I’ve read some of the related threads here, and the Jetson section on Elinux.org
https://devtalk.nvidia.com/default/topic/762822/?comment=4267532
https://devtalk.nvidia.com/default/topic/780560/?comment=4853671
Have the TK1 in an enclosure and would just like to add a power on/off button to the outside of the enclosure.
I don’t know much about electronics and want to clarify info in the TK1 Devkit PDF.
The schematic for the Front Panel Header has me confused if a resistor needs to be added.
Pins 6 /8 are for Power Button
What has me confused is in the schematic, I see this for pin 6 ( PWRBTN_R_L --> 33 Ohm --> ONKEY_L ). Does a 33 Ohm resistor need to be added?
It looks like I could use a 2 pin header cable, much like those used for front panel connections on PC ATX motherboard. I would just need to buy a power button and connect it to the front panel header.
If what I’m thinking is right, which would be correct to do?
2 pin header cable --> power button
2 pin header cable --> 33 Ohm Resistor --> Power button
