PCB flex specification for Jetson Xavier NX
I have two questions regarding the note in the Jetson Xavier NX Thermal Guide:
“For Jetson Xavier NX, the amount of flex (bow or bend) of the PCB should not cause more than 500 micro-strain within 5 mm of the Xavier SoC.”
  1. Could you please clarify the exact definition of this specification?
  2. Based on this definition, what is the allowable board deflection? Deformation/SoM length(69.6mm)=?%?
Please refer to IPC/JEDEC-9704 for strain gauge measurement setup https://www.jedec.org/sites/default/files/docs/IPC-JEDEC9704.pdf
