Hey,
I’m currently working with the contact sensor in Isaac Sim for my bachelor thesis.
I found the “Output Types” section in the API, but I’m still confused.
https://docs.omniverse.nvidia.com/py/isaacsim/source/extensions/omni.isaac.isaac_sensor/docs/index.html
I got two problems:
1) get_sensor_readings
The Order in the API is diffrent to the Output order in Isaac sim. I figured out which value is which output.
But what does “Value - sensor force reading value” actually mean?
I understood it, as the force meassured in direction of the x-axis. Is that correct?
2) get_contact_sensor_raw_data
Here I lost it completly.
This method produces an array with 4 elements and each element has 7 elements.
I see the diffrent outputs in the API but I can’t figure out how to interpret the values.
Here an example of my output:
[(1769.55, 0.01666667, 445415896, 445175368, (-1.2844094, -4.44703 , 3.1296086), (-0.00183242, -0.00090104, 0.9999976), (-0. , -0. , 0. ))
(1769.55, 0. , 445415896, 445175368, (-1.2411792, -4.545627, 3.1295629), (-0.00183242, -0.00090104, 0.9999976), (-0.11149172, -0.05482317, 60.843887))
(1769.55, 0. , 445415896, 445175368, (-1.1598302, -4.39112 , 3.1295764), (-0.00183242, -0.00090104, 0.9999976), (-0.21032718, -0.10342294, 114.78092 ))
(1769.55, 0. , 445415896, 445175368, (-1.1265872, -4.514685, 3.1295273), (-0.00183242, -0.00090104, 0.9999976), (-0.17403138, -0.08557542, 94.97337 ))]
Thanks for your help
