I just got a jetson TX1, it’s installation was successful and it is working fine, but I wanted to access it via a remote desktop on local network so I have successfully done it using VNC service of Linux.
The problem that I am facing is that if I start the board when the HDMI is connected to a screen and then try to access it through VNC it is visible and if I remove the HDMI and then reboot it it becomes inaccessible via VNC. Also if I connect the HDMI at this stage then I don’t get a display, i.e.,I have to restart the board.
I have also assigned it a static IP for remote access.
