i have jetson nx xavier dev kit , recently the jetson suddenly power off by itself and i dont know the reason. i suspect something but first i will tell what i tried. i thought that the powering off is when the board is max loaded it powers off to prevent overheating,but i tried to do stress tests on cpu and gpu and it worked very good and the temps didnt exceed 45deg
second thing , i think the reason is someway with usb ports as the powering off problems happens either when there is usb connected to the board or when i plug usb
there is no specific thing as it may keep working while i connecting 4 usb devices and sometimes it power off when plugging 1 device , it also doesn`t depend on the device (this can be happened while connecting any usb like mouse, camera, microcontroller) or the port this can be happened in any of the 4 usb ports.
i don`t know if it is a coincidence or not but i want help, please as i use the board in my graduation project :'.
this is vdd log after powering off
sudo dmesg -T | grep -i “vdd|power|voltage”
[Sun Apr 6 15:59:02 2025] thermal_sys: Registered thermal governor ‘power_allocator’
[Sun Apr 6 15:59:02 2025] vdd-epb-1v0: supplied by vdd-3v3-cvb
[Sun Apr 6 15:59:04 2025] vdd-1v0: supplied by regulator-dummy
[Sun Apr 6 15:59:04 2025] vdd-1v8-hs: supplied by regulator-dummy
[Sun Apr 6 15:59:04 2025] vdd-1v8-ls: supplied by regulator-dummy
[Sun Apr 6 15:59:05 2025] vdd-1v8-ao: supplied by regulator-dummy
[Sun Apr 6 15:59:05 2025] vddio-ddr-1v1: supplied by regulator-dummy
[Sun Apr 6 15:59:05 2025] vdd-rtc: supplied by regulator-dummy
[Sun Apr 6 15:59:05 2025] vdd-ao-3v3: supplied by regulator-dummy
[Sun Apr 6 15:59:05 2025] vddio-emmc-3v3: supplied by regulator-dummy
[Sun Apr 6 15:59:05 2025] vdd-usb-3v3: supplied by regulator-dummy
[Sun Apr 6 15:59:05 2025] vddio-sdmmc1-3v3: supplied by regulator-dummy
[Sun Apr 6 15:59:05 2025] vdd-csi-1v2: supplied by vdd-1v8-ls
[Sun Apr 6 15:59:05 2025] spmic-ldo8: supplied by vdd-1v8-ls
[Sun Apr 6 15:59:05 2025] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[Sun Apr 6 15:59:07 2025] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[Sun Apr 6 15:59:08 2025] tegradc 15210000.display: blank - powerdown
[Sun Apr 6 15:59:28 2025] tegradc 15200000.display: blank - powerdown
[Sun Apr 6 15:59:28 2025] tegradc 15210000.display: blank - powerdown
[Sun Apr 6 15:59:39 2025] vdd-1v8-sd: disabling
[Sun Apr 6 15:59:39 2025] vdd-3v3-cvb: disabling
[Sun Apr 6 15:59:39 2025] vdd-1v8-cvb: disabling
[Sun Apr 6 15:59:39 2025] vdd-epb-1v0: disabling
[Sun Apr 6 15:59:39 2025] vdd-fan: disabling
[Sun Apr 6 15:59:39 2025] vdd_sys_en: disabling
