gPTP time synchronization: Device connected to EQOS as GM for sensors connected to switches?
DRIVE OS Version: Provide DRIVE OS version: 6.0.10
Issue Description: Provide issue description and attached logs as text message instead of images
I am investigating gPTP time synchronization on a DRIVE AGX Orin setup with several Ethernet LiDARs connected through the onboard switches.
This closed topic seems very similar to what we observe:
“PTP synchronization issue: sensors receiving wrong time due to dual PTP sources on mgbe2_0”
From the DRIVE OS time synchronization documentation, I understand that the onboard Marvell switches have their own internal MCU/firmware for PTP/AVNU CDS 1.6 and that the switch ports use static PTP roles.
What we would like to achieve is to use an external GM connected via EQOS and distribute this time to the LiDARs connected through the onboard switches:
GOAL:
GM → EQOS (PTP Client Port) → MGBE-3/MGBE-2 (PTP Server Ports) → Switches: P10/XFI (PTP Client Port)–> Sensors (PTP Server Ports)
According to the static PTP role table described in NVIDIA DRIVE OS Linux SDK Developer Guide Time Synchronization , I am not fully sure whether this should work. The documentation shows both switch-ports (mgbe-3 and mgbe-2) only as client ports and the corresponding ports inside the switches as unchangeable server ports.
The linked forum topic makes it look as if a similar MGBE-to-switch setup should be possible in principle, although there were issues. So do I understand the documentation wrong and should an EQOS-connected external GM feeding time toward Switch-2 / MGBE3-connected LiDARs work?
I am also unsure whether, in the default state, the PHCs of EQOS, MGBE2, and MGBE3 are expected to become synchronized (that’s also how I understand the linked documentation). This is not necessery for our goal - just for better understanding.
Any clarification on the intended default behavior and the recommended setup would be very helpful.
Let me check internally if connecting GM to EQOS to achieve PTP synchronization across lidar. Is there any specific reason for your design?
Did you check connecting GM to Matenet J11 port 4 ? Do you see any issue in this setup?
@SivaRamaKrishnaNV
thank you for your reply.
The main reason for this setup is that we want to synchronize all sensors in the system, even though they are connected through different Ethernet ports and onboard switches.
In our current setup, the external grandmaster provides the vehicle-wide reference time. The external GM provides a generic IEEE 802.1AS time source, while the LiDARs require one of the automotive 802.1AS variants, such as AVNU / Automotive or AUTOSAR.
Therefore, directly connecting the external GM to Switch 1 would probably not work, because the switch is probably not able to synchronize to this GM if the profiles do not match (that’s what NVIDIAs doc says). Our idea was to use the Orin as an intermediate system: receive the external GM time on EQOS, synchronize the Orin / PHC to it, and then provide a compatible automotive gPTP profile (AVNU) towards the switch-connected sensors. That’s why we didn’t connect the GM to Matenet J11 port 4 - just because of the non-compatible gPTP-Profile.
The main question is whether DRIVE OS supports such a use case, where time received on EQOS is distributed further to sensors connected through the onboard switches, possibly with the Orin acting as a kind of gPTP gateway / profile translator.
As a separate question, we were also wondering whether it is possible to use the switch-internal time as the common time source for the switch-connected sensors, without using an external GM at all. However, for our main setup we would prefer to synchronize everything to the external GM time, because this is the common vehicle reference time.
Any updates on this?
The eqos/mgbe0/mgbe1 can connect to GM directly after configured as slave and follow GM ptp via AVNU, however it cannot forward l2 ptp packet to mgbe2/mgbe3 by default, so sensor connected to switches won’t get the GM ptp packet.
When NW_CFG_BASE_SAFETY is used as it will disable switch cpu so that AVNU will not work as l2 and only l3 udp based ptp can work.
Our expected use case for l2 AVNU would be like sensor/tegra get GM l2 ptp via port4 in matenet J11.
Does it help to clarify?
We understand that forwarding L2 PTP packets from EQOS to MGBE2/MGBE3 is not supported by default.
But is there any supported DRIVE OS configuration where Tegra acts as a boundary clock or time gateway:
EQOS as PTP slave to an external GM, and MGBE2/MGBE3 or the onboard switches as PTP master/server ports for sensors? So is this possible somehow, even if not by default?:
Also, we might be able to use AUTOSAR instead of AVNU - does that make any difference?
If no, is connecting the external GM to Matenet J11 P4 the only supported way to provide L2 automotive gPTP to switch-connected sensors?
