Possible bug when creating new material
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
4.2.0
Operating System
Ubuntu 22.04
GPU Information
  • Model: RTX 4080 Super 16 GB
  • Driver Version: 560.35.03 CUDA Version: 12.6
Unable to create material in Isaac Sim
Detailed Description
Whenever I try to create a new material, Isaac Sim freezes. In the bottom I see that it is stuck on the following step: Screenshot from 2025-02-05 10-06-49
Steps to Reproduce
  1. Create/Material/select any kind of material
Error Messages
No error messages, just Isaac Sim freezes up
Screenshots or Videos
Additional Information
What I’ve Tried
Tried to reinstall Isaac Sim and Cache. Also emptied the cache. Nothing worked.
Hi. I was the guy brought this issue up back in the discord Omniverse server.
I haven’t solved this, I just want to also reply here to get more attentions from the software team.
Btw, we actually have the exact same GPU and driver version. Could this be the problem? I will install a newer driver later.
But still, I hope software team people can look at this weird bug.
Best
Could you share the discussion link in Discord?
Could you try using Isaac Sim 4.5.0?
In 4.5.0, this bug also exists for me.
4.2 is broken for me. 4.5 takes a lot longer to load as it gets stuck on this file for like 3 mins, but then I can use it after:
Screenshot from 2025-02-09 11-53-12
Updated to the 570 driver and 4.2 is still broken.
Hi @VickNV , here is the link: Discord
4.5 at least loads for me, but it has a lot less material kinds, so even if that works, feels like a downgrade.
Does material creation work for you in isaac sim 4.5.0 after you upgrade the driver?
I also upgraded to 570 driver but the material stil can be loaded for me.
Screenshot from 2025-02-09 19-19-49
Did you do anything else?
I think there are extensions that will provide with you more material kind
Hi @HaoyuMa , I didn’t do anything else, just updated the driver, but I am not even sure that was the solution.
It was kinda weird, because on one start I was able to create materials in 4.2 and 4.5, even before the driver update. During that run I installed the new driver. Once I restarted my computer I could not create materials in 4.2 again, but 4.5 works.
Hmm. Thank you for replying to me.
I guess I will wait for the software team to fix this. This is a really weird problem and to my knwoledge, there were previous forums also brought this problem up. And some people may be able to fix it by reinstalling.
I guess I am being unlucky that none of solutions work for me.
My workaround before 4.5 was that I just used USD Composer (2023.2.5) for material / scene editing, because loading materials that were part of my USD files still work fine for me. Maybe see if you can use that in the meanwhile?
Hi. This is the follow up regarding the material loading leading to crash. I have found out the solution. All you need to do is to clean cache from the app selector and --user-reset. This icon problem I believe is related to the extsCache. And problem arises may be because I run ./post_install.sh and change\rename the installation folder later. Hope the software team can fix this bug in the future release.
I presume this relates to the issue you encountered in Isaac Sim 4.5.0. Please create a new topic specifically for the 4.5.0 issue, and provide detailed steps to reproduce it. Thanks.
