I am now learning to use Contact Sensor from “from omni.isaac.sensor import ContactSensor”. However, I find a weird situation that even though there is no “actual” contact, the data from contact sensor still get updated like this:
2024-01-07 19:28:12 [Info] [omni.kit.app._impl] [py stdout]: {'in_contact': True, 'force': 0.0, 'time': 4.116666793823242, 'number_of_contacts': 1, 'contacts': [{'body0': '/panda/panda_rightfinger', 'body1': '/World/pick_cube', 'position': [0.446928, 0.028464135, 0.06670742], 'normal': [0.7892201, 0.12467989, 0.60132074], 'impulse': [0.0, 0.0, 0.0]}]}
The code to print
_contact_sensor_interface = _sensor.acquire_contact_sensor_interface()
cs_sensor_reading = _contact_sensor_interface.get_sensor_reading("/panda/panda_rightfinger/Contact_Sensor")
cs_raw_data = _contact_sensor_interface.get_contact_sensor_raw_data("/panda/panda_rightfinger/Contact_Sensor")
_current_frame = dict()
if cs_sensor_reading.is_valid:
_current_frame["in_contact"] = bool(cs_sensor_reading.in_contact)
_current_frame["force"] = float(cs_sensor_reading.value)
_current_frame["time"] = float(cs_sensor_reading.time)
# self._current_frame["physics_step"] = float(self._number_of_physics_steps)
_current_frame["number_of_contacts"] = len(cs_raw_data)
_current_frame["contacts"] = []
for i in range(len(cs_raw_data)):
contact_frame = dict()
contact_frame["body0"] = _contact_sensor_interface.decode_body_name(
int(cs_raw_data["body0"][i])
contact_frame["body1"] = _contact_sensor_interface.decode_body_name(
int(cs_raw_data["body1"][i])
contact_frame["position"] = [
cs_raw_data["position"][i][0],
cs_raw_data["position"][i][1],
cs_raw_data["position"][i][2]
contact_frame["normal"] = [
cs_raw_data["normal"][i][0],
cs_raw_data["normal"][i][1],
cs_raw_data["normal"][i][2]
contact_frame["impulse"] = [
cs_raw_data["impulse"][i][0],
cs_raw_data["impulse"][i][1],
cs_raw_data["impulse"][i][2]
_current_frame["contacts"].append(contact_frame)
print(_current_frame)
And the viewport of the exact time step:
And how the sensor is added:
