Isaac Sim Contact Sensor - No Force Data
I have placed contact sensors on the end-effector of ur10 with slight offset to ensure that it touches the cube in the environment.
I do get some contact data but the impulses and the forces are zero. My data looks like this when the manipulator is in contact with the cube:
{‘time’: 16.66666753590107, ‘physics_step’: 1000.0, ‘contacts’: [{‘body0’: ‘/World/UR10/wrist_3_link’, ‘body1’: ‘/World/fixed_cube’, ‘position’: array([0.10658075, 1.2599742 , 0.38374284], dtype=float32), ‘normal’: array([ 9.6200620e-06, -1.0000000e+00, -1.3767298e-06], dtype=float32), ‘impulse’: array([ 0., -0., -0.], dtype=float32)}, {‘body0’: ‘/World/UR10/wrist_3_link’, ‘body1’: ‘/World/fixed_cube’, ‘position’: array([0.10658075, 1.2599742 , 0.38374284], dtype=float32), ‘normal’: array([ 9.6200620e-06, -1.0000000e+00, -1.3767298e-06], dtype=float32), ‘impulse’: array([ 0., -0., -0.], dtype=float32)}, {‘body0’: ‘/World/UR10/wrist_3_link’, ‘body1’: ‘/World/fixed_cube’, ‘position’: array([0.10658075, 1.2599742 , 0.38374284], dtype=float32), ‘normal’: array([ 9.6200620e-06, -1.0000000e+00, -1.3767298e-06], dtype=float32), ‘impulse’: array([ 0., -0., -0.], dtype=float32)}], ‘in_contact’: False, ‘force’: 0.0, ‘number_of_contacts’: 3}
And like this when its not
{‘time’: 16.66666753590107, ‘physics_step’: 1000.0, ‘contacts’: [], ‘in_contact’: False, ‘force’: 0.0, ‘number_of_contacts’: 0}
I would like there to be force data.
Additionally, Is there a way to cover the entire UR10 with a blanket of contact sensors, so that every single part of ur10 gives me contact data?
Please let me know
Hello! the impulse is the force that the physx engine provides. In order to convert the impulse into a force, you need to divide it by your simulation timestep (usually 60 timesteps per second: 0.01666, or multiply it by 60 :)
To have any part of the UR10 with contact reporting, you can add one contact sensor per body, and set the sensor radius to -1, therefore disabling its clipping and capturing every contact that happens on the body.
But the impulse has 0 value :/
Also, what I would like to do is get contact force at every single point on ur10 and not a net force from all the contact points. Do I have to manually place multiple contact sensors for this?
In that case I’d suggest you use the raw data as you were before. Your zero may also be a rounding issue when printing. Try multiplying by your time steps per second to see if you get anything above zero
