo systemctl restart bluetooth
Run
pactl list cards short
If you see bluez_card.AA_9B_B8_7E_58_3E there, but no sink, manually set the profile:
pactl set-card-profile bluez_card.AA_9B_B8_7E_58_3E a2dp-sink
I test it , but not work
jetson@jetson ~ $ rfkill list
0: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
1: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
jetson@jetson ~ $ ^C
jetson@jetson ~ $ sudo systemctl restart bluetooth
jetson@jetson ~ $ pactl list cards short
40      alsa_card.platform-88090b0000.hda       alsa
41      alsa_card.usb-FY-SP003_FY-SP003_V1.0.0.20231021_S3_D3_gain_22_12-00     alsa
42      alsa_card.platform-sound        alsa
jetson@jetson ~ $
jetson@jetson ~ $ pactl set-card-profile bluez_card.AA_9B_B8_7E_58_3E a2dp-sink
Failure: No such entity
jetson@jetson ~ $ sudo rfkill unblock bluetooth
[sudo] password for jetson:
jetson@jetson ~ $
jetson@jetson ~ $
jetson@jetson ~ $ bluetoothctl disconnect AA:9B:B8:7E:58:3E
Attempting to disconnect from AA:9B:B8:7E:58:3E
Successful disconnected
jetson@jetson ~ $ bluetoothctl connect AA:9B:B8:7E:58:3E
Attempting to connect to AA:9B:B8:7E:58:3E
[CHG] Device AA:9B:B8:7E:58:3E Connected: yes
Connection successful
jetson@jetson ~ $
jetson@jetson ~ $
        Soft blocked: no
        Hard blocked: no
1: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
Please apply this for a try:
Enabling Bluetooth Audio — NVIDIA Jetson Linux Developer Guide
