Hi there, is there anyway to add the paint system that we can find in the 2023 composer downloaded via the launcher, into a custom build of the composer template using the 106 kit. I cant find it in the developer extension list.
At this time, we are still in the process of publishing all the 105 extensions in 106 versions. We started with the core extensions and paint is just a bit further down the list right now. It should be up within the next few weeks. If you want to try to add the 105.2 version you can try that.
Thanks Richard, i actually tried but due to some dependencies with other extensions i was not able to make it work. However i´m very pleased to hear you will indeed support it for 106, just a last thing, how exactly can i know when this is released? Is there an specific site where you post these updates?
No specific site as yet. But I will try to keep you up to date. Give us about a month. Maybe Oct 1st ish
