I am designing a carrier board based on the Jetson NANO. I understand that there are 2 variants of the NANO viz - development module and production module. I want to know the following -
Are the pinouts for both the same ?
The repository has an excel sheet “Jetson Nano Module Pinmux Config Template”. Is it the dev or production module pinouts ?
Can you please share the link to the repository for the NANO based support documents ?
Also, i got a schematic of a carrier board which was designed using OrCAD. Is that for the production model or dev model ?I understand that there is no carrier board for the production module so how can I test it ? Should I always go get one made by Auvidea or Leopard ? How can I reduce the risk if I am to make my own board ?
