Port Isaac lab Articulation to Isaac Sim Robot
Hi all, this might be a very dumb question but is there a way for me to add a robot (who’s joint configuration etc) was defined in isaac lab API to isaac sim simply via the Script Editor?
Specifically, i want to add the PSM Robot from Orbit Surgical. The ArticulationCfg is defined in this script orbit-surgical/source/extensions/orbit.surgical.assets/orbit/surgical/assets/psm.py at main · orbit-surgical/orbit-surgical · GitHub
I’m specifically using this and not URDF Importer and simply importing the URDF file because i want high quality materials as I want to try to simulate photo-realism.
I’m using isaac sim 4.2 with ubuntu 22.04
Could you follow this note and also submit your query there?
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
Started using it with Isaac Lab instead. Will post an issue on the Isaac Lab Github Repo if i still need help. Thanks
