[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140 (wujz@wujz-thinkpad-t450s) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) ) #45 SMP PREEMPT Thu Apr 30 18:11:56 HKT 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00140000@92cb0000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb1000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb0000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29400(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3568680K/4159488K available (15294K kernel code, 2934K rwdata, 6952K rodata, 8640K init, 609K bss, 115672K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009640000 ( 6976 KB)
[ 0.000000] .init : 0xffffff8009640000 - 0xffffff8009eb0000 ( 8640 KB)
[ 0.000000] .data : 0xffffff8009eb0000 - 0xffffff800a18d808 ( 2935 KB)
[ 0.000000] .bss : 0xffffff800a18d808 - 0xffffff800a225e3c ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001778] Console: colour dummy device 80x25
[ 0.001796] console [tty0] enabled
[ 0.001814] kmemleak: Kernel memory leak detector disabled
[ 0.001831] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001843] pid_max: default: 32768 minimum: 301
[ 0.002295] Security Framework initialized
[ 0.002518] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002527] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003637] ftrace: allocating 47225 entries in 185 pages
[ 0.174999] sched-energy: CPU device node has no sched-energy-costs
[ 0.175031] ASID allocator initialised with 65536 entries
[ 0.211834] tegra-id: chipid=22117.
[ 0.211847] tegra-id: opt_subrevision=0.
[ 0.211864] Tegra Speedo/IDDQ fuse revision 4
[ 0.211870] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211874] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.211879] Tegra: CPU Speedo Value 2045, SoC Speedo Value 1949, GPU Speedo Value 2052
[ 0.211883] Tegra: CPU IDDQ Value 1708, SoC IDDQ Value 1832, GPU IDDQ Value 2245
[ 0.211901] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.211916] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.211922] DTB Build time: Apr 30 2020 15:30:39
[ 0.261068] CPU1: Booted secondary processor [411fd071]
[ 0.292954] CPU2: Booted secondary processor [411fd071]
[ 0.324930] CPU3: Booted secondary processor [411fd071]
[ 0.325017] Brought up 4 CPUs
[ 0.325023] SMP: Total of 4 processors activated.
[ 0.325031] CPU features: detected feature: 32-bit EL0 Support
[ 0.325288] CPU: All CPU(s) started at EL2
[ 0.325307] alternatives: patching kernel code
[ 0.333416] devtmpfs: initialized
[ 0.370933] Initilizing CustomIPI irq domain
[ 0.371315] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.371335] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.381951] pinctrl core: initialized pinctrl subsystem
[ 0.382604] OS set in device tree is not L4T.
[ 0.383061] regulator-dummy: no parameters
[ 0.383364] Initializing plugin-manager
[ 0.383481] Plugin module not found
[ 0.383712] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[ 0.384256] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[ 0.384777] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[ 0.385534] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.385992] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.386630] node /plugin-manager/fragement@10 match with board >=3448-0002-300
[ 0.391993] NET: Registered protocol family 16
[ 0.393610] pstore: using zlib compression
[ 0.393653] console [pstore-1] enabled
[ 0.393659] pstore: Registered ramoops as persistent store backend
[ 0.393665] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.409087] cpuidle: using governor menu
[ 0.413422] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.415038] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009eb4000)
[ 0.415060] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.417570] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.420159] tegra_powergate_init: DONE
[ 0.420175] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.420182] DTB Build time: Apr 30 2020 15:30:39
[ 0.422031] Tegra reboot handler registered.
[ 0.426486] iommu: Adding device tegra-carveouts to group 0
[ 0.426622] platform tegra-carveouts: domain=ffffffc0f9bc33d8 allocates as[0]=ffffffc0f94380a8
[ 0.426973] iommu: Adding device smmu_test to group 1
[ 0.427023] platform smmu_test: domain=ffffffc0f9bc3618 allocates as[0]=ffffffc0f9438110
[ 0.427818] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.427875] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.427927] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.427934] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.427954] mc-err: mcerr ops are set to t21x
[ 0.437405] iommu: Adding device 70090000.xusb to group 2
[ 0.437683] iommu: Adding device 70006000.serial to group 3
[ 0.437764] platform 70006000.serial: domain=ffffffc0f94b4618 allocates as[0]=ffffffc0f9438178
[ 0.438188] iommu: Adding device 70006040.serial to group 4
[ 0.438459] iommu: Adding device 70006200.serial to group 5
[ 0.438683] iommu: Adding device sound to group 6
[ 0.438734] platform sound: domain=ffffffc0f94b4b58 allocates as[0]=ffffffc0f94381e0
[ 0.439288] iommu: Adding device 7000d400.spi to group 7
[ 0.439544] iommu: Adding device 7000d600.spi to group 8
[ 0.439880] iommu: Adding device 50000000.host1x to group 9
[ 0.440152] iommu: Adding device 54080000.vi to group 10
[ 0.440538] iommu: Adding device 54600000.isp to group 11
[ 0.440792] iommu: Adding device 54680000.isp to group 12
[ 0.441201] iommu: Adding device tegradc.0 to group 13
[ 0.441278] platform tegradc.0: domain=ffffffc0f94c2918 allocates as[0]=ffffffc0f9438248
[ 0.442659] platform tegradc.0: IOVA linear map 0x0000000092cb0000(140000)
[ 0.443048] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.443383] iommu: Adding device tegradc.1 to group 14
[ 0.443432] platform tegradc.1: domain=ffffffc0f94c2b58 allocates as[0]=ffffffc0f94382b0
[ 0.444801] platform tegradc.1: IOVA linear map 0x0000000092cb0000(140000)
[ 0.445223] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.445465] iommu: Adding device 54340000.vic to group 15
[ 0.445669] iommu: Adding device 544c0000.nvenc to group 16
[ 0.445863] iommu: Adding device 54500000.tsec to group 17
[ 0.446054] iommu: Adding device 54100000.tsecb to group 18
[ 0.446251] iommu: Adding device 54480000.nvdec to group 19
[ 0.446438] iommu: Adding device 54380000.nvjpg to group 20
[ 0.447508] iommu: Adding device 546c0000.i2c to group 21
[ 0.447839] iommu: Adding device 57000000.gpu to group 22
[ 0.447890] platform 57000000.gpu: domain=ffffffc0f94ceb58 allocates as[0]=ffffffc0f9438318
[ 0.447928] platform 57000000.gpu: domain=ffffffc0f94ceb58 allocates as[1]=ffffffc0f9438380
[ 0.447969] platform 57000000.gpu: domain=ffffffc0f94ceb58 allocates as[2]=ffffffc0f94383e8
[ 0.448009] platform 57000000.gpu: domain=ffffffc0f94ceb58 allocates as[3]=ffffffc0f9438450
[ 0.448893] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.448903] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.448916] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.448920] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.448925] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.501120] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.501127] tegra-pmc: Clear bootloader IO dpd settings
[ 0.501146] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.501208] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.501514] iommu: Adding device 70012000.se to group 23
[ 0.502274] iommu: Adding device 7000c000.i2c to group 24
[ 0.502531] iommu: Adding device 7000c400.i2c to group 25
[ 0.502772] iommu: Adding device 7000c500.i2c to group 26
[ 0.503022] iommu: Adding device 7000c700.i2c to group 27
[ 0.503263] iommu: Adding device 7000d000.i2c to group 28
[ 0.503540] iommu: Adding device 7000d100.i2c to group 29
[ 0.503805] iommu: Adding device sdhci-tegra.3 to group 30
[ 0.503860] platform sdhci-tegra.3: domain=ffffffc0f955ecd8 allocates as[0]=ffffffc0f94384b8
[ 0.504277] iommu: Adding device sdhci-tegra.2 to group 31
[ 0.504325] platform sdhci-tegra.2: domain=ffffffc0f955ef18 allocates as[0]=ffffffc0f9438520
[ 0.505181] iommu: Adding device 700d0000.xudc to group 32
[ 0.508530] vdd-ac-bat: 5000 mV
[ 0.508882] vdd-5v0-sys: 5000 mV
[ 0.509881] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.509921] vdd-5v0-hdmi: 5000 mV
[ 0.510299] vdd-1v8-sys: 1800 mV
[ 0.510679] vdd-fan: supplied by vdd-5v0-sys
[ 0.510713] vdd-fan: 5000 mV
[ 0.511124] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.511156] vdd-usb-vbus: 5000 mV
[ 0.511667] vdd-usb-vbus2: 5000 mV
[ 0.545815] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.548209] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.549389] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.549406] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.549435] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.549783] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.557670] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.558005] SCSI subsystem initialized
[ 0.558226] libata version 3.00 loaded.
[ 0.558561] usbcore: registered new interface driver usbfs
[ 0.558615] usbcore: registered new interface driver hub
[ 0.558680] usbcore: registered new device driver usb
[ 0.562512] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.568316] vdd-core: 600 <–> 1162 mV at 1125 mV
[ 0.569075] random: fast init done
[ 0.569180] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.572242] vdd-ddr-1v1: 1150 mV
[ 0.576238] vdd-pre-reg-1v35: 1350 mV
[ 0.580239] vdd-1v8: 1800 mV
[ 0.584232] avdd-sys-1v2: 1200 mV
[ 0.588235] vdd-pex-1v0: 1050 mV
[ 0.588790] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.589272] max77620-ldo3: at 3100 mV
[ 0.592238] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.592729] max77620-ldo5: at 3100 mV
[ 0.596237] vddio-sdmmc3-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.600232] avdd-1v05-pll: 1050 mV
[ 0.604235] avdd-io-hdmi-dp: 1050 mV
[ 0.605302] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.605579] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.606918] max77620 4-003c: max77620 probe successful
[ 0.609578] media: Linux media interface: v0.10
[ 0.609633] Linux video capture interface: v2.00
[ 0.610612] pps_core: LinuxPPS API ver. 1 registered
[ 0.610618] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.610643] PTP clock support registered
[ 0.614215] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.620540] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.621433] Advanced Linux Sound Architecture Driver Initialized.
[ 0.622094] Bluetooth: Core ver 2.22
[ 0.622144] NET: Registered protocol family 31
[ 0.622147] Bluetooth: HCI device and connection manager initialized
[ 0.622163] Bluetooth: HCI socket layer initialized
[ 0.622171] Bluetooth: L2CAP socket layer initialized
[ 0.622195] Bluetooth: SCO socket layer initialized
[ 0.623913] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.623930] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.623978] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.623992] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.627246] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.628384] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.628447] vdd-3v3-sys: 3300 mV
[ 0.628704] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.632310] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.632777] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.632815] vdd-3v3-sd: 3300 mV
[ 0.633613] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.633656] avdd-io-edp-1v05: 1050 mV
[ 0.634115] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.634153] vdd-usb-hub-en: 5000 mV
[ 0.635450] camchar: rtcpu character device driver loaded
[ 0.636279] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.637641] clocksource: Switched to clocksource arch_sys_counter
[ 0.676929] VFS: Disk quotas dquot_6.6.0
[ 0.677055] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.677552] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.677991] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.678009] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.678203] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.678209] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.678220] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.678247] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.678253] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.678266] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.678274] nvmap_page_pool_init: Total RAM pages: 1010954
[ 0.678279] nvmap_page_pool_init: nvmap page pool size: 126369 pages (493 MB)
[ 0.678364] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.678860] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.679830] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.688105] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.688518] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.688764] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.688974] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.689152] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.689408] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.689413] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.689885] NET: Registered protocol family 2
[ 0.690856] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.691066] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.691563] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.691709] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.691789] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.692194] NET: Registered protocol family 1
[ 0.692989] RPC: Registered named UNIX socket transport module.
[ 0.692994] RPC: Registered udp transport module.
[ 0.692998] RPC: Registered tcp transport module.
[ 0.693002] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.693015] PCI: CLS 0 bytes, default 64
[ 0.693252] Trying to unpack rootfs image as initramfs…
[ 0.938461] Freeing initrd memory: 5356K
[ 0.948229] host1x 50000000.host1x: initialized
[ 0.950178] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.953426] audit: initializing netlink subsys (disabled)
[ 0.953516] audit: type=2000 audit(0.799:1): initialized
[ 0.954335] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.964241] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.965786] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.966584] 9p: Installing v9fs 9p2000 file system support
[ 0.969834] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.969981] io scheduler noop registered
[ 0.970269] io scheduler cfq registered (default)
[ 0.972869] gic 702f9000.agic: GIC IRQ controller registered
[ 0.975681] iommu: Adding device 702ef000.adsp to group 33
[ 0.981932] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.982066] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.982659] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x7a29c0f
[ 0.982667] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.984277] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.984380] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.984470] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.984654] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.984747] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.984842] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.984932] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.985024] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.985107] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.985195] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.991079] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.992800] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.994778] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.996079] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.996428] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.997787] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.997858] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.998100] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 0.998342] Adding domain tsec-pd to PM domain host1x-pd
[ 1.001696] tsec 54500000.tsec: initialized
[ 1.003050] tsec 54100000.tsecb: initialized
[ 1.003738] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.007158] nvdec 54480000.nvdec: initialized
[ 1.008190] Adding domain vic03-pd to PM domain host1x-pd
[ 1.008375] Adding domain msenc-pd to PM domain host1x-pd
[ 1.008534] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.012651] falcon 54340000.vic: initialized
[ 1.013955] falcon 544c0000.nvenc: initialized
[ 1.015262] falcon 54380000.nvjpg: initialized
[ 1.019850] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.019970] display board info: id 0x0, fab 0x0
[ 1.020030] generic_infoframe_type: 0x87
[ 1.020164] tegradc tegradc.0: DT parsed successfully
[ 1.020212] tegradc tegradc.0: Display dc.ffffff800abc0000 registered with id=0
[ 1.020811] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 640x480 (on 0x0mm) pclk=25173906
[ 1.023913] tegradc tegradc.0: probed
[ 1.028122] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.032416] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.033251] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.033583] kfuse 7000fc00.kfuse: initialized
[ 1.035093] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.036083] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.037468] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.037485] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.038032] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.039273] vdd-gpu: applied init 1000000uV constraint
[ 1.039281] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.039717] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.044242] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.044387] No Device Node present for smmu client: serial8250 !!
[ 1.044403] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.044457] iommu: Adding device serial8250 to group 35
[ 1.046894] console [ttyS0] disabled
[ 1.046969] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.047061] console [ttyS0] enabled
[ 1.047993] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.048366] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.049482] [drm] Initialized
[ 1.050185] Console: switching to colour frame buffer device 80x30
[ 1.050225] tegradc tegradc.0: fb registered
[ 1.059972] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.060026] tegradc tegradc.0: hdmi: tmds rate:25174K prod-setting:prod_c_hdmi_0m_54m
[ 1.060307] brd: module loaded
[ 1.060566] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.060580] tegradc tegradc.0: hdmi: BL set VIC 0
[ 1.060587] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.066688] loop: module loaded
[ 1.066799] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.066909] tegra_profiler: auth: init
[ 1.068319] THERMAL EST: found 2 subdevs
[ 1.068326] THERMAL EST num_resources: 0
[ 1.068332] [THERMAL EST subdev 0]
[ 1.068339] [THERMAL EST subdev 1]
[ 1.068800] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.068804] THERMAL EST: thz register success.
[ 1.068950] THERMAL EST: end of probe, return err: 0
[ 1.070633] hisi_sas: driver version v1.6
[ 1.073810] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.073819] Extcon AUX1(HDMI) enable
[ 1.074858] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.074966] tegradc tegradc.1: No lt-data, using default setting
[ 1.075008] tegradc tegradc.1: No hpd-gpio in DT
[ 1.075069] tegradc tegradc.1: DT parsed successfully
[ 1.075129] tegradc tegradc.1: Display dc.ffffff800d540000 registered with id=1
[ 1.076538] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.077406] libphy: Fixed MDIO Bus: probed
[ 1.078175] tun: Universal TUN/TAP device driver, 1.6
[ 1.078178] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.082579] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 1.082583] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 1.082639] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.082642] igb: Copyright © 2007-2014 Intel Corporation.
[ 1.082697] igbvf: Intel® Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.082699] igbvf: Copyright © 2009 - 2012 Intel Corporation.
[ 1.082748] Intel® 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.082752] Copyright© 1999 - 2017 Intel Corporation.
[ 1.083811] PPP generic driver version 2.4.2
[ 1.084017] PPP BSD Compression module registered
[ 1.084023] PPP Deflate Compression module registered
[ 1.084065] PPP MPPE Compression module registered
[ 1.084072] NET: Registered protocol family 24
[ 1.084147] usbcore: registered new interface driver r8152
[ 1.084193] usbcore: registered new interface driver asix
[ 1.084236] usbcore: registered new interface driver ax88179_178a
[ 1.084281] usbcore: registered new interface driver cdc_ether
[ 1.084310] usbcore: registered new interface driver net1080
[ 1.084340] usbcore: registered new interface driver cdc_subset
[ 1.084369] usbcore: registered new interface driver zaurus
[ 1.084407] usbcore: registered new interface driver simcom_wwan
[ 1.084456] usbcore: registered new interface driver cdc_ncm
[ 1.084630] VFIO - User Level meta-driver version: 0.3
[ 1.086150] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.086172] ehci-pci: EHCI PCI platform driver
[ 1.086217] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.086228] ohci-pci: OHCI PCI platform driver
[ 1.086264] ohci-platform: OHCI generic platform driver
[ 1.088806] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.090386] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.090616] tegradc tegradc.1: probed
[ 1.092074] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9623800 id
[ 1.094133] usbcore: registered new interface driver uas
[ 1.094229] usbcore: registered new interface driver usb-storage
[ 1.094382] usbcore: registered new interface driver usbserial
[ 1.094421] usbcore: registered new interface driver option
[ 1.094457] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.101705] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.101834] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.101893] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.102963] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.103067] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.103410] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.103417] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.103423] usb usb1: Product: xHCI Host Controller
[ 1.103428] usb usb1: Manufacturer: Linux 4.9.140 xhci-hcd
[ 1.103433] usb usb1: SerialNumber: 70090000.xusb
[ 1.104505] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.104740] hub 1-0:1.0: USB hub found
[ 1.104802] hub 1-0:1.0: 5 ports detected
[ 1.105511] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.105532] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.105687] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.105787] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.105793] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.105799] usb usb2: Product: xHCI Host Controller
[ 1.105804] usb usb2: Manufacturer: Linux 4.9.140 xhci-hcd
[ 1.105808] usb usb2: SerialNumber: 70090000.xusb
[ 1.106603] hub 2-0:1.0: USB hub found
[ 1.106645] hub 2-0:1.0: 4 ports detected
[ 1.106793] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.106811] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.106873] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.107220] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.108373] mousedev: PS/2 mouse device common for all mice
[ 1.108564] usbcore: registered new interface driver xpad
[ 1.108994] cyttsp5_i2c_adapter 0-0024: cyttsp5_init: INIT CYTTSP RST gpio=194 and IRQ gpio=224 r=0
[ 1.112188] tegradc tegradc.0: nominal-pclk:25174825 parent:25173906 div:1.0 pclk:25173906 24923052~27440532
[ 1.114023] cyttsp5_i2c_adapter 0-0024: cyttsp5_startup_: Bootloader mode
[ 1.116756] tegradc tegradc.1: fb registered
[ 1.119996] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.120004] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.120012] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.120027] tegradc tegradc.1: blank - powerdown
[ 1.120052] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.120056] Extcon DP: HPD disabled
[ 1.120061] hpd: hpd_switch 0
[ 1.120065] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.120073] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.120080] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.124416] cyttsp5_i2c_adapter 0-0024: cyttsp5_hid_output_validate_bl_response: HID output response, ERROR:5
[ 1.144292] tegra-i2c 7000c000.i2c: no acknowledge from address 0x24
[ 1.144333] cyttsp5_i2c_adapter 0-0024: cyttsp5_read_input: Error getting report, r=-121
[ 1.153678] cyttsp5_i2c_adapter 0-0024: cyttsp5_startup_: Operational mode
[ 1.153683] cyttsp5_i2c_adapter 0-0024: cyttsp5_startup_: Reading report descriptor
[ 1.193540] tegradc tegradc.0: blank - powerdown
[ 1.205755] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.227301] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.227305] Extcon AUX1(HDMI) disable
[ 1.258758] tegradc tegradc.0: unblank
[ 1.302973] tegradc tegradc.0: nominal-pclk:69300000 parent:69300000 div:1.0 pclk:69300000 68607000~75537000
[ 1.303047] tegradc tegradc.0: hdmi: tmds rate:69300K prod-setting:prod_c_hdmi_54m_75m
[ 1.323515] tegradc tegradc.0: sync windows ret = 250
[ 1.329248] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 1.329252] Extcon HDMI: HPD enabled
[ 1.329283] tegradc tegradc.0: hdmi: plugged
[ 1.428000] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.429664] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.458934] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.458942] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.458947] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.458952] usb 1-2: Manufacturer: Generic
[ 1.460385] hub 1-2:1.0: USB hub found
[ 1.460989] hub 1-2:1.0: 4 ports detected
[ 1.585662] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 1.605654] usb 1-2: usb_suspend_both: status 0
[ 1.605732] usb usb1: usb_suspend_both: status 0
[ 1.831411] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.114354] cyttsp5_i2c_adapter 0-0024: cyttsp5 Protocol Version: 1.2
[ 2.138004] input: cyttsp5_mt as /devices/7000c000.i2c/i2c-0/0-0024/input/input0
[ 2.138370] input: cyttsp5_btn as /devices/7000c000.i2c/i2c-0/0-0024/input/input1
[ 2.138679] input: cyttsp5_proximity as /devices/7000c000.i2c/i2c-0/0-0024/input/input2
[ 2.233696] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.235715] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.341409] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.341422] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.341428] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.341433] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.341439] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.341482] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.341585] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.341675] cyttsp5_i2c_adapter 0-0024: cyttsp5_hid_send_output_and_wait_: HID output cmd execution timed out
[ 2.341909] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.342067] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.342095] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.342129] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit pref]
[ 2.342151] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[ 2.342290] pci 0000:01:00.0: supports D1 D2
[ 2.342294] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.351889] cyttsp5_i2c_adapter 0-0024: cyttsp5_loader_probe: Successful probe 0-0024
[ 2.351940] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[ 2.352109] cyttsp5_i2c_adapter 0-0024: Direct firmware load for cyttsp5_fw.bin failed with error -2
[ 2.352115] cyttsp5_i2c_adapter 0-0024: Falling back to user helper
[ 2.352541] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[ 2.353254] cyttsp5_i2c_adapter 0-0024: Direct firmware load for ttdl_cmcp_thresholdfile.csv failed with error -2
[ 2.353261] cyttsp5_i2c_adapter 0-0024: Falling back to user helper
[ 2.353732] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.353791] pci 0000:00:02.0: BAR 15: assigned [mem 0x20000000-0x200fffff 64bit pref]
[ 2.353799] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.353810] pci 0000:01:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bit pref]
[ 2.353832] pci 0000:01:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bit pref]
[ 2.353852] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.353864] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.353872] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.353881] pci 0000:00:02.0: bridge window [mem 0x20000000-0x200fffff 64bit pref]
[ 2.354269] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.354275] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.354283] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.354450] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.354790] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 2.354820] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.376115] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.376354] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e9:d6:30 from device tree
[ 2.377042] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.377072] r8168 Copyright © 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 2.482830] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.485281] rtc rtc1: alarm rtc device
[ 2.485303] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 2.485329] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 2.486257] i2c /dev entries driver
[ 2.488267] i2c i2c-6: Added multiplexed i2c bus 7
[ 2.488651] i2c i2c-6: Added multiplexed i2c bus 8
[ 2.488659] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 2.489499] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 2.512825] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 2.512910] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.520553] imx219 7-0010: board setup failed
[ 2.525086] imx219: probe of 7-0010 failed with error -121
[ 2.525667] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 2.548937] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 2.549021] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.556616] imx219 8-0010: board setup failed
[ 2.561093] imx219: probe of 8-0010 failed with error -121
[ 2.562371] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.565304] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 2.565311] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 2.565800] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.565818] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 2.565829] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 2.565999] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.566011] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 2.566018] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 2.566169] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.566180] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 2.566185] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 2.566377] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 2.567224] tegra_aotag tegra-aotag: Registering sensor 0
[ 2.567279] tegra_aotag tegra-aotag: Invalid temp readout
[ 2.567305] tegra_aotag tegra-aotag: Invalid temp readout
[ 2.567323] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 2.567332] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 2.568278] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.568298] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 2.568491] tegra_aotag tegra-aotag: Invalid temp readout
[ 2.568526] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 2.568947] parse_throttle_dt_data: Num cap clks = 6
[ 2.568953] parse_throttle_dt_data: clk=cclk_g type=2
[ 2.568967] parse_throttle_dt_data: clk=gpu type=4
[ 2.568995] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 2.569015] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 2.569036] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 2.569040] parse_throttle_dt_data: clk=emc type=3
[ 2.569437] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.569532] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.569685] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.570484] FAN dev name: pwm-fan
[ 2.570540] FAN:gpio request success.
[ 2.570612] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 2.570927] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 2.571119] pwm_fan_driver pwm-fan: fan tach request irq success
[ 2.571129] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.571227] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.571233] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 2.571239] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 2.571244] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 2.571249] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.571254] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.571258] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.571263] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.571268] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.571273] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.571962] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 2.572364] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 2.573375] device-mapper: uevent: version 1.0.3
[ 2.573944] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 2.579560] tegra210-cpufreq cpufreq: probe()…completed
[ 2.580316] sdhci: Secure Digital Host Controller Interface driver
[ 2.580319] sdhci: Copyright© Pierre Ossman
[ 2.580321] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.580683] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 2.585375] sdhci-tegra sdhci-tegra.2: Client registration for eMC Successful
[ 2.590066] tegra-se 70012000.se: tegra_se_probe: complete
[ 2.590604] hidraw: raw HID events driver © Jiri Kosina
[ 2.591752] usbcore: registered new interface driver usbhid
[ 2.591755] usbhid: USB HID core driver
[ 2.593911] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 2.594082] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 2.595817] nvpmodel: initialized successfully
[ 2.596894] usbcore: registered new interface driver snd-usb-audio
[ 2.596958] No Device Node present for smmu client: snd-soc-dummy !!
[ 2.596963] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 2.596981] iommu: Adding device snd-soc-dummy to group 36
[ 2.597376] knl–>in rt5640_i2c_probe
[ 2.602620] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input3
[ 2.621670] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 2.628754] OPE platform probe
[ 2.628843] OPE platform probe successful
[ 2.629210] OPE platform probe
[ 2.629292] OPE platform probe successful
[ 2.629656] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
[ 2.630015] knl–>in tegra_machine_driver_probe
[ 2.630842] tegra-asoc: sound: ASoC: CODEC DAI codec_roborock not registered
[ 2.637977] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 2.644207] knl–>snd_soc_register_card failed (-517)
[ 2.644645] u32 classifier
[ 2.644647] Actions configured
[ 2.644718] Initializing XFRM netlink socket
[ 2.645444] NET: Registered protocol family 10
[ 2.646341] NET: Registered protocol family 17
[ 2.646353] NET: Registered protocol family 15
[ 2.646429] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.646578] Bluetooth: RFCOMM socket layer initialized
[ 2.646588] Bluetooth: RFCOMM ver 1.11
[ 2.646596] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.646626] Bluetooth: HIDP socket layer initialized
[ 2.646644] 9pnet: Installing 9P2000 support
[ 2.646678] Key type dns_resolver registered
[ 2.647136] Registered cp15_barrier emulation handler
[ 2.647143] Registered setend emulation handler
[ 2.648640] registered taskstats version 1
[ 2.649204] Adding domain ve2-pd to PM domain host1x-pd
[ 2.649443] Adding domain ve-pd to PM domain host1x-pd
[ 2.651481] isp 54600000.isp: initialized
[ 2.652409] isp 54680000.isp: initialized
[ 2.662949] last reset is due to software reset
[ 2.662954] KERNEL: PMC reset status reg: 0x3
[ 2.663035] BL: PMC reset status reg: 0x3
[ 2.663037] BL: PMIC poweroff Event Recorder: 0x0
[ 2.664569] clk_cbus_recalc_rate: no gbus parent
[ 2.664575] clk_cbus_round_rate: no gbus parent
[ 2.664578] clk_cbus_round_rate: no gbus parent
[ 2.664586] clk_cbus_recalc_rate: no gbus parent
[ 2.664686] clk_cbus_recalc_rate: no gbus parent
[ 2.664690] clk_cbus_round_rate: no gbus parent
[ 2.664693] clk_cbus_round_rate: no gbus parent
[ 2.664697] clk_cbus_recalc_rate: no gbus parent
[ 2.665358] tegra_dvfs: GPU-cap: registered
[ 2.665415] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 2.665418] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 2.665420] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 2.667975] tegra_dvfs: vdd-gpu-vts: registered
[ 2.668656] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 2.669297] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 2.670065] knl–>in tegra_machine_driver_probe
[ 2.670901] tegra-asoc: sound: ASoC: CODEC DAI codec_roborock not registered
[ 2.673343] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.673748] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 2.677998] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 2.678065] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 2.682181] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 2.684307] knl–>snd_soc_register_card failed (-517)
[ 2.684905] input: gpio-keys as /devices/gpio-keys/input/input4
[ 2.686070] knl–>in tegra_machine_driver_probe
[ 2.686884] tegra-asoc: sound: ASoC: CODEC DAI codec_roborock not registered
[ 2.686979] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 2.690005] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 2.694022] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 2.700246] knl–>snd_soc_register_card failed (-517)
[ 2.701035] knl–>in tegra_machine_driver_probe
[ 2.701872] tegra-asoc: sound: ASoC: CODEC DAI codec_roborock not registered
[ 2.708995] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 2.715214] knl–>snd_soc_register_card failed (-517)
[ 2.718288] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 04:10:05 UTC (946699805)
[ 2.719297] vi 54080000.vi: vi_probe: ++
[ 2.722390] vi 54080000.vi: initialized
[ 2.724379] vi 54080000.vi: subdev nvcsi–2 bound
[ 2.724481] vi 54080000.vi: subdev nvcsi–1 bound
[ 2.725222] knl–>in tegra_machine_driver_probe
[ 2.725943] mmcblk mmc0:0001: Card claimed for testing.
[ 2.726028] tegra-asoc: sound: ASoC: CODEC DAI codec_roborock not registered
[ 2.727366] Disable partitions left on by BL
[ 2.727368] disb
[ 2.727415] bwmgr: missing cdev-type property
[ 2.727508] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.727514] DRAM derating cdev registered.
[ 2.728601] vdd-fan: disabling
[ 2.728603] vdd-usb-vbus: disabling
[ 2.728605] vdd-usb-vbus2: disabling
[ 2.728613] vddio-sdmmc-ap: disabling
[ 2.733210] vdd-3v3-sd: disabling
[ 2.733215] avdd-io-edp-1v05: disabling
[ 2.733218] vdd-usb-hub-en: disabling
[ 2.733238] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 2.739479] knl–>snd_soc_register_card failed (-517)
[ 2.739629] ALSA device list:
[ 2.739632] #0: tegra-hda at 0x70038000 irq 82
[ 2.742830] Freeing unused kernel memory: 8640K
[ 2.764173] Root device found: mmcblk0p1
[ 2.765227] Found dev node: /dev/mmcblk0p1
[ 2.787620] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.788375] Rootfs mounted over mmcblk0p1
[ 2.805361] Switching from initrd to actual rootfs
[ 2.885323] systemd[1]: System time before build time, advancing clock.
[ 2.907781] ip_tables: © 2000-2006 Netfilter Core Team
[ 2.919270] cgroup: cgroup2: unknown option “nsdelegate”
[ 2.934684] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.935443] systemd[1]: Detected architecture arm64.
[ 2.958098] systemd[1]: Set hostname to .
[ 3.020351] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.020361] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.034074] systemd[1]: network-online.target: Wants dependency dropin /etc/systemd/system/network-online.target.wants/networking.service.wujz is not a symlink, ignoring.
[ 3.120001] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.121944] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.122045] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.123954] systemd[1]: Created slice User and Session Slice.
[ 3.124002] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.124024] systemd[1]: Reached target User and Group Name Lookups.
[ 3.124074] systemd[1]: Reached target Swap.
[ 3.174036] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.522518] systemd-journald[1946]: Received request to flush runtime journal from PID 1
[ 3.766476] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 3.768574] knl–>in tegra_machine_driver_probe
[ 3.769531] tegra-asoc: sound: ASoC: CODEC DAI codec_roborock not registered
[ 3.787834] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 3.797289] knl–>snd_soc_register_card failed (-517)
[ 4.102789] using random self ethernet address
[ 4.108860] using random host ethernet address
[ 4.808774] random: crng init done
[ 4.812209] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.924131] Mass Storage Function, version: 2009/09/11
[ 4.924138] LUN: removable file: (no medium)
[ 4.932752] using random self ethernet address
[ 4.940902] using random host ethernet address
[ 4.978040] rndis0: HOST MAC ce:db:ff:fe:f4:04
[ 4.978101] rndis0: MAC ce:db:ff:fe:f4:05
[ 4.980534] usb0: HOST MAC ce:db:ff:fe:f4:06
[ 4.980571] usb0: MAC ce:db:ff:fe:f4:07
[ 4.980595] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 4.982489] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 4.982509] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 4.982543] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 4.982789] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 4.982805] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 4.991330] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 4.991357] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 4.991604] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 4.997417] l4tbr0: port 1(rndis0) entered blocking state
[ 4.997422] l4tbr0: port 1(rndis0) entered disabled state
[ 4.998769] device rndis0 entered promiscuous mode
[ 5.033964] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 5.041241] l4tbr0: port 2(usb0) entered blocking state
[ 5.041246] l4tbr0: port 2(usb0) entered disabled state
[ 5.042391] device usb0 entered promiscuous mode
[ 5.050907] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.220423] cyttsp5_i2c_adapter 0-0024: _cyttsp5_firmware_cont_builtin: No builtin firmware
[ 5.226402] cyttsp5_i2c_adapter 0-0024: cyttsp5_cmcp_parse_threshold_file: No builtin cmcp threshold file
[ 5.229499] zram: Added device: zram0
[ 5.230389] zram: Added device: zram1
[ 5.234382] zram: Added device: zram2
[ 5.236429] zram: Added device: zram3
[ 5.266815] zram0: detected capacity change from 0 to 519401472
[ 5.270703] knl–>in tegra_machine_driver_probe
[ 5.271729] tegra-asoc: sound: ASoC: CODEC DAI codec_roborock not registered
[ 5.279094] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 5.286981] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.286986] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.287121] knl–>snd_soc_register_card failed (-517)
[ 5.303666] Adding 507224k swap on /dev/zram0. Priority:5 extents:1 across:507224k SS
[ 5.307635] zram1: detected capacity change from 0 to 519401472
[ 5.317087] eth0: 0xffffff800a839000, 00:04:4b:e9:d6:30, IRQ 404
[ 5.323226] Adding 507224k swap on /dev/zram1. Priority:5 extents:1 across:507224k SS
[ 5.327105] zram2: detected capacity change from 0 to 519401472
[ 5.339388] Adding 507224k swap on /dev/zram2. Priority:5 extents:1 across:507224k SS
[ 5.347835] zram3: detected capacity change from 0 to 519401472
[ 5.367511] Adding 507224k swap on /dev/zram3. Priority:5 extents:1 across:507224k SS
[ 5.491572] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.565608] knl–>in tegra_machine_driver_probe
[ 5.566730] tegra-asoc: sound: ASoC: CODEC DAI codec_roborock not registered
[ 5.571337] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 5.574017] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 5.581677] knl–>snd_soc_register_card failed (-517)
[ 5.598452] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.627162] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.627169] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.627173] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.627177] usb 2-1: Manufacturer: Generic
[ 5.630989] hub 2-1:1.0: USB hub found
[ 5.631795] hub 2-1:1.0: 4 ports detected
[ 5.635088] knl–>in tegra_machine_driver_probe
[ 5.636062] tegra-asoc: sound: ASoC: CODEC DAI codec_roborock not registered
[ 5.645013] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 5.651407] knl–>snd_soc_register_card failed (-517)
[ 5.789666] usb 2-1: usb_suspend_both: status 0
[ 5.789829] usb usb2: usb_suspend_both: status 0
[ 5.969690] usb 1-2.4: new high-speed USB device number 3 using tegra-xusb
[ 5.990428] usb 1-2.4: New USB device found, idVendor=0bda, idProduct=c811
[ 5.990447] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.990451] usb 1-2.4: Product: 802.11ac NIC
[ 5.990455] usb 1-2.4: Manufacturer: Realtek
[ 5.990458] usb 1-2.4: SerialNumber: 123456
[ 5.993114] knl–>in tegra_machine_driver_probe
[ 5.994219] tegra-asoc: sound: ASoC: CODEC DAI codec_roborock not registered
[ 6.006628] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 6.006630] knl–>snd_soc_register_card failed (-517)
[ 7.314379] tegradc tegradc.0: blank - powerdown
[ 7.373413] extcon-disp-state extcon:disp-state: cable 47 state 0 already set.
[ 7.373416] Extcon AUX1(HDMI) disable
[ 7.394075] cyttsp5_i2c_adapter 0-0024: fb_notifier_callback: POWERDOWN!
[ 7.394105] tegradc tegradc.0: unblank
[ 7.406098] tegradc tegradc.0: nominal-pclk:69300000 parent:69300000 div:1.0 pclk:69300000 68607000~75537000
[ 7.406179] tegradc tegradc.0: hdmi: tmds rate:69300K prod-setting:prod_c_hdmi_54m_75m
[ 7.428416] cyttsp5_i2c_adapter 0-0024: fb_notifier_callback: UNBLANK!
[ 7.431264] tegradc tegradc.0: unblank
[ 7.431269] cyttsp5_i2c_adapter 0-0024: fb_notifier_callback: UNBLANK!
[ 7.431277] tegradc tegradc.1: blank - powerdown
[ 7.431281] cyttsp5_i2c_adapter 0-0024: fb_notifier_callback: POWERDOWN!
[ 7.542162] r8168: eth0: link up
[ 7.542286] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.028615] RTW: module init start
[ 8.028620] RTW: rtl8821cu v5.8.1.2_35530.20191025_COEX20191014-4141
[ 8.028623] RTW: build time: Apr 28 2020 11:40:24
[ 8.028625] RTW: rtl8821cu BT-Coex version = COEX20191014-4141
[ 8.028658] RTW: rtw_inetaddr_notifier_register
[ 8.028727] RTW:
usb_endpoint_descriptor(0):
[ 8.028730] RTW: bLength=7
[ 8.028732] RTW: bDescriptorType=5
[ 8.028734] RTW: bEndpointAddress=84
[ 8.028736] RTW: wMaxPacketSize=512
[ 8.028739] RTW: bInterval=0
[ 8.028741] RTW: RT_usb_endpoint_is_bulk_in = 4
[ 8.028743] RTW:
usb_endpoint_descriptor(1):
[ 8.028744] RTW: bLength=7
[ 8.028746] RTW: bDescriptorType=5
[ 8.028748] RTW: bEndpointAddress=5
[ 8.028750] RTW: wMaxPacketSize=512
[ 8.028752] RTW: bInterval=0
[ 8.028754] RTW: RT_usb_endpoint_is_bulk_out = 5
[ 8.028756] RTW:
usb_endpoint_descriptor(2):
[ 8.028758] RTW: bLength=7
[ 8.028760] RTW: bDescriptorType=5
[ 8.028762] RTW: bEndpointAddress=6
[ 8.028763] RTW: wMaxPacketSize=512
[ 8.028765] RTW: bInterval=0
[ 8.028767] RTW: RT_usb_endpoint_is_bulk_out = 6
[ 8.028769] RTW:
usb_endpoint_descriptor(3):
[ 8.028771] RTW: bLength=7
[ 8.028773] RTW: bDescriptorType=5
[ 8.028775] RTW: bEndpointAddress=87
[ 8.028776] RTW: wMaxPacketSize=64
[ 8.028778] RTW: bInterval=3
[ 8.028780] RTW: RT_usb_endpoint_is_int_in = 7, Interval = 3
[ 8.028782] RTW:
usb_endpoint_descriptor(4):
[ 8.028784] RTW: bLength=7
[ 8.028786] RTW: bDescriptorType=5
[ 8.028788] RTW: bEndpointAddress=8
[ 8.028789] RTW: wMaxPacketSize=512
[ 8.028791] RTW: bInterval=0
[ 8.028793] RTW: RT_usb_endpoint_is_bulk_out = 8
[ 8.028796] RTW: nr_endpoint=5, in_num=2, out_num=3
[ 8.028797] RTW: USB_SPEED_HIGH
[ 8.028800] RTW: CHIP TYPE: RTL8821C
[ 8.028906] RTW: [HALMAC]11692M
HALMAC_MAJOR_VER = 1
HALMAC_PROTOTYPE_VER = 6
HALMAC_MINOR_VER = 5
HALMAC_PATCH_VER = 5
[ 8.029702] RTW: Chip Version Info: CHIP_8821C_U2_1T1R_RomVer(1)
[ 8.029709] RTW: config_chip_out_EP OutEpQueueSel(0x07), OutEpNumber(3)
[ 8.029987] RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
[ 8.188601] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_LOGICAL_EFUSE
[ 8.188625] RTW: HW EFUSE
[ 8.188632] RTW: 0x000: 29 81 00 BC 09 00 21 00 6E 04 A4 10 10 00 30 0B
[ 8.188670] RTW: 0x010: FF FF FF FF FF FF FF FF FF FF FF 02 FF FF FF FF
[ 8.188705] RTW: 0x020: FF FF 26 27 27 28 27 27 25 22 23 22 25 26 26 28
[ 8.188739] RTW: 0x030: 33 FF FF FF FF FF F0 FF FF FF 25 25 25 26 26 26
[ 8.188773] RTW: 0x040: 29 29 29 29 29 33 FF FF FF FF FF FF FF FF FF FF
[ 8.188807] RTW: 0x050: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.188840] RTW: 0x060: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.188873] RTW: 0x070: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.188907] RTW: 0x080: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.188940] RTW: 0x090: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.188975] RTW: 0x0A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189009] RTW: 0x0B0: FF FF FF FF FF FF FF FF 7F 16 20 00 FF FF FF FF
[ 8.189044] RTW: 0x0C0: FF 01 00 41 00 00 00 00 00 FF 22 FF FF FF FF FF
[ 8.189078] RTW: 0x0D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189111] RTW: 0x0E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189145] RTW: 0x0F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189178] RTW: 0x100: DA 0B 11 C8 E3 46 02 74 EE 2A 45 AD C7 09 03 52
[ 8.189212] RTW: 0x110: 65 61 6C 74 65 6B 0E 03 38 30 32 2E 31 31 61 63
[ 8.189244] RTW: 0x120: 20 4E 49 43 08 03 31 32 33 34 35 36 FF FF FF FF
[ 8.189277] RTW: 0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189311] RTW: 0x140: FF FF FF FF 00 00 31 0F FF FF FF FF FF FF FF FF
[ 8.189345] RTW: 0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189379] RTW: 0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189431] RTW: 0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189474] RTW: 0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189508] RTW: 0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189541] RTW: 0x1A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189574] RTW: 0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189607] RTW: 0x1C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189703] RTW: 0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189737] RTW: 0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189773] RTW: 0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 8.189810] RTW: EEPROM ID = 0x8129
[ 8.189813] RTW: EEPROM Version = 0
[ 8.189817] RTW: EEPROM Regulatory=0x01
[ 8.189819] RTW: EEPROM Board Type=0x00
[ 8.189980] RTW: EEPROM Disable BT-coex, ant_num=1
[ 8.189985] RTW: hal_com_config_channel_plan chplan:0x7F
[ 8.189988] RTW: EEPROM crystal_cap=0x16
[ 8.189991] RTW: EEPROM ThermalMeter=0x20
[ 8.189993] RTW: EEPROM Customer ID=0x00
[ 8.189996] RTW: EEPROM SupportRemoteWakeup=0
[ 8.189998] RTW: EEPROM rfe_type=0x22
[ 8.190002] RTW: EEPROM PAType_2G is 0x0, ExternalPA_2G = 0
[ 8.190005] RTW: EEPROM PAType_5G is 0x0, external_pa_5g = 0
[ 8.190007] RTW: EEPROM LNAType_2G is 0x0, ExternalLNA_2G = 0
[ 8.190010] RTW: EEPROM LNAType_5G is 0x0, external_lna_5g = 0
[ 8.190012] RTW: EEPROM TypeGPA = 0x0
[ 8.190014] RTW: EEPROM TypeAPA = 0x0
[ 8.190017] RTW: EEPROM TypeGLNA = 0x0
[ 8.190019] RTW: EEPROM TypeALNA = 0x0
[ 8.190021] RTW: EEPROM tx_bbswing_24G =0x00
[ 8.190026] RTW: EEPROM tx_bbswing_5G =0x00
[ 8.190028] RTW: EEPROM USB Switch=0
[ 8.190031] RTW: EEPROM VID = 0x0BDA, PID = 0xC811
[ 8.198938] RTW: [HALMAC][ALWAYS]shall R reg twice!!
[ 8.199721] RTW: SetHwReg: bMacPwrCtrlOn=1
[ 8.266723] RTW: _rtw_hal_set_fw_rsvd_page((null)) Get [ NOR ] RsvdPageNUm ==>
[ 8.266729] RTW: LocPsPoll: 4
[ 8.266734] RTW: LocNullData: 5
[ 8.266738] RTW: LocQosNull: 6
[ 8.266741] RTW: LocBTQosNull: 7
[ 8.266745] RTW: _rtw_hal_set_fw_rsvd_page((null)) Get [ NOR ] RsvdPageNUm <==
[ 8.273983] RTW: WARN [HALMAC][WARN]the H2C ver. does not match halmac
[ 8.274831] RTW: rtl8821c_fw_dl Download Firmware from array success
[ 8.274837] RTW: NIC FW Version:24 SubVersion:5
[ 8.276083] RTW: SetHwReg: bMacPwrCtrlOn=0
[ 8.281705] RTW: hal_read_mac_hidden_rpt OK! (1, 8ms), fwdl:1, id:0x19
[ 8.281711] RTW: EEPROM Disable BT-coex by hal_spec
[ 8.281719] RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
[ 8.281890] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_PHYSICAL_EFUSE
[ 8.281901] RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
[ 8.282060] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_PHYSICAL_EFUSE
[ 8.282066] RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
[ 8.282237] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_PHYSICAL_EFUSE
[ 8.282243] RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
[ 8.282404] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_PHYSICAL_EFUSE
[ 8.282410] RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
[ 8.282572] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_PHYSICAL_EFUSE
[ 8.282577] RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
[ 8.282753] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_PHYSICAL_EFUSE
[ 8.282762] RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
[ 8.282924] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_PHYSICAL_EFUSE
[ 8.282933] RTW: rtw_hal_read_chip_info in 252 ms
[ 8.282950] RTW: init_channel_set((null)) ChannelPlan ID:0x7f, ch num:37
[ 8.282959] RTW: [RF_PATH] IC’s RF PATH:RF_1T1R, max_tx_cnt:1
[ 8.282962] RTW: [RF_PATH] PG’s trx_path_bmp:0x00, max_tx_cnt:0
[ 8.282965] RTW: [RF_PATH] Registry’s RF PATH:UNKNOWN
[ 8.282968] RTW: [RF_PATH] HALDATA’s trx_path_bmp:0x11, max_tx_cnt:1
[ 8.282970] RTW: [RF_PATH] HALDATA’s RF PATH:RF_1T1R
[ 8.282972] RTW: [RF_PATH] NumTotalRFPath:1
[ 8.282976] RTW: rtw_hal_rfpath_init trx_path_bmp:0x11(RF_1T1R), NumTotalRFPath:1, max_tx_cnt:1
[ 8.282979] RTW: [TRX_Nss] HALSPEC - tx_nss :1, rx_nss:1
[ 8.282982] RTW: [TRX_Nss] Registry - tx_nss :0, rx_nss:0
[ 8.282984] RTW: [TRX_Nss] HALDATA - tx_nss :1, rx_nss:1
[ 8.282986] RTW: rtw_hal_trxnss_init tx_nss:1, rx_nss:1
[ 8.283076] RTW: init_mlme_default_rate_set: support CCK
[ 8.283078] RTW: init_mlme_default_rate_set: support OFDM
[ 8.283352] RTW: NR_RECVBUFF: 8
[ 8.283355] RTW: MAX_RECVBUF_SZ: 32768
[ 8.283359] RTW: NR_PREALLOC_RECV_SKB: 8
[ 8.283473] RTW: rtw_alloc_macid((null)) if1, mac_addr:ff:ff:ff:ff:ff:ff macid:1
[ 8.283479] RTW: rtw_init_pwrctrl_priv: IPS_mode=1, LPS_mode=2, LPS_level=0
[ 8.283489] RTW: IQK FW offload:enable
[ 8.283496] RTW: init_phydm_cominfo: Fv=1 Cv=1
[ 8.283512] RTW: [A] 2G G00 CCK-1T base:45 from IC_DEF
[ 8.283515] RTW: [A] 2G G01 CCK-1T base:45 from IC_DEF
[ 8.283518] RTW: [A] 2G G02 CCK-1T base:45 from IC_DEF
[ 8.283520] RTW: [A] 2G G03 CCK-1T base:45 from IC_DEF
[ 8.283523] RTW: [A] 2G G04 CCK-1T base:45 from IC_DEF
[ 8.283526] RTW: [A] 2G G05 CCK-1T base:45 from IC_DEF
[ 8.283528] RTW: [A] 2G G00 BW40-1S base:45 from IC_DEF
[ 8.283531] RTW: [A] 2G G01 BW40-1S base:45 from IC_DEF
[ 8.283534] RTW: [A] 2G G02 BW40-1S base:45 from IC_DEF
[ 8.283536] RTW: [A] 2G G03 BW40-1S base:45 from IC_DEF
[ 8.283539] RTW: [A] 2G G04 BW40-1S base:45 from IC_DEF
[ 8.283560] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
[ 8.283605] RTW: phy_ConfigBBWithPgParaFile(): No File PHY_REG_PG.txt, Load from HWImg Array!
[ 8.283616] RTW: default power by rate loaded
[ 8.283621] RTW: phy_txpwr_by_rate_chk_for_path_dup duplicate 2.4G [A] to [B]
[ 8.283632] RTW: can’t get autopm:
[ 8.283638] RTW: rtw_macaddr_cfg mac addr:74:ee:2a:45:ad:c7
[ 8.283642] RTW: bDriverStopped:True, bSurpriseRemoved:False, bup:0, hw_init_completed:0
[ 8.283678] RTW: rtw_wiphy_alloc(phy0)
[ 8.283683] RTW: rtw_wdev_alloc(padapter=ffffff80114ab000)
[ 8.283688] RTW: rtw_wiphy_register(phy0)
[ 8.283691] RTW: Register RTW cfg80211 vendor cmd(0x67) interface
[ 8.283839] RTW: rtw_reg_notifier: NL80211_REGDOM_SET_BY_CORE
[ 8.284048] RTW: rtw_ndev_init(wlan0) if1 mac_addr=74:ee:2a:45:ad:c7
[ 8.284287] RTW: rtw_ndev_notifier_call(wlan0) state:16
[ 8.284933] RTW: cfg80211_rtw_get_txpower
[ 8.284941] RTW: rtw_ndev_notifier_call(wlan0) state:5
[ 8.286364] knl–>in tegra_machine_driver_probe
[ 8.287505] tegra-asoc: sound: ASoC: CODEC DAI codec_roborock not registered
[ 8.287845] RTW: cfg80211_rtw_get_txpower
[ 8.297855] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 8.305736] knl–>snd_soc_register_card failed (-517)
[ 8.308332] usbcore: registered new interface driver rtl8821cu
[ 8.308337] RTW: module init ret=0
[ 8.432451] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.432621] RTW: rtw_ndev_notifier_call(wlan0) state:13
[ 8.432627] RTW: _netdev_open(wlan0) , bup=0
[ 8.442082] RTW: [HALMAC][ALWAYS]shall R reg twice!!
[ 8.443113] RTW: SetHwReg: bMacPwrCtrlOn=1
[ 8.519082] RTW: _rtw_hal_set_fw_rsvd_page(wlan0) Get [ NOR ] RsvdPageNUm ==>
[ 8.519089] RTW: LocPsPoll: 4
[ 8.519094] RTW: LocNullData: 5
[ 8.519097] RTW: LocQosNull: 6
[ 8.519101] RTW: LocBTQosNull: 7
[ 8.519105] RTW: _rtw_hal_set_fw_rsvd_page(wlan0) Get [ NOR ] RsvdPageNUm <==
[ 8.526904] RTW: rtw_start_drv_threads(wlan0) enter
[ 8.526908] RTW: rtw_start_drv_threads(wlan0) start RTW_CMD_THREAD
[ 8.528036] RTW: WARN [HALMAC][WARN]the H2C ver. does not match halmac
[ 9.262300] RTW: FW Version:24 SubVersion:5
[ 9.262306] RTW: rtl8821c_hal_init_main: successful
[ 9.263440] RTW: txpath=0x1, rxpath=0x1
[ 9.263445] RTW: txpath_1ss:0x1, num:1
[ 9.277272] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 9.279740] RTW: rtl8821cu_hal_init in 848ms
[ 9.279751] RTW: rtw_hal_set_macaddr_port wlan0- hw port(0) mac_addr =74:ee:2a:45:ad:c7
[ 9.280080] RTW: rtw_hal_get_macaddr_port wlan0- hw port(0) mac_addr =74:ee:2a:45:ad:c7
[ 9.280085] RTW: wlan0- hw port(0) mac_addr =74:ee:2a:45:ad:c7
[ 9.280493] RTW: [HW_VAR_ENABLE_RX_BAR] 0x6A2=0x500
[ 9.302125] RTW: rtw_hal_set_macaddr_port wlan0- hw port(0) mac_addr =74:ee:2a:45:ad:c7
[ 9.302291] RTW: wlan0: hw_port(0) set mode=2
[ 9.302994] RTW: MAC Address = 74:ee:2a:45:ad:c7
[ 9.302999] RTW: rtw_cfg80211_init_wiphy:rf_type=0
[ 9.303004] RTW: [HT] HAL Support LDPC = 0x02
[ 9.303007] RTW: [HT] HAL Support STBC = 0x01
[ 9.303011] RTW: [HT] HAL Support LDPC = 0x02
[ 9.303014] RTW: [HT] HAL Support STBC = 0x01
[ 9.303017] RTW: [VHT] Support LDPC = 0x02
[ 9.303020] RTW: [VHT] Support STBC = 0x01
[ 9.303028] RTW: rtw_build_vht_cap_ie, line810, Set MAX MPDU len = 11454 bytes
[ 9.303031] RTW: [VHT] Declare supporting SGI 80MHz
[ 9.303034] RTW: [VHT] Declare supporting RX STBC = 1
[ 9.303043] RTW: -871x_drv - drv_open, bup=1
[ 9.303302] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.303312] RTW: cfg80211_rtw_set_power_mgmt(wlan0) enabled:1, timeout:-1
[ 9.303317] RTW: rtw_ndev_notifier_call(wlan0) state:1
[ 9.305580] RTW: cfg80211_rtw_get_txpower
[ 9.317050] RTW: cfg80211_rtw_get_txpower
[ 9.317129] RTW: cfg80211_rtw_get_txpower
[ 9.317513] RTW: cfg80211_rtw_get_txpower
[ 9.317582] RTW: cfg80211_rtw_get_txpower
[ 9.319164] RTW: cfg80211_rtw_get_txpower
[ 9.319261] RTW: rtw_ndev_notifier_call(wlan0) state:4
[ 9.338163] RTW: cfg80211_rtw_flush_pmksa(wlan0)
[ 9.377052] RTW: rtw_ndev_notifier_call(wlan0) state:4
[ 9.377480] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.380105] RTW: cfg80211_rtw_scan(wlan0)
[ 9.380807] RTW: [HW_VAR_CHECK_TXBUF] Empty in 0 ms
[ 9.380983] RTW: wlan0 sleep m0=0x00000002, ori reg_0x4d4=0x00000000
[ 10.830557] RTW: cfg80211_rtw_get_txpower
[ 10.845807] RTW: cfg80211_rtw_set_power_mgmt(wlan0) enabled:0, timeout:-1
[ 11.169141] fuse init (API version 7.26)
[ 11.249005] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.249018] Bluetooth: BNEP socket layer initialized
[ 12.096597] tegradc tegradc.0: unblank
[ 12.096603] cyttsp5_i2c_adapter 0-0024: fb_notifier_callback: UNBLANK!
[ 12.096613] tegradc tegradc.1: blank - powerdown
[ 12.096616] cyttsp5_i2c_adapter 0-0024: fb_notifier_callback: POWERDOWN!
[ 13.587076] RTW: wlan0 wakeup m0=0x00000002, ori reg_0x4d4=0x00000002
[ 13.587179] RTW: survey done event(22) band:0 for wlan0
[ 13.587287] RTW: rtw_indicate_scan_done(wlan0)
[ 13.597004] RTW: ==>rtw_ps_processor .fw_state(8)
[ 13.597009] RTW: ==>ips_enter cnts:1
[ 13.597011] RTW: nolinked power save enter
[ 13.597013] RTW: ===> rtw_ips_pwr_down…
[ 13.597016] RTW: ====> rtw_ips_dev_unload…
[ 13.597385] RTW: usb_read_port_cancel
[ 13.597749] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[ 13.598177] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[ 13.598563] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[ 13.598920] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[ 13.599300] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[ 13.599666] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[ 13.600048] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[ 13.600412] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[ 13.600430] RTW: usb_write_port_cancel
[ 13.600455] RTW: ==> rtl8821cu_hal_deinit
[ 13.601218] RTW: SetHwReg: bMacPwrCtrlOn=0
[ 13.607490] RTW: rtl8821cu_hal_deinit <==
[ 13.608080] RTW: <=== rtw_ips_pwr_down… in 12ms
[ 16.257603] RTW: cfg80211_rtw_get_txpower
[ 20.824296] RTW: cfg80211_rtw_get_txpower
