I would like to connect a custom board to the Charge Control receptacle of my Jetson TX2 devkit (J27).
On the datasheet it is written: 10-pin, 0.8mm pitch flex receptacle.
So I have bought this one: 10pcs 150mm 10Pin 0.8mm Pitch FFC cable Flexible Flat Cable Wire Ribbon Forward Direct A type|Home Automation Kits| - AliExpress
but it does not fit at all into the connector (it is a bit too wide and too thin to be clipped).
Which one should I buy?
Thank you very much by advance,
Xavier
Trumany
September 26, 2018, 2:10am
2
Hi, P/N of J27 is 50208-01001-001 from Aces, here is the link: [url]http://www.acesconn.com/product_detail.aspx?state=B&selKey=50208-&selType=ProductNo&SelMethod=Contain[/url] , its mated connector is 50375-xxxxx-xxx as said on page. You can ask Aces for detail info.
Thank you for your reply, but:
This site is in Chinese or whatever, I don’t understand this language. When I click on English icon I go back to the home page.
The link is to the female connector you put on the board. But I need the male one to plug into the female one.
I don’t plan to open an electronic component shop, I just need to get somewhere where I can buy 1 (or 10, I am generous) connector(s).
Best,
Xavier
Trumany
September 27, 2018, 1:12am
4
I can see English version site: [url]http://www.acesconn.com/eindex.aspx[/url]
The mated one is 50375-xxxxx-xxx as said previously, please contact vendor or search for selling on internet by the P/N.
Thank you for your answer.
It seems I can buy it here: https://www.yoycart.com/Product/551364440402/
I will do so and give some feedback here if it works or not here :).
Best,
Xavier
