I am having a problem with the Nvidia driver 435.21 for 0ubuntu0 18.04.2 for Linux Mint 19.3 Cinnamon Verstion 4.4.8. I am trying to use my external NEC monitor with the HDMI connection. When I look at the Graphics information in Terminal mode the driver reads as: N/A for my Nvida graphics card. I have downloaded and installed the new driver, as is the recommended metapackage.
–Graphics Card: GM107M (GeForce GTX 960M)
/var/log/nvidia-installer.log.
chris@chris-HP:~$ sudo uname -a
[sudo] password for chris:
Linux chris-HP 5.3.0-42-generic #34~18.04.1-Ubuntu SMP Fri Feb 28 13:42:26 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
chris@chris-HP:~$ sudo inxi -SMCGx
System:
Host: chris-HP Kernel: 5.3.0-42-generic x86_64 bits: 64 compiler: gcc
v: 7.4.0 Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Machine:
Type: Laptop System: HP product: HP Pavilion Notebook
v: Type1ProductConfigId serial: 5CD6248S6B
Mobo: HP model: 820D v: 82.34 serial: PFYLT038J300FG UEFI: Insyde v: F.38
date: 05/24/2017
CPU:
Topology: Quad Core model: Intel Core i5-6300HQ bits: 64 type: MCP
arch: Skylake-S rev: 3 L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18399
Speed: 901 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 900 2: 900
3: 900 4: 900
Graphics:
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: Hewlett-Packard
driver: N/A bus ID: 01:00.0
Display: server: X.Org 1.20.7 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2)
v: 4.5 Mesa 19.2.8 direct render: Yes
chris@chris-HP:~$ sudo lspci -k | grep -A 2 -i “VGA”
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 530 (rev 06)
Subsystem: Hewlett-Packard Company HD Graphics 530
Kernel driver in use: i915
chris@chris-HP:~$ sudo ls /etc/modprobe.d/
alsa-base.conf blacklist.conf blacklist-modem.conf dkms.conf
amd64-microcode-blacklist.conf blacklist-firewire.conf blacklist-oss.conf intel-microcode-blacklist.conf
blacklist-ath_pci.conf blacklist-framebuffer.conf blacklist-rare-network.conf iwlwifi.conf
chris@chris-HP:~$ sudo sudo lshw -c video | grep ‘configuration’
configuration: latency=0
configuration: driver=i915 latency=0
chris@chris-HP:~$ sudo xed /var/log/gpu-manager.log
sudo Rerun the gpu-manager.log
System:
Machine:
date: 05/24/2017
CPU:
3: 900 4: 900
Graphics:
** (xed:5839): WARNING **: 19:04:57.492: Set document metadata failed: Setting attribute metadata::xed-position not supported
chris@chris-HP:~$ sudo Rerun the gpu-manager.log
sudo: Rerun: command not found
chris@chris-HP:~$
chris@chris-HP:~$ sudo gpu-manager.log
sudo: gpu-manager.log: command not found
chris@chris-HP:~$ sudo rerun the gpu-manager.log
sudo: rerun: command not found
** (xed:6272): WARNING **: 19:11:24.257: Set document metadata failed: Setting attribute metadata::xed-spell-language not supported
** (xed:6272): WARNING **: 19:11:24.258: Set document metadata failed: Setting attribute metadata::xed-encoding not supported
^C
chris@chris-HP:~$
chris@chris-HP:~$
^C
chris@chris-HP:~$
Please advise.
Thank you.
