I’m facing critical issues on my Dell laptop with Intel Core i9 13th Generation and NVIDIA GeForce RTX 4060 Laptop GPU, using hybrid graphics (Intel + NVIDIA) on Ubuntu 24.04.2 LTS.
The system becomes very hot, then freezes completely often after running just one or two terminal commands. I am unable to use the system reliably for any GPU-intensive tasks.
Even after a clean install, just running one or two commands in the terminal causes the system to freeze especially when using the NVIDIA GPU.
first I installed ubuntu 22.04 LTS than 20.04 multiple times, than I reinstalled Ubuntu 20.04, 22.04, and now 24.04.2, but the same issue occurs in all.
Installed several different NVIDIA drivers: 535, 550,575, 570 (recommended), current driver is 570.
Tried switching between on-demand and nvidia mode with prime-select.
Installed drivers via Ubuntu “Additional Drivers” and also via manual .run file.
Used nvidia-smi to enable persistence mode and set power limits, but the problem remains.
System Info:
Laptop: Dell (with Hybrid Graphics)
CPU: Intel Core i9
GPU: NVIDIA GeForce RTX 4060 Laptop GPU
OS: Ubuntu 24.04.2 LTS (also tried 20.04 and 22.04 same issues)
Driver: NVIDIA 570 (recommended), also tested others
Current PRIME mode: on-demand
please help me!!
