Hi!
I am trying to read a contact sensor on IsaacSim using the standalone Python API workflow.
I did a minimal example as follows. I am creating a scene, a default ground, a dynamic sphere, and a contact sensor attached to the dynamic sphere. However, the readings of the contact sensor are always zero. What I am missing?
Thank you in advance
import omni
from omni.isaac.kit import SimulationApp
CONFIG = {"renderer": "RayTracedLighting",
"width": "1920",
"height": "1080",
"headless": False} #False
simulation_app = SimulationApp(CONFIG) # we can also run as headless.
from omni.isaac.core import World
from omni.isaac.core.objects import DynamicSphere
from omni.isaac.isaac_sensor import _isaac_sensor
from omni.isaac.core.utils.viewports import set_camera_view
import omni.physxdemos as demo
import omni.physx as _physx
import rosgraph
import numpy as np
from pxr import Gf
import omni.kit.commands
simulation_app.update()
world = World(stage_units_in_meters=1.0)
world.scene.add_default_ground_plane()
set_camera_view(eye=np.array([30, 30, 40]), target=np.array([0, 0, 0]))
sphere = world.scene.add(
DynamicSphere(
prim_path="/World/Sphere",
name="sphere",
position=np.array([0, 0, 15.91708]), # Using the current stage units which is in meters by default.
radius=0.3, # most arguments accept mainly numpy arrays.
color=np.array([0, 0, 1.0]),
mass = 100,
visible = True,
# RGB channels, going from 0-1
sensor_path = "/World/Sphere"
world.reset()
sphere_egg_breaker = world.scene.get_object("sphere_egg_breaker")
result, sensor = omni.kit.commands.execute(
"IsaacSensorCreateContactSensor",
path="/sensor",
parent= sensor_path,
min_threshold=0,
max_threshold=10000000,
color= (1, 0, 0, 1),
radius=0.4, #0.01
sensor_period=0.5,
offset= Gf.Vec3d(0,0,0),
visualize=True,)
_cs = _isaac_sensor.acquire_contact_sensor_interface()
i = 0
while simulation_app.is_running():
world.step(render=True)
if world.is_playing():
if world.current_time_step_index == 0:
world.reset()
i = i+1
readings = _cs.get_sensor_sim_reading(sensor_path +"/sensor")
print("Contact sensor: ", readings.inContact, readings.time, readings.value)
print(i)
simulation_app.close() # close Isaac Sim
