Hi, I have a Mellanox ConnectX-4 with the latest driver. When I try to attach an interface to the team I created it says Incorrect number of parameters, even though the docs suggest that command.
The goal would be to create a team that can load balance between the two 10Gb/s interfaces so a software with multiple connections can use both interfaces at the same time using LACP.
