Does the USB type C input allow for more than 15W in the Nvidia Jetson Orin dev kit? I cheked in this datasheet https://openzeka.com/en/wp-content/uploads/2022/08/Jetson-AGX-Orin-Module-Series-Datasheet.pdf but I am not certain whether the supplies higher than 15W can only be delivered though the jack input.
It is supported. Please refer to the devkit carrier board spec: Jetson AGX Orin Developer Kit Carrier Board Specification
VBUS supports up to 5A per Type C connector.
