I found that ORINs POWER state indicator disappeared from the tool bar.
Expected
Dissapeared
How can I recover it?
Expected
Dissapeared
Hi Hirofumi.Tamori,
Could you share the result of the following command on your board when you hit the issue?
$ sudo nvpmodel -q --verbose
$ sudo systemctl status nvpmodel.service
Will the reboot help to recover it?
Thanks Kevin,
It’s JetPack 5.1.2 for AGX Orin.
NVPM VERB: Config file: /etc/nvpmodel.conf
NVPM VERB: parsing done for /etc/nvpmodel.conf
NVPM VERB: Current mode: NV Power Mode: MAXN
0
NVPM VERB: PARAM CPU_ONLINE: ARG CORE_0: PATH /sys/devices/system/cpu/cpu0/online: REAL_VAL: 1 CONF_VAL: 1
NVPM VERB: PARAM CPU_ONLINE: ARG CORE_1: PATH /sys/devices/system/cpu/cpu1/online: REAL_VAL: 1 CONF_VAL: 1
NVPM VERB: PARAM CPU_ONLINE: ARG CORE_2: PATH /sys/devices/system/cpu/cpu2/online: REAL_VAL: 1 CONF_VAL: 1
NVPM VERB: PARAM CPU_ONLINE: ARG CORE_3: PATH /sys/devices/system/cpu/cpu3/online: REAL_VAL: 1 CONF_VAL: 1
NVPM VERB: PARAM CPU_ONLINE: ARG CORE_4: PATH /sys/devices/system/cpu/cpu4/online: REAL_VAL: 1 CONF_VAL: 1
NVPM VERB: PARAM CPU_ONLINE: ARG CORE_5: PATH /sys/devices/system/cpu/cpu5/online: REAL_VAL: 1 CONF_VAL: 1
NVPM VERB: PARAM CPU_ONLINE: ARG CORE_6: PATH /sys/devices/system/cpu/cpu6/online: REAL_VAL: 1 CONF_VAL: 1
NVPM VERB: PARAM CPU_ONLINE: ARG CORE_7: PATH /sys/devices/system/cpu/cpu7/online: REAL_VAL: 1 CONF_VAL: 1
NVPM VERB: PARAM CPU_ONLINE: ARG CORE_8: PATH /sys/devices/system/cpu/cpu8/online: REAL_VAL: 1 CONF_VAL: 1
NVPM VERB: PARAM CPU_ONLINE: ARG CORE_9: PATH /sys/devices/system/cpu/cpu9/online: REAL_VAL: 1 CONF_VAL: 1
NVPM VERB: PARAM CPU_ONLINE: ARG CORE_10: PATH /sys/devices/system/cpu/cpu10/online: REAL_VAL: 1 CONF_VAL: 1
NVPM VERB: PARAM CPU_ONLINE: ARG CORE_11: PATH /sys/devices/system/cpu/cpu11/online: REAL_VAL: 1 CONF_VAL: 1
NVPM VERB: PARAM TPC_POWER_GATING: ARG TPC_PG_MASK: PATH /sys/devices/gpu.0/tpc_pg_mask: REAL_VAL: 0 CONF_VAL: 0
NVPM VERB: PARAM GPU_POWER_CONTROL_ENABLE: ARG GPU_PWR_CNTL_EN: PATH /sys/devices/gpu.0/power/control: REAL_VAL: auto CONF_VAL: on
NVPM VERB: PARAM CPU_A78_0: ARG MIN_FREQ: PATH /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq: REAL_VAL: 729600 CONF_VAL: 729600
NVPM VERB: PARAM CPU_A78_0: ARG MAX_FREQ: PATH /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq: REAL_VAL: 2201600 CONF_VAL: 9223372036854775807
NVPM VERB: PARAM CPU_A78_1: ARG MIN_FREQ: PATH /sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq: REAL_VAL: 729600 CONF_VAL: 729600
NVPM VERB: PARAM CPU_A78_1: ARG MAX_FREQ: PATH /sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq: REAL_VAL: 2201600 CONF_VAL: 9223372036854775807
NVPM VERB: PARAM CPU_A78_2: ARG MIN_FREQ: PATH /sys/devices/system/cpu/cpu8/cpufreq/scaling_min_freq: REAL_VAL: 729600 CONF_VAL: 729600
NVPM VERB: PARAM CPU_A78_2: ARG MAX_FREQ: PATH /sys/devices/system/cpu/cpu8/cpufreq/scaling_max_freq: REAL_VAL: 2201600 CONF_VAL: 9223372036854775807
NVPM VERB: PARAM GPU: ARG MIN_FREQ: PATH /sys/devices/17000000.ga10b/devfreq_dev/min_freq: REAL_VAL: 306000000 CONF_VAL: 0
NVPM VERB: PARAM GPU: ARG MAX_FREQ: PATH /sys/devices/17000000.ga10b/devfreq_dev/max_freq: REAL_VAL: 1300500000 CONF_VAL: 9223372036854775807
NVPM VERB: PARAM GPU_POWER_CONTROL_DISABLE: ARG GPU_PWR_CNTL_DIS: PATH /sys/devices/gpu.0/power/control: REAL_VAL: auto CONF_VAL: auto
NVPM VERB: PARAM EMC: ARG MAX_FREQ: PATH /sys/kernel/nvpmodel_emc_cap/emc_iso_cap: REAL_VAL: 0 CONF_VAL: 0
NVPM VERB: PARAM DLA0_CORE: ARG MAX_FREQ: PATH /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_core: REAL_VAL: 1600000000 CONF_VAL: 9223372036854775807
NVPM VERB: PARAM DLA1_CORE: ARG MAX_FREQ: PATH /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_core: REAL_VAL: 1600000000 CONF_VAL: 9223372036854775807
NVPM VERB: PARAM DLA0_FALCON: ARG MAX_FREQ: PATH /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_falcon: REAL_VAL:
844800000 CONF_VAL: 9223372036854775807
NVPM VERB: PARAM DLA1_FALCON: ARG MAX_FREQ: PATH /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_falcon: REAL_VAL:
NVPM VERB: PARAM PVA0_VPS: ARG MAX_FREQ: PATH /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_vps: REAL_VAL: 1152000000 CONF_VAL: 9223372036854775807
NVPM VERB: PARAM PVA0_AXI: ARG MAX_FREQ: PATH /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_cpu_axi: REAL_VAL: 832000000 CONF_VAL: 9223372036854775807
* nvpmodel.service - nvpmodel service
Loaded: loaded (/etc/systemd/system/nvpmodel.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Tue 2024-09-10 13:29:44 JST; 1h 34min ago
Process: 1214 ExecStart=/etc/systemd/nvpmodel.sh (code=exited, status=0/SUCCESS)
Main PID: 1214 (code=exited, status=0/SUCCESS)
Sep 10 13:29:43 xa systemd[1]: Starting nvpmodel service...
Sep 10 13:29:44 xa systemd[1]: nvpmodel.service: Succeeded.
Sep 10 13:29:44 xa systemd[1]: Finished nvpmodel service.
Both working one and disappered one show the same result.
It may depend on gdm things, I guess.
I almost reach to the root cause.
The icon is provided by /usr/share/nvpmodel_indicator/nvpmodel_indicator.py
And because somehow I modified the python settings and it failed to access the required module 'gi'.
I reset the python setting to the default, the POWER state indicator came back.
Linux desktop is something difficult to me ;p
