Power on
Hi! Excuse me, does AGX Orin power-on support NO MCU? At present, we have a baseboard of AGX Xavier. The power-on supply adopts NO MCU design, which can start AGX Xavier normally. Can AGX Orin be compatible with AGX Xavier to start on this baseboard?
For Orin module, customer need to follow Orin design guide to make custom design.
See also Jetson AGX Orin Power-On No MCU Design - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
OK,I see,thanks!
Hi Sir
If you have Orin SOM, you can try it on your AGX Xavier carrier board.
Maybe you will have an answer.
