Server 2012 R2 preview version. Our setup has the Mellanox ConnectX3 EN Dual Port Ethernet adapters with firmware version of 2.11.500
Im creating LBFO team (evendynamic, hyper-v port or hash with static teaming) on a new Windows Server 2012
R2 OS installation without any roles or custom configurations. After restart of OS the teamed adapter disappears from Network Adapter Configuration. Inside Team Management its still persist but in faulty state and Faulted Not Found
reason for each adapter of the team. When I checked Device Manager Microsoft Network Adapter Multiplexor Driver is installed but greyed out like the hardware is unplugged for example.
As workaround I can uncheck an adapter from the team, apply the configuration, recheck it apply configuration which cause to reconnect/install/plug the teamed adapter and it appears immediately and reconnects the port in healthy state. I can do this for each
port but once I restart the node again in goes in faulty state and the teamed adapter disappears.
Update:
http://www.mellanox.com/page/products_dyn?id=129&product_family=129&menu_section=34 http://www.mellanox.com/page/products_dyn?id=129&product_family=129&menu_section=34
I have downloaded these drivers and somehow I fixed the problem on one of my cluster nodes. The problem is that I cannot fix it in the same way on my second node Ill keep you updated
