Port 4 on MATE-NET does not propagate PTP to sensor
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
We are deploying PTP synchronization on DRIVE AGX Orin with 6 radars connected to the 6 Ethernet ports of the MATE-NET J11 on switch 1.
  • PTP is correctly propagated to 5 out of 6 radars.
  • The only radar that never receives PTP is always the one connected to port 4 of the MATE-NET J11 on switch 1.
  • This behavior is consistent across two different AGX Orin boards with different radar : in both cases, the radar connected to port 4 does not receive PTP.
Based on NVIDIA’s documentation:
It seems that port 4 is configured with a different role (secondary), which might explain why PTP is not delivered to devices connected on this port.
Question
  • Is this limitation expected (port 4 configured as secondary, not propagating PTP)?
  • If so, is it possible to reconfigure port 4 to act as primary (like the other ports) so that PTP can be distributed to the radar connected on it?
Yes. For reconfiguration of port, you need to consult marvell to customize for your use case .
Thanks for your response.
To proceed with the reconfiguration of port 4 on the Marvell switch, could you please let me know if NVIDIA has a contact at Marvell that we can reach out to for support on this customization?
Alternatively, if there’s a recommended procedure or channel to initiate this request with Marvell.
Just to close the loop on this topic: after switching the network configuration to NW_CFG_BASE_SAFETY, PTP is now correctly propagated on all six ports, including the one that was previously not receiving PTP.
The issue is therefore resolved. Thanks for the guidance and support!
