I found one for Jetson Xavier as follows StarTech.com 4 Port USB 3.0 PCIe Card w/ 4 Dedicated 5Gbps Channels (USB 3.2 Gen 1) - UASP - SATA / LP4 Power - PCI Express Adapter Card (PEXUSB3S44V)
Should I use the same for Orin?
Thank you
Thank you
We don’t have such recommendation, maybe you can check with vendors in ecosystem. Jetson Ecosystem | NVIDIA Developer
Thank you so much! For those looking, I brought a StarTech PCIe card which works on both. But currently figuring out how to supply more power to it. I will post about it if I find anything.
