I have a system that includes both a Jetson AGX Orin and a Wi-Fi router that can be powered via a USB-C cable. According to the router’s documentation, its power consumption is “<8.75W.”
To reduce the complexity of the power supply setup, I plan to connect the router directly to one of the Jetson’s USB ports. Will the Jetson’s USB ports be able to provide 5V at approximately 2A for an extended period without causing overheating or damaging the hardware? Should I use one of the USB-C ports, or can I also use the USB-A ports?
