Problem about flash AGX orin
I am trying to flash my AGX Orin 32GB development kit with sdkmanager 1.9.3. My host machine is ubuntu20.04 (not vm). The version I am trying to flash is 5.1.2.
Here is the problem I met when I reflash it.
Can someone help me with that please?
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_AGX_Orin_modules_2023-09-05_11-55-38.zip (95.1 KB)
This is the report I have.
please try running the following commands on your host PC:
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
, after that, put your device into force recovery mode again and flash again.
Thank you for your response.
I met this problem. But I have manually set the board to recovery mode ,by pressing and hold bottom 2, then press bottom 3 and hold, then release 3 then 2.
Still I have the problem like this
Have you done this?
You may need to try more times and also hot-plug the USB cable, or reset/reboot your host PC.
