Ptp faill
Software Version
[*] DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (940-63710-0010-300)
other
SDK Manager Version
2.1.0
other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Issue Description
<Please provide details about your query/application pipeline/usecase/pictures here >
Error String
< Please provide just the error messages here >
Logs
Provide logs in text box instead of image
Please paste the complete application log here. If there are multiple logs, please use multiple text box
I plugged a laser radar into the mgbe1_0 port and it only supports gptp. When I tried to start PTP to synchronize time stamps, I got the following error. Could you please help me take a look?
zhangzs@tegra-ubuntu:~/adas_ws$ sudo ptp4l -v
1.92
zhangzs@tegra-ubuntu:~/adas_ws$ sudo ptp4l -S -E -2 -m -i mgbe1_0
ptp4l[1035.756]: port 1: INITIALIZING to LISTENING on INIT_COMPLETE
ptp4l[1035.756]: port 0: INITIALIZING to LISTENING on INIT_COMPLETE
ptp4l[1041.828]: port 1: LISTENING to MASTER on ANNOUNCE_RECEIPT_TIMEOUT_EXPIRES
ptp4l[1041.828]: selected local clock 48b02d.fffe.fed196 as best master
ptp4l[1041.828]: assuming the grand master role
ptp4l[1042.829]: timed out while polling for tx timestamp
ptp4l[1042.829]: increasing tx_timestamp_timeout may correct this issue, but it is likely caused by a driver bug
ptp4l[1042.830]: port 1: send sync failed
ptp4l[1042.830]: port 1: MASTER to FAULTY on FAULT_DETECTED (FT_UNSPECIFIED)
ptp4l[1058.920]: port 1: FAULTY to LISTENING on INIT_COMPLETE
ptp4l[1065.618]: port 1: LISTENING to MASTER on ANNOUNCE_RECEIPT_TIMEOUT_EXPIRES
ptp4l[1065.618]: selected local clock 48b02d.fffe.fed196 as best master
ptp4l[1065.618]: assuming the grand master role
ptp4l[1066.619]: timed out while polling for tx timestamp
ptp4l[1066.619]: increasing tx_timestamp_timeout may correct this issue, but it is likely caused by a driver bug
ptp4l[1066.619]: port 1: send sync failed
ptp4l[1066.619]: port 1: MASTER to FAULTY on FAULT_DETECTED (FT_UNSPECIFIED)
ptp4l[1082.696]: port 1: FAULTY to LISTENING on INIT_COMPLETE
ptp4l[1089.679]: port 1: LISTENING to MASTER on ANNOUNCE_RECEIPT_TIMEOUT_EXPIRES
ptp4l[1089.679]: selected local clock 48b02d.fffe.fed196 as best master
ptp4l[1089.679]: assuming the grand master role
ptp4l[1090.680]: timed out while polling for tx timestamp
ptp4l[1090.680]: increasing tx_timestamp_timeout may correct this issue, but it is likely caused by a driver bug
ptp4l[1090.680]: port 1: send sync failed
ptp4l[1090.680]: port 1: MASTER to FAULTY on FAULT_DETECTED (FT_UNSPECIFIED)
^Czhangzs@tegra-ubuntu:~/adas_ws$ cat /etc/ne
netconfig netplan/ network/ networks newt/
zhangzs@tegra-ubuntu:~/adas_ws$ cat /etc/netplan/01-lidar-network.yaml
network:
version: 2
renderer: networkd
ethernets:
mgbe1_0:
dhcp4: no
addresses:
- 192.168.1.102/24
@SivaRamaKrishnaNV Could you please take a look?
Dear @deng.shigang,
Is it like you want to sync the radar timestamp to PTP? May I know radar details to check internally on support.
is lidar。and we have solve it.by using -H instead of -S。and use the automotive-master.cfg。but we need to set tx_timestamp_timeout 1000
Dear @deng.shigang,
Glad to hear you could fix it. Could you share details on what was your mistake and how you could fix it?
We found that Orin only supports hardware-based time synchronization, and using software-based time synchronization would cause problems. Therefore, we changed to hardware-based time synchronization instead.
