Pinmux Template without Excel
I’m running Linux and do not have easy access to a Windows computer with Excel installed. This seems to be a requirement for working with the file ‘Jetson_Thor_Series_Modules_Pinmux_Template_v1.3.xlsm’. For older releases of Jetpack and for t19x series of SOCs I can find the script ‘pinmux-dts2cfg.py’ that seems to be something that can be used outside of Windows. But I can nit find this script in Jetson Linux 38 for Thor.
Is there any other way to work with pinmux settings outside of Windows Excel?
you can directly try to changes pinmux ctrl register settings value using devmem command. But this is again temporary after booting, and it wont be retained once you reboot the unit.
libreoffice calc is quite good with this. Just tell it to allow macros. Works on every platform I know of and is free.
Unfortunately I can not get the macros to work in LibreOffice Calc. I end up in an error that I try to show in the attached screenshot.
I have not seen that error before, but I also run it from Linux. Can someone from NVIDIA try this on Windows with libreoffice calc?
@p.bergin, which version of Windows are you using?
I’m running on Ubuntu 24.04. I see now that the original request was a bit unclear and should have been running without Windows and Excel, pure Linux env. I can happen it works in Windows+LibreOffice, haven’t tested.
I’ve only used the PINMUX on Ubuntu 18.04 and 20.04, so maybe there is something needing an update when running a newer libreoffice calc. That’s also something someone from NVIDIA could try to reproduce, from 24.04 (I’m not currently set up for that either).
